Question about Logitech Harmony 880 LCD Remote Control
Harmony 890 channels and volume wont work
Pressing on volume and channels and it will not doing anything. HELP!
  • 3 Answers
Sometimes you need to go into the menu page for the device that doesn't work and you need to "learn" the keys to the new remote. "Learn" meaning pressing the buttons on your original remote with the Infrared part of the remote facing the Infrared part of the new remote. This will help the Harmony remote duplicate the signal to the device you want to operate.
Posted on Feb 12, 2009
My Harmony 890 will not change the channels through my U-Verse box unless I am 2-3 feet from the face of the unit. The volume control works fine with my receiver.
Hi. This could be an issue with the IR emitters on your remote wearing out, or your U-verse's IR receiver could be faulty. Try controlling the U-verse with the original remote. If the same thing happens with the original remote, then it is the IR receiver (U-verse) that is the problem. If the original remote is able to control the device from the normal distance, then your 890's IR emitters are the problem.
If you find that it is the Harmony remote that is the problem, try doing a firmware update as this often solves issues. To update the firmware on your remote, log in to the Harmony software, click "Downloads" at the top of the screen then click "Firmware."
I hope this helps.
D
Aug 20, 2011 | Logitech Harmony 890 LCD Remote Control
Adding a second Harmony
Account migration from a Harmony 1000 to 890 is not suppoted, though it may work.
1. In the software, click on the 'Remote Settings; tab.
2. Click 'Manage Remotes'.
3. Connect the 890 and click 'Replace Remote'.
4. Update the remote.
Like I said this is not supported by Logitech, so if anything goes wrong they may not help you out with it. The saftest way to get your 890 set up is to create a new account.
Apr 14, 2010 | Logitech Harmony 890 LCD Remote Control
My harmony remote won't change channels or do anything. It will only change the volume. Why?
Hi. There are a couple of things that you can try to get the remote working. First, you can learn the commands from the original remote for your devices.
Also, ensure that the buttons on the remote are properly mapped to commands. You can check your button mapping my clicking "Customize Buttons" beside the icon for your Activities.
Hope that is helpful.
-D
Dec 06, 2009 | Logitech Harmony 890 LCD Remote Control
The power flickered on and off last night and since then I cannot get my Harmony 890 remote to change channels. We have Direct TV. It will control the volumn and turn the tv on and off, but will not...
You DirecTV device may have been reset ack to RF. You'll have to make sure the device is set to accept IR commands in order for the Harmony remote to work on it.
This link will help you.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=12985
-D
Oct 31, 2009 | Logitech Harmony 890 LCD Remote Control
Can not change channel with 890 remote. Volume button works. Ca turn tv on and off with remote just can not change channels
Hey!
You might have to make sure your Harmony remote has the buttons customized right. The following link shows how to do it!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9700
If it still is not working, you might have to learn the commands. The next link shows how to do that:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9603
Hope this helps!
-Kennedy
Sep 28, 2009 | Logitech Harmony 890 LCD Remote Control
My Harmony 890 is blinking and won't do anything!!
try doing a firmware upgrade after booting your remote in safe mode
Jun 03, 2009 | Logitech Harmony 890 LCD Remote Control
Harmony 890 will no longer operate the tv, dvr,or sound
I had a similar issue and only needed to "re-configue" the remote... Basically, just try plugging it back into a USB cord ( connected to your computer) and go to the original programming home page and click the "Update button." It will re-program your remote as if it was new.. Over time your Harmony may lose or forget the frequency of your various components. This happened to me. Also, make sure the remote has a full charge while you're programming it. Give it a try !
Mar 18, 2009 | Logitech Harmony 890 Universal Remote
Need a manual to know how to use the various menus on the remote
The Logitech Harmony 890 remote control is programmed through the
Harmony Windows Setup Software.
Once installed, you will simply run the program and select the devices you would like to control from menus. This program finds the right codes for you and loads them into your remote control.
You can get a copy of the Harmony 890 Manual by clicking here.
I hope that helps.
_____________________________________________
Harmony 890 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Harmony MAC Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Jan 23, 2009 | Logitech Harmony 890 Universal Remote
Changes 2 channels at a time
I can help you with your Logitech Harmony 890 remote control.
I recommend resetting it up with your components to get rid of the two channel problem.
I hope that helps.
Nov 25, 2008 | Logitech Harmony 890 LCD Remote Control
Harmony 890
Hi Jeff,
Looks like the internal battery is failing/dead and needs replacing. You can purchase a spare here:
http://www.buylogitech.com/store/logius/en_US/DisplayCategoryProductListPage/categoryID.11201300
Hope that helps! Kindly rate this a Fixya if the information helped you. Thanks.
Cheers!
ID
Nov 17, 2008 | Logitech Harmony 890 LCD Remote Control
Logitech Harmony 880 LCD Remote Control Logo
410 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
