Question about Bosch Classixx WFL 2066 Front Load Washer
Bosch clasixx6 noy heating water on any setting
    Sergeant:
  • 228 Answers
Need to replace wash heater remove front panel heater held in with one 10 mm nut easy to fit.
Posted on Jun 06, 2010
Washes indefinitely - water does not heat.
perhaps a call to a service man locally will be your best choice . none I have ever worked on had heating as an option .
Jun 02, 2015 | Bosch Washing Machines
Bosch classixx dishwasher not heating water on cooler wash works on hot wash
Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
Nov 30, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch aq 125 no water preasure
Clean water filter yearly or monthly. Page 16 example manual.
http://waterheatertimer.org/pdf/Bosch-125BO-NG-LP-outdoor.pdf
Shut off the installer supplied cold water supply valve.
Disconnect water pipe going to the back of the water
valve. Remove filter from back of water valve. Clean the
filter and inspect for damage. Replace if the filter is at all
damaged. Inspect the top of the water valve for signs of
a water leak or corrosion. If present, rebuild the water
valve.
Bosch service bulletins:
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/38b-125-series-bulletins.html
Descale heat exchanger yearly.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
Sep 29, 2012 | Bosch Water Heaters AquaStar 125 series...
Cannot find pilot light on my bosch GWH635ESL, help!
Call Bosch
Gas Products Technical Support: 800-642-3111
That model number is only shown at one website, and that model number is not shown at Bosch.
Open following link for Bosch:
http://www.boschwaterheater.com/BoschHotWatercomHome/GasProducts/tabid/331/Default.aspx
Search of Bosch for that model number shows no result.
Some water heaters do not have a pilot light. Instead they use hot surface igniter rod that glows red hot
The igniter rod ignites the gas after solenoid valve opens and gas flows to combustion chamber.
The igniter rod and heat sensor have to be operational, and have to be positioned correctly for ignition to take place.
If igniter rod is not working, or if heat sensor does not detect flame, then gas solenoid valve shuts down and water heater does not heat water.
Sep 03, 2011 | Bosch Water Heaters AquaStar - Tankless...
What does a thermometer symbol with up arrow mean on an shx68
Hello Jsg5,
That symbol means that the dishwasher is heating the water, bringing it up to the required temperature to properly sanitize your dishes.
This symbol can appear during the wash and rinse cycles. It is nothing to worry about. Most dishwasher will heat up the wash and rinse water, it's just that Bosch decided to add an indicator, so users would know that any delay in the wash/rinse cycle, is a result of getting the water up to the proper temperature (typically around 140 degrees F)
Even if you've got your hot water heater or hot water supply set to a very low temperature, the dishwasher will use the built-in heating element (the drying element in the bottom of the dishwasher) to heat the water.
Hope you find this Very Helpful and best regards!
Dec 10, 2009 | Bosch Integra 800 SHX68M0xUC Dishwasher
No hot water
The machine will only take water from the hot tap when it is set to a 95degree wash, it will heat the water on all other cycles itself. apparently an energy saving feature.
May 01, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Once hot water is open the gas is burning and water is not heated
Sounds like the flow is too high and or the temp set too low.
Apr 01, 2009 | Bosch Water Heaters
Bosch 1600h NG not heating water hot enough
it sounds to me like the dip tube has failed. this is a plastic tube that is inside the water heater on the cold side. It is designed to put the incoming cold water at the bottem of the tank allowing heated water out at the top. when this tube deteriorates the cold water mixes at the top of the tank instead of the bottom. a new dip tube is about 5 bucks but must be inserted on the cold side by someone with plumbing experience.
Jan 08, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch Classixx WFL 2066 Front Load Washer Logo
73 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
