Question about Samsung 50" Slim-Depth DLP HDTV
There are white dots all over my tv screen. What causes this and what does it take to fix it?
  • Samsung Master
  • 610 Answers
You need the DMD chip replaced. Samsung is covering the cost of this repair so call 1-800-samsung and they will set you up for repair with the closest authorized service center.
Posted on Jun 01, 2010
  • j28j28 Nov 03, 2010
    just spoke to samsung 800#. they told me i was responsible for the charges. any advice?
SOURCE: White dots appearing on Samsung TV screen and multipling each day
It seems you might have an issue with the dmd board. Go to the menu, and if the dots still show on the menu, the issue definitely is with the dmd board but if they don't come up on the menu, the issue will be with the video board.
Posted on Aug 20, 2009
ltfrc
  • 227 Answers
SOURCE: white dots on tv screen
The white dots that come and go could be what is called ignition noise. Caused by something in your residence or on the power line to your living area. You will have to do some tracking. Take a portable radio and tune it to the 550mhz, you will hear a crackle or buzz, tune to the loudest that the buzz/crackle can be heard. Walk around to see were the noise gets to be the loudest. If it gets weaker you are moving away from the source. The source could be a dimmer switch for lighting, or a loose connection on a receptcle, or in the panel box that supplies the residence. Worst case it could be entering from outside source. I have tracked ignition noise as far as two houses away that had a bad butter control on a refrigerator that was on the same power line that supplied the neighbor hood. There are so many things this day and age that could be causing your dots. Yours come and go, so you will have to track it when it is acually seen on your tv. Sounds like something on a timer like refrigerator, Furnace, etc.
Posted on Jan 31, 2009
tvtek
  • 1284 Answers
SOURCE: Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
Posted on Nov 22, 2009
  • 10 Answers
SOURCE: Samsung Slim DLP TV white dots on screen Model
No way to fix it solo, but Samsung is aware of the problem. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Posted on Jan 17, 2010
  • 69 Answers
SOURCE: white dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
Posted on Feb 07, 2010
White screen
"White screen" on Samsung LED TV - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I guess I better send it to the repair shop and prepare myself for a long break ... Hello i have experienced the white screen tv as well, i got mine as part of a deal ... Samsung LCD Green Screen
Jun 11, 2015
Samsung DLP TV w/ White Dots on Screen
Jun 11, 2015
Samsung DLP white dots fix?
Apr 10, 2012
Samsung LCD TV now bright white screen
Aug 1, 2011
More results from www.cnet.com
EASY Common BLANK SCREEN FIX FOR LCD SERVICE ...
? 4:42
https://www.youtube.com/watch?v=SARGnOExL8c
May 11, 2013 - Uploaded by Tampatec
EASY Common LCD REPAIR Blank WHITE DISTORTED VIDEO... LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test ...
Samsung TV "white screen" repair - YouTube
Dec 16, 2015 | Televison & Video
My WD60638 has a couple of white dots on the screen, what causes this and how can i fix the problem
if its a dlp tv most likely the dots are from.the bulb if its an lcd tv your screen may not be of high quality u need to change it
Oct 02, 2015 | Mitsubishi WD-60638 DLP TV
I do I fix white dots on screen
Hi
Have you tuned the channel frequency tuner? Use the remote to bring up setup menu on TV, scan channel frequencies & save. If it's an old TV that can't pick up digital signals, then you need to get a digital set top box & tune to TV.
Jun 26, 2014 | Mitsubishi WD-65735 Television
My mitsubishi 65in tv has a lot of small white dots on the screen what causes this?
projection tvs can display white dots from the dust that is on the reflector mirror your lamp shines the picture on before it is reflected onto the front screen of your tv, one must be very careful when cleaning this, may be worth a service man doing it for you
Mar 07, 2013 | Televison & Video
Has got alot of white dots on big screen tv.what can we do to fix it
white dots, especially if they have gradually been increasing in numbers is usually a defect in the optical light engine, not too many other things will cause this.
Sep 02, 2012 | Televison & Video
Light bulb
White dot for DLP Projector TV is not because of the light buy. It is caused by aging DLP chip ( DMD Chip.) Your TV DLP Part should be the following image:
Check the post how to place it diy
May 04, 2012 | Televison & Video
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
White dots all over the screen
White dots are due to bad DMD chip and qualified tv tech can replace required DMD chip in this tv to fix the picture issue.
Please contact nearest Samsung service center or local tv repair shop for repair estimate.
Thanks.
May 16, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I have white dots on the screen of my hsl4266wx/xaa?
If these dots are only seen when the picture is on I would look for the Optical Block to be causing it. Are the dots in the same place each time you turn it on?
Jul 17, 2009 | Samsung HLS4266 TV
Have little white dot's on screen will changing
Highly unlikely the bulb could be at fault; it sounds a lot like a defective DLP chip. If you are not aware of how this device functions, it is an array of physical mirrors which can fail individually and cause the effect you are having. The bulb failing would cause a loss of the entire screen, not just a few points.
Jul 05, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung 50" Slim-Depth DLP HDTV Logo
578 people viewed this question
Henry  Thomas
Henry Thomas
