Question about Crown CE2000 2-Channel Amplifier
Crown CE1000 Hi Where can you get smt resistors.
    Genius:
  • 1,175 Answers
Www.mouser.com
www.digikey.com
www.jameco.com
Posted on Jul 30, 2009
  • 1,512 Answers
Hi Rodman55
If it is surface mount technology(device) resistors you require, they are available most everywhere electronics parts are sold. What values do you need.
You can get them direct world wide from Farnell Electronics But it may be a little work to sort the one you need. Best measure it up and go by dimensions to pin down the specific one you need. Good luck
regards
Graeme
Posted on Apr 09, 2008
SOURCE:
Clip led
That particular channel is blown. These are not the easiest units to repair. Given that this is a commercial amp, I would recommend that this unit be brought to an authorized Crown service center for repair. Expect parts cost in the $50 range plus the labor charge.
Dan
Apr 07, 2008 | Crown CE1000 2-Channel Amplifier
I NEED SCHEMATIC DIAGRAM OF CE1000
I think this is what you wanted.
Thanks,
gylacz
Dec 05, 2012 | Crown CE1000 2-Channel Amplifier
Fan running
Yes, many of the pro sound amps throttle the fan based on an internal temperature sensing device.
May 14, 2010 | Crown CE1000 2-Channel Amplifier
CROWN CE1000- slips into fault immediately after connection
if ur output power amp is defective u will have that problem - meaning the moment u connect load across it it will go into circuit protection to limit/stop excessive output current. make sure the speaker terminals are connected to +/- output terminals. in bridge mode use only channel 1 and that too with 4 ohms speaker only otherwise amp will clip. considering all connections are okay if it still clips when speaker is connected, u have a faulty power amp section. this the way ur amp is designed
Apr 05, 2010 | Crown CE1000 2-Channel Amplifier
Fan running
This is a very sophisticated amp and it will turn the fan on at various speeds when it feels the need for it. Of course, if it's running REALLY hot, going into thermal protection and/or posting a fault you might take a look at it to see if it CAN turn (no obstructions).
Mar 26, 2010 | Crown CE1000 2-Channel Amplifier
I have a Crown CE1000 power amplifier. I turned it on the other day and I seen a bright flash inside of it. Now the fault lights are blinking and it won't work. Is there something that I can look for or is...
Unfortunately Crown amps are not the easiest to repair as they utilize multiple levels of amplification. Since you saw a flash, a resistor probable smoked, I would recommend that you bring this to an authorized service center.
Dan
Mar 17, 2009 | Crown CE1000 2-Channel Amplifier
Crown CE1000
Hi waveybnc
The fan has failed, or is clagged up with dust. Remove it and clean it first. But best to just replace it. They are not that special and there is not alot that stops them from working. You can get a replacement device for the amp from Crown direct, or once you know its dimensions and power requirements, from here.
Thanks for using FixYa. Please rate my advice to you here as FixYa if it helps you.
regards
robotek
May 25, 2008 | Crown CE1000 2-Channel Amplifier
Crown CE1000
Cuold be the final power amp ic. Might be imput transistors to that channel. Its possible to have a cold solder joint on pcb.
Look close at board with good light and a mag. glass to see if any foggy looking joints and heat up with soldering iron then dab with fresh solder.
Good Luck
BigRED
Oct 20, 2007 | Crown CE1000 2-Channel Amplifier
Crown CE2000 2-Channel Amplifier Logo
113 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
