Question about Xerox DocuMate 510 Document Scanner
Assembly instructions needed
Unable to install ink cart.
  • 503 Answers
1 Open the printer cover and prop it up with the support brace located on the right-hand side of the cover. It's similar to the way a car hood is propped open.
  • Step 2 Remove the black FINE ink cartridge from its container and locate the protective tape. Gently remove the protective tape used to cover the print head nozzles and electrical contacts.
  • Step 3 Insert the black FINE ink cartridge into the printer slot labeled "B." It will rest on a slight angle. Push the cartridge up and back until it clicks into place.
  • Step 4 Repeat the process for the color FINE ink cartridge, placing it in the slot labeled "C."
  • Step 5 Raise the printer cover slightly to loosen the support brace. Fold the brace inward and replace the cover to its closed position.
  • Step 6 A green LED light will flash on top of the printer. In about a minute, the LED stops flashing and displays "1." Once the "1" appears, you're ready to print.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Posted on Jun 01, 2010
    • Amy Quicke
      Amy Quicke Jul 28, 2012
      can't locate the release ? to open cabinet
    • Amy Quicke
      thanku
    Assembly instruction for a Mainstays computer cart
    Go back to Walmart and request the assembly instructions or offer to exchange your cart for a new one. If Walmart accepts the exchange, open up the new one and check for assembly instructions inside.
    Dec 28, 2016 | Office Equipment & Supplies
    Receiving cartridge error consilt user guide, can you help mke?
    Well, without knowing what printer it is or the full text of the error message, or what lead up to your proboem, this is a guess.
    Wrong ink cart.
    Empty ink cart
    Missing ink cart.
    Mis-installed ink cart.
    Many ink carts have a piece of tape over the contacts or over an air breather hole. This must be removed before installing it.
    Some printers have delicate contacts that can be bent or broken if the cart isn't installed carefully.
    Jun 29, 2015 | Office Equipment & Supplies
    CANON i560 INKS ARE MIXING AT PRINT HEAD
    Due to the wastage of ink in the cleaning proc the cleaning head and the mechanism had become clogged and by sealing the gause cover jelified the ink unableing the succtionto work the sugestion was to renew the mechanism unit ...TO DISMANTLE the printer rais the lid....the two ends must be levered carefuly from the back as you will see the front has a tiny lug holding them on ...it is a push-fit and click 3 hiden lugs hold the sides on ...use a thin bladed knife some damage may occur to them but there is no other way once loose pull the sides forward to take the light colour ""L" shape ends off the unit... this will expose 2 slots in the front and one each side near the back ...a flat tool gently pushed in 1/8th inch will release the top cover ...move the ink carrage to the centre psn exposing the cleaning pads ...I was unable to go any further as although lose the pads were sprung and was fitted to a lifting mech with a cleaning blade which scrapes the surplace ink from the suction unit simular to a mini silk screen blade...
    Dec 29, 2009 | Canon BubbleJet i560 InkJet Printer
    The printer says no cart. installed. Then I put all new ink cart in and it still says no cart for all 3 colors. Help
    Might need to remove all carts, power down and unplug for a few seconds, power up and install inks as they are asked for on the screen. Machine just gets confused...
    Jul 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
    "set ink cartridge" message won't allow me to print
    You may need a new carriage assembly, with the ink removed, with a mirror you can see down in front where the ink cart. circuit board contacts the carriage. Each slot should have 4 gold wires all of them straight. Bent ones can be straightened carefully, any missing, you'll need a new carriage assembly, a shop repair.
    Jun 23, 2009 | Canon PIXMA MP530 All-In-One InkJet...
    Epson 9600 magenta won't print - have new cap assembly installed
    The ink should come out of the cart. if not the cart is the problem at this point try anothere magenta if that does not shore it up then you need to then start looking at the print head where it goes it itself now the store you bought the ink from will give you a replacement no questions asked sometimes even if you dont got the reciept. Try those steps you be glad you did.
    Apr 23, 2009 | Epson Stylus Pro 9600 InkJet Printer
    Changing ink cartiage
    ab-e - open the lid, the cart will move to the center, use your index finger on the top of the cart. push down and out. Here's the instructions from Lexmark's site.
    Hope that fixed ya...
    Geno
    Guest: The lid switch must be bad, you can manually slide the cart assembly with your fingers if need be.
    Geno
    Mar 28, 2008 | Lexmark 83 Color Ink Cartridge (Twin Pack)...
    Ink problems....
    Take all carts out of the machine. Have a look into the cart holder. Is there ink swapping beneath the white plastic? (You might shake the machine ;-)
    If yes, the cart holder leaks and needs replacement.
    If not (your lucky!) it could be that the automatic cleaning procedure which starts when a cart is changed has soaked the carts empty.
    Do set machine with date and time and NEVER unplug NOR use a power switch which breaks the power supply.
    Do use constant power and switch off machine by pressing stand-by-fax-button!
    Everytime when machine comes to (new) power contact it runs an extensive ink cleaning procedure. thats why your carts are always near empty....
    The stand-by will prevent this and machine does some cleaning procedures which consumes only a few drops(!) of ink!
    The display asks you if you have changed the carts. Do answer this question by pressing 1 for YES or 2 for NO.
    This will reset the built-in inkcountermanagement to the correct settings
    Jan 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
    Cheap ink problem
    you need to reset chip..........
    Nov 08, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
    No cartridge found error
    One or more ink carts aredodgy, fit gen new brother inks (x4)
    On inks carts there is a flag inside them that normally floats, when it sits down due to ink level being low it blocks a photocell to stop machine from working, it needs to do this to stop any air getting in ink lines, so inks may appear to have ink in them but will not work, on some refill/aftermarket carts flag gets stuck
    Oct 27, 2007 | Brother MFC-3240C All-In-One InkJet...
    Xerox DocuMate 510 Document Scanner Logo
    264 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
