Question about Kenmore Grilling
I have a Kenmore gas bar b que model number 16238. I need to purchase a new flame difuser/diverter. Part number 16 in the manual. Can you help please. I live in the uk
SOURCE: Filters for the Kenmore Downdraft Blower
I have the manual on this model.  It says it is part#97009786 key#33. and has a phone# of 1-800-366-part(7278) to call to order. Hope this helps. My lift stop working and I am searching for answers on that.
Greg
Posted on Nov 29, 2008
trav1856
  • 57 Answers
SOURCE: flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
Posted on Dec 06, 2008
  • 3 Answers
SOURCE: I need a manual for Char-broil gas bar-b-que Model # 463420507
Try this web site:
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463232103.pdf
Posted on Dec 31, 2008
gisvc
  • 40 Answers
SOURCE: I need a manual for a McCulloch Timber Bear Model#60013414 chains
hi,
i believe this is the manual you are needing it is on ebay Item number: 150322102913 rtcurve.gif
good luck.
Posted on Mar 29, 2009
  • 43 Answers
SOURCE: I have a Kenmore natural gas grill, model #
owners manual can be gotten through the internet- Sears.com find parts,type in model# of item, select manual sounds like valves are clogged- propaine and natural gasses are dirty gasses-no filter, it comes up out of ground,through dirty pipes, all the way to peoples homes- and thats why they have to replace valves on hot water tanks/furnuces........
Posted on Jan 07, 2010
As fireplace turns in the reverse of the gas insert. Can you please help?
Google make and model number you should find a manual you can down load in a pdf .
Oct 13, 2017 | Heating & Cooling
Oven turns on gas but doesnt ignite until theres gas build up and has small explosion. kenmore model 362.75702001
What is causing that is a weak oven igniter that is not strong enough to fully open the gas valve yet just open it a little,letting gas accumalate in the oven then finally the igniter gets to full strenght and all the gas explodes. By replacing the igniter with a new strong one it will stop that.
The igniter is pretty easy to replace. Just remove the floor of the oven and the wing looking flame spreader, the screws that hold igniter to bake burner can be removed, and disconnect wiring.Then attach new igniter to burner reconnect wires and reinstall spreader and floor .
The part number for igniter is WB13K21 it could be purchased at your local appliance parts store or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
appliancepartspros.com
apdepot.com
I hope i have been able to help you fix your oven,
Gene
Aug 13, 2011 | Kenmore 30172 / 30174 / 30179 Gas Single...
Change chain and bar on model 235
It can be found on page 13 of your manual; about as clear as mud.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_5451676-63.pdf
Try my manual. much better; see page 16.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_1150154-95.pdf
If you are asking where to purchase a new bar and chain try here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Oregon part numbers are easily converted to other manufacturer's part numbers.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 30, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Kenmore oven doesnt bake
Can I assume that you determined that the bottom burner flame is burning properly? To do this, remove the oven bottom insert. The flames should have approximately 1" of blue cone and should burn with no yellowing tip, if on natural gas. (A small yellow tip on the end of the outer cone is normal with most LP gas.) The flmaes should not lift off the burner ports. If the flame is lifting, gradually reduce the air shutter until the flame stabilizes.
Go to the following website for your particular manual.
http://www.hammerwall.com/Manuals/Kenmore/Description/362.75585890/Kenmore%20Free%20Standing%20Gas%20Range%20Owners%20Manual/L0522834/
Feb 16, 2010 | Kenmore Ovens
Gas kenmore dryer
It could be a couple of things, but I would start with the flame sensor. Different models work differently.
Jan 03, 2010 | Kenmore 74962 Gas Dryer
Kenmore gas stove not coming out of pre- heat model 66575842001
This sounds like a flame sensor problem. No signal from sensor will shut down gas valve. Check flame sensor position in flame/or replace
Sep 02, 2009 | Kitchen Ranges
SPEED QUEEN MODEL AGS68AWF-- I'VE CLEANED ALL VENTS. NOT GETTING HEAT.DRYER CYCLES BUT GAS DOES NOT TURN ON. I'VE OPENED BOTTOM ACCESS PANEL AND NOTE THAT THE IGNITER GLOWS AND CYCLES BUT GAS DOES NOT...
If the glow bar is cycling off and on the glow bar works and the black box on the side of the vent are working, Either there is no gas to the dryer, doubltful but something to check or, You need a gas valve.
I would check for gas first, do you have other gas appliances? and all are functioning properly? Check the gas line and make sure someone hasnt accidently turned off the gas. If it is none of these you need a gas valve.
Go to repairclinic.com or partselect.com with your Sp Q model number, or the part number off the gas valve, it could be a five digit 58**** or 51***** number. Get you best price. Im guessing 80 to 100 Amercian
When replacing the gas valve, unplug the dryer first, turn off the gas, remove the front panel, two screws lower front panel, you will need a crescent wrench for gas line of side and a 5/16 nut driver remove wires. Now remove the orfice from the old gas valve and make sure you install it on the new valve. Is this a Natural Gas or LP Gas dryer?, If it is LP make sure you make the conversion to LP. Ask if you have more questions on this.
install gas valve, tighten gas line turn gas on check for leaks! with a bubble solution, start dryer and make sure dryer works properly.
best of luck
T
Jul 10, 2008 | Dryers
Grilling Logo
139 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
