Question about Dometic Rooftop RV Air Conditioner
What could cause my RV air conditioner to "pop" the breaker
It happens when the electric water heater, and the fridge is on
  • Mike Butler
    Mike Butler Jun 06, 2010
    Heading doesn't give too much info, could you please add complete problem to your posting please? Thanks.
  • Dometic Master
  • 6,674 Answers
Even though you don't specify which breaker is popping, I suspect your main breaker is going as you have 3 appliances that can draw a lot of current if they are calling for power all at once. Try running fridge and/or water heater on propane when using AC, to reduce the load. Many parks and trailers are limited to 30 amp service. Those 3 items drawing power at the same time will usually draw more than that. Add use of a microwave, and your really over.
Posted on Jun 06, 2010
Circuit breaker switch to rv water heater blew and will not reset. Was working until I overloaded the unit's 30 amp service. Reset GDIF switch and replaced water heater element, per RV tech's advice.
if you have overloaded the system , it is possible that at some point the insulation has broken down and there is current leakage that is tripping the rcd unit
the current can be in milliamps so best get in an electrician to check the entire system on that breaker
Jun 01, 2016 | Heating & Cooling
Had a rain storm power went off fridge wo rks microwave works plugs I rv wrks lights in rv do not work ac does not work
sounds like one leg of the main breaker is tripped need to reset. also the a/c's in a rv require dc to operate controls. check those fuses
Sep 06, 2015 | Dometic Rooftop RV Air Conditioner
1989 damon escaper ultrasport, at full hookup site A/C working fine until it just shut off. At that moment I was programming fridge because it wasn't cooling. Might be irrevelant but fridge now...
Your AC (air conditioner) would only run on AC (alternating current - shore power) so there would be a circuit breaker. Fuses are for DC (direct current - batteries).
That said, 16A is a very odd number for a circuit breaker (or fuse).
Your AC will only run if you are connected to shore power or have a generator. (Very large inverter and a lot of house batteries is technically possible but very unlikely and it wouldn't have been built that way).
If your AC actually draws 16A then being connected to a 30A outlet is fine, I have actually connected mine to a 20A outlet at home to test it but I made sure nothing else was turned on fridge, heaters, water heater etc).
May 20, 2017 | RVs
What causes an ac unit to pull too many amps and then pops the breaker
A few things to check . Incoming voltage, unit is clean and not overworking due to debris/dirt in evaporator and condenser coils. If it trips the breaker when compressor kicking in it may be a faulty compressor start capacitor. When does it appear to happen most times?
Aug 28, 2011 | Dometic Rooftop RV Air Conditioner
Recently purchased a 4400W generator to operate travel trailer primarily and on occasion my ac unit. Connected the generator to the travel trailer, then ran the a/c, everything going well, then the circuit...
What size circuit breaker is on the generator that is tripping? You'll need a 20amp for AC alone, then consider other things that are drawing current when RV plugged in like , converter, fridge etc that may be drawing current at same time. Make sure fridge is on propane, as well as water heater if you have electric element option on water heater. AC may only draw 12-15 amps when running if good and clean and wired properly, but will draw 17-18 amps when compressor kicks in. Perhaps generator not designed for that surge?
MY AIR CONDITIONER WILL WORK GOOD FOR ABOUT 10-12 HOURS AND THE NEXT DAY I WILL AND CHECK THE RV AND THE CIRCUIT BREAKER WILL HAVE POPPED WHAT WOULD CAUSE THIS TO HAPPEN. IT COOLS GREAT. THANK YOU
most likely the condenser is very dirty and the compressor pull more amps than is suppose to and when this happens the breaker tripps.start by cleaning the condenser with a design conderser cleaner.
Aug 12, 2010 | Dometic Rooftop RV Air Conditioner
Why does the breaker keep popping when I turn on the air conditioner in my rv
The breaker will trip if the electrical draw or load from the ac unit exceeds the limits of the breaker rating. This can happen if the ac unit is getting old or has a maintenance problem which causes it to use more energy than it is supposed to. Try connecting a loaner AC unit or rental from your RV dealership to see if the problem is resolved by that.
Jul 25, 2010 | Yamaha 2500 Watt Industrial Inverter...
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Jul 22, 2010 | Dometic Rooftop RV Air Conditioner
Just bought a used 1987 Real-Lite truck camper. The roof air unit is Dometic as well as the LP/AC refrigerator. When turned to "cool" the air conditioner really draws down, dims the lights, and eventually...
To start with, if it's plugged in to a 15 amp breaker, and extension cord, the compressor starting up may just be enough to trip the breaker. It will draw close to 15 amps on start-up of compressor, and if there is a light extension cord used to plug it in, that only makes it worse. Make sure you shut all other breakers off in panel except AC, and try it. If you have water heater on hydro, fridge on hydro, and then try to start AC compressor, you'll be way over the 15 amps, especially if it's a light extension cord.
Keep in mind, in order for fridge to work, you need 12 volts DC (Battery) power going to back of fridge. If the controls aren't lighting up at top, you've most likely got no 12 Volt DC power going to fridge. Check all fuses as well.
Jun 02, 2010 | Dometic Rooftop RV Air Conditioner
Ac goes off when hot water is being used ac throws braker when you use hot water
this is amazing. these 2 things have nothing to do with each other. the only logical explaination would be the hot water leaking on the supply lines to the a/c, causing a short
Jun 19, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
151 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
