Question about Asko W6222 Top Load Washer
During water draining of our ASKO W6222, the pump noise is much louder than I would expect from a washer that everyone claims is quiet. Once the water has drained, the pump continues for a bit and the cavitation "grinding" noise becomes unsettling LOUD. The store we purchased from insists that the pumps on front load washers are louder than top load and that this is normal. Really? We have used other front load machines of similar size during U.E. travels and have never heard this. Should we be asking for technition to check this or is this machine truly noisy during pump operation?
    Sergeant:
  • 351 Answers
No these pumps are not normally that noisy,they are the same type of pump that are in all machines,if its still under warranty get it checked,
Posted on Jun 16, 2010
Asko w 6222 pump broken
The way the pump was installed must be not right or the new pump is defective.
Jan 11, 2014 | Asko W6222 Top Load Washer
My ASKO W6222 won't drain
Sounds like the inlet water valve is not seated properly and is letting water in when it shouldn't .
Jun 20, 2012 | Asko W6222 Top Load Washer
During the washing circle the machine stops and F3 appears in the time window and machine cant restart
If F3 is flashing, then you are having a problem with drainage.
Check that there is no object stuck in the drain hose outlet. Check that the pump is not blocked by foreign objects and clean the pump. Check that there are no kinks in the drain hose.
After making these corrections, run the drain program or press the key button (door open) to empty the machine.
Feb 10, 2011 | Asko W6222 Top Load Washer
Hi, I have the ASKO W6222 front load washer, my
if the valve was stuck open it would run all the time the washer was on i would say that there is a power short running to the valve turning it on when not selected
sonic boom electronics australia
Jan 04, 2011 | Asko W6222 Top Load Washer
Asko model 1776 that doesn't drain. We stored it for years and have installed it without any installation guides. It was from a construction auction and it had some mice living in it in the shed. I...
Remove the drain hose and make sure its clear. Inspect the pump outlet where the hose attaches and make sure itts clear. Usually insects build nests in the end of the hoses during storage. If this is not the problem, and it does spray water during the wash cycle, it is either the separate drain pump or the control board. test the drain pump to see if it has resisitance (unplug the unit first) if not it is bad. If the pump has resistance it may be seized. Last check the control board.
Feb 12, 2010 | Asko D1776 Built-in Dishwasher
Open Questions:
See all Asko W6222 Top Load Washer Questions
Asko W6222 Top Load Washer Logo
300 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
