Question about Acer Aspire 5315 Notebook
Change RAM in Acer Aspire 5315 - Acer Aspire 5315 Notebook
    Genius:
  • 1,354 Answers
Hi
nplug your laptop from the AC power source and remove the battery.
  • Step 2 Protect your computer from static electricity by grounding yourself with an ESD wrist strap or through another grounding method.
  • Step 3 Locate the memory access door for the main memory module. It should be on the back of your computer.
  • Step 4 Unscrew the memory access door and remove it.
  • Step 5 Remove the RAM module by applying gentle outward pressure to the securing clips on either side of the RAM module until they release.
  • Step 6 Rotate the RAM module upward to a 45 degree angle and slide it out of the slot.
  • Step 7 Align the new RAM module with the tab in the connector slot.
  • Step 8 Slide it firmly into place and gently rotate it downward until it clicks into place.
  • Step 9 Replace the memory access door.
  • Step 10 Replace the battery and power up the computer. It should recognize the added memory and reconfigure itself for use
  • Posted on Jun 01, 2010
    Acer Aspire 5315 Screen Keep Go Black
    Does changing your power options in control panel make any difference?
    Dec 18, 2012 | Acer Aspire 3680 Laptop
    After memory upgrade it's not coming on
    The RAM is either faulty or the wrong type for this laptop.
    Try using the same brand as the original RAM but larger RAM size.
    Oct 15, 2012 | Acer Aspire 5315 Notebook
    Acer Laptop Aspire 5315 Continuous Beep on Start Up
    its either there is a stucked key on your keyboard or you have a bad ram (memory card).
    Jun 11, 2010 | Acer Aspire 4315 Notebook
    Aspire 5315 fan overworking. The laptop does not overheat, but the fan is always working and wastes ram memory
    maybe the processor works too fast. it causes the fan to work too much. or, maybe you have a defective fan. contact acer support
    Jun 09, 2009 | Acer Aspire 5315 Notebook
    NEED HELP ADDING RAM
    hi..check out the following image to insert
    the RAM in your laptop.
    http://images.compusa.com/itemdetails/A265-15001/A265-15001-out8-dw.jpg
    try it out..
    thank u..
    rate me..
    Feb 22, 2009 | Acer Aspire 5315 Notebook
    HELP WITH ADDING RAM
    attach the ram in mother boart slat2
    Installing Acer 5315 series memory
    Laptops use a different type of RAM unlike a tower computer, the RAM is like little square pieces. Unscrew the cover, lift the old RAM out and replace with the new. Its located on the back or underside of the computer.
    Jan 09, 2009 | Acer Aspire 5315 Notebook
    Acer aspire 5315 laptop ram
    There are no extra port to put new rams
    You have to use the same ram slot to use a new large ram
    Jul 30, 2008 | Acer Aspire 5315 Notebook
    Acer Aspire 5315
    I have a friend who has an Acer Aspire 5315 running Vista and it was pretty slow right out of the box with 1gb of ram. I upgraded his Ram to 2gb and it ran moderatly faster and smoother. Vista is a demanding OS because it's so graphical in nature. Windows Vista requires more ram then XP plus a better CPU to run smoothly. His had a 1.6ghz Celeron which is not that great of a CPU to begin with but uping your ram will usually up your performance a few degrees. Be careful with cheap ram it can run hot and unstable. Make sure go with a name brand PNY, Corsair, Kingston, etc. Don't just buy House ram (generic) because it's cheap. It's not worth wasting your money on junk ram.
    Hope this helps. M~
    May 01, 2008 | Acer Aspire 5315 Notebook
    Acer Aspire 5315 Notebook Logo
    117 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
