Question about HP Designjet 110plus nr InkJet Printer
We have HP Designjet 110plus. Our magenta is flashing saying that it is out of ink, however it wasn't. We replaced it with a new cartridge, and it still reads empty. Please help!
  • HP Master
  • 4,737 Answers
Turn off the printer, disconnect and remove everything like power cable, usb cable, cartridges etc.. Connect your power chord and power on, leave it for few minutes (clean the cartridge interfaces not the head, and the corresponding interfaces on the printer). Again shut down the printer using the power button. Reconnect/reinsert everything, and again power on the printer before you connect the Usb to the computer. Now check if it helps or not. This will clear any static memory/voltage. Good luck Thanks for using FixYa.
Posted on Jun 01, 2010
HP Designjet 800 - Magenta cartridge
Check the expiration date in the ink menu of the printer
Mar 13, 2013 | HP DesignJet Office Equipment & Supplies
My HP Designjet T1100 says "Ink Cartridge Faulty Replace Ink Cartridge". But the cartridge in brand new. Any suggestions?
The most common cause I've seen is that when people put the new cartridge, they forget to remove the seal which makes the ink stay in the cartridge. It is typically a strip that covers the hole where the ink comes out, or else a strip that is located far from the hole, but that needs to get removed or else the ink will not flow from the cartridge
Feb 27, 2013 | HP Designjet T1100ps Printer
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
The "!" light is flashing; two of the print heads are flashing; I send a drawing to be printed; and nothing happens.
The flashing lights signal an error. If the printer started printing, please check for jammed paper. If it has not started to print, please remove the ink cartridges and then put them on again. They might just failed to be charged by the printer unit.
Feb 02, 2010 | HP Designjet 110plus nr InkJet Printer
Black ink cartridge show empty in ink system
Clean the Cartidge carrier (metel pcb dots) with ISO profie and fix..Othe wise replace the Cartridge.
Jul 10, 2009 | HP Designjet 110plus nr InkJet Printer
Our hp designjet 110plus is not printing black though the indicator shows we have black ink, what seems to be the problem? -Leh
Check whether the black cartridge is dry and whether it is releasing the ink properly.  This you can check by rubbing the paper on the place where the flows.
Else check with a new cartridge.  Even if the problem continues in the printer preferrence you have an option of service.  click on it and the problem will be fixed......!
Mar 13, 2009 | HP Designjet 110plus nr InkJet Printer
Printhead errors
sounds like a carridge issue , check that the carridge can move freely and theres nothing stopping it
Oct 27, 2008 | HP Designjet 110plus nr InkJet Printer
Printer Designjet 110 Plus not working
Ink supplies Description HP part number 11 Black Printhead C4810A 11 Cyan Printhead C4811A 11 Magenta Printhead C4812A 11 Yellow Printhead C4813A 10 Black Ink Cartridge C4844A 82 Cyan Ink Cartridge C4911A 82 Magenta Ink Cartridge C4912A 82 Yellow Ink Cartridge C4913A
alot of printers now if the ink in the cartidge is the first ones placed in the system from the box are those that are only half full if not less depending on the maker but I know HP only fills their cartidges only just under the half way make but the printer sees it as a new cartrige because of the chips programming.
Have you tryed to turn the power of and let is sit for about 5 mins and turn it back on with the same result? (ushally a yellow error light is on)
Also if you can find the settings to only print in black and white on the printers properties that might also work as well for a temp fix.
But ushally once one ink runs out it likes to do that you where correct with the "is it because of the finished color cartidges.." either that or the carts all have finally expired.
Nice printer by the way.
But your best way to do it would be to replace the color carts and if not reasonable to do now there is also a way to reset the color carts so that the printer thinks that there is ink in them as well.
hope this helps you a bit if you need more info please let us know.
Aug 02, 2008 | HP Designjet 110plus nr InkJet Printer
HP Designjet 110plus nr InkJet Printer Logo
444 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
