I have a bush wd 1000 txve washer drier and the drier wont work keeps coming up with e13
  • 327 Answers
Hello,the E-13 error code is a drain timeout code. This means the pump has run a certain amount of time without fully draining itself. This could be anything from a clogged drain line in your home to a clogged drain line in the machine, your pump is clogged, pump is burned up, no power to the pump, bad board etc. Most of the time its either something jammed in the pump, or its burned up (from something being jammed in it). Just have to take her apart to find out for sure.
Thanks
Posted on Jun 02, 2010
Hoover washer dryer wd 9616c error code e13 and burning smell from the rear????
The automatically suggestted E13 guidance that the system posts referring to Bosch machines is irrelevant I'm afraid. On a Hoover, the message means "Faulty module connections. Check all connections between modules and associated wiring." The chances are that you have a partially dislodged connector on the main board, or on the connector that goes to the motor
Oct 14, 2015 | Hoover Washing Machines
How can I fix my washer when it stops with an E13
E13 indicates your input voltage is to high
also can happen with faulty motor/ brushes
Jan 31, 2015 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I have a smeg washer drier wdi 146 with error code e13. Can you tell me what the problem might be. Thanks
i beleve your door interlock is fautly
or the wiring too it can overheat and cook
so youll need a new one from smeg uk
and check out the connector for any issues
see here for some details
although its a different model i would assume the company uses the same error code setup for all its models
and i would order direct from smeg
http://www.ukwhitegoods.co.uk/forumsphpbb3/washing-machine-forum/error-code-e13-smeg-wdi12c6-washer-dryer-t75513.html
Dec 20, 2014 | Washing Machines
What is error code e13
Good Afternoon Friend,
I understand that you are receiving an E13 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E13 means, as well as assist in clearing it. Hope this is helpful.
-Best Regards-
WP
May 31, 2014 | Electrolux EW1000i Front Load Washer
Hoover Aquarius Washer Drier WD 440 Washing machine worked fine yesterday but today is tripping out and blowing everything in the house. Also washing inside the machine was very hot and water not drained...
sounds like the bushes have gone in the motor... about £20 from your local appliance retailer/parts department! or the filter may be blocked... clear the filter but it will get messy so have towels at the ready a hosepipe would come in handy or move it outside if you feeling strong!!
to check the bushes locate the motor not sure of position on these but near to the bottom you will see wires going to plastic parts each side normaly held in by a screew, take a wire off each plug in and see if it runs...
hope this helps
Aug 30, 2011 | Hotpoint Aquarius WD63 Front Load...
I have a bush wd 1000 txve with error code unb and wont spin. What does this mean?
'unb' is likely to stand for 'unbalanced' and spinning shows any problem with balance the most!
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Mar 22, 2011 | Washing Machines
E13 and clothes are trapped
try setting the knob to the stop position, turn off the power and pull out the plug and wait for 2 mins and it should open.
Sep 18, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
GTS1000 -93 noise from back of motorcycle
Check you spring, use lube grease with a grease gun to lube it NOT WD-40 like most people would do it will only hide th noise for about 1-2 days of riding. If spring is good change out the bushings at the ends of bushing for spring.
Jun 22, 2009 | 1997 Yamaha GTS 1000 ABS
Zanussi washer drier 1480W door lock
Zanussi's always keep clicking before starting.I don't know what E60 is about,but I take it the machine is working?
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
712 people viewed this question
Top Washing Machines Experts
