Question about RIM BlackBerry? Tour 9630 Smartphone
My ring tones have stopped working on my Blackbery
My ring tones have stopped working on my phone Blackbery 9630. I've double checked volume, profiles, battery removed and returned. Can't figure out what happened.
  • 903 Answers
There may be a setting that got adjusted somehow. Go into your Options (the wrench icon) and select "Sounds and Ringtones." Under "Ring Tone," there is a volume setting -- make sure it is not set to "Silent." Underneath that, there is a setting called "Play sound" -- make sure that's set to "Always"or "Out of holster."
Do other sounds work on your BlackBerry (such as music files, video clips, or alerts)?
Posted on Jun 03, 2010
  • jr_cox26 Sep 13, 2011
    i need to hear the phone ring also the messengers sound and that is nnot what i am hearing can someone help before i throw this phone out the window
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
Tip
BlackBerry Tour: How to make it ring and vibrate for incoming calls
You can customize your BlackBerry Tour so that either it rings when you get a phone call, or it vibrates -- or both. To make your phone both ring and vibrate when you get a call, go to your BlackBerry's sounds and ring tone options, which you can get to by either of the following two ways:
#1 - Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
#2 - On the main screen, press the BlackBerry button (the one with the seven dots) to take you to your Home folder. Scroll down to the Options folder (it's usually toward the bottom, and it has a wrench icon) and click on it, then select Sounds and Ring Tones.
From this scren you can select the ring tone that you want and adjust the ring tone volume. Then scroll down to Vibration and set it for On.
There is also an option for Vibrate with Ring Tone. If you turn this option on, the phone will both ring and vibrate at the same time when you get a call. If you turn it off, the phone will vibrate first, then ring. Either way, you'll get the ring and the vibration -- it's just a matter of whether they happen together or not. To see the difference between the two options, use the "Try it" option at the bottom of the screen.
When you've made the selections that you want, exit out of the options screen, but be sure to choose Save rather than Discard to save your changes.
on Jul 10, 2010 | RIM BlackBerry? Tour 9630 Smartphone
I have problem with my Nokia 2310 mobile phone.. it has very low sound of ring tone.. how can i increase the ringing sound
Dear Sir . Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step : Select Menu > Settings > Tone settings and from the available options: Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls. I hope this will works for you. Regards. Rizwan.
Mar 14, 2011 | Nokia 2310 Cellular Phone
My ring tone says high in settings but will only ring very quietly have tried loads of preinstalled tones but same prob can you help?
The phone speaker appears to be defective, you will need to purchase a new speaker for your BB, open the phone and replace the speaker.
Sep 22, 2010 | RIM BlackBerry? Tour 9630 Smartphone
The ringer of my phone is off. How do I turn it on?
flip open your phone -then increase volume with side ^ button...this toggles ringer on/off
no need to go into phone settings...
Aug 05, 2010 | Cell Phones
My phone will not ring out loud and vibrate at the same time.
To turn on a ringtone and vibration, go to your BlackBerry's sounds and ring tone options by either of the following ways:
1. Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
2. In the Home folder, go to your Options folder (usually toward the bottom, has a wrench icon) and select Sounds and Ring Tones.
Select the ring tone and volume that you want, and for Play Sound select Always. Scroll down to Vibration and set it for On.
There is an option for Vibrate with Ring Tone -- set that to on in order to make your phone both ring and vibrate at the same time, then save the settings when you cancel out, and you're all set.
Jun 21, 2010 | RIM BlackBerry? Tour 9630 Smartphone
How do you change ring tone for a text message on a blackberry tour 9630
Go to the sounds icon in the upper left corner of your main Home screen (the one that looks like a speaker with sound coming out of it). Scroll down the list that appears and select Set Ring Tones/Alerts. Click Messages, then SMS Text. Select the ring tone and volume that you want for text messages, as well as any other options (like vibrate) and then exit out and save your changes.
Jun 11, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Double ring tone issue
Go to the same place that you go to to put it on vibrate and scroll down to set ring tones/alerts and sms text and change the settings the volume should be set to silent.
Apr 20, 2010 | RIM BlackBerry? Tour 9630 Smartphone
How can I make the phone ring longer on my 9630?
go to menu
profile
general
ring volume
now set volume wat u like
i mean 1 2 3 4 5 which u need
ok ?
Oct 29, 2009 | RIM BlackBerry? Tour 9630 Smartphone
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
RIM BlackBerry? Tour 9630 Smartphone Logo
364 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
