Question about Sony Cyber-Shot DSC-S500 Digital Camera
Help ME!!! When I Go To Shoot A picture I Doesn't Take It. I Tried This With Plenty Of Different Memory Cards And None Of Them Work? It Just Makes This Beeping Sound When I Try To Shoot
    New Friend:
Same problem in my camera..any help?
Posted on Nov 08, 2011
Up at the top of the camera there is a little pin wheel thing, right, now turn the wheel to the green camera on the pin wheel. Now take the pic, then go to the icon below the green camera and see if ur pic came out.
Posted on Apr 09, 2008
6ya staff
SOURCE:
Clarion Max960HD won't read SD card
Just to be clear, you tried SD cards, 2GB or smaller? The unit won't work with higher-capacity SDHC cards.
May 16, 2013 | Clarion Car Audio & Video
Why does my camera say card error?
You probably need a Card Reader to access the Cards on your PC if you are trying to transfer pictures from Card.
Regards,
Suhail
May 16, 2012 | JVC Everio HD Camcorder with Dual Memory...
While taking pictures my camera all of a sudden froze and said card error, tried putting memory card on computer but it won't read it have tried using recovery programs but it freezes them please help
If your memory card is 4GB or larger, AND if your computer is two or more years old, your computer's card reader might not be able to read the newer 4GB SDHC card. In that case, just purchase an inexpensive USB card reader from WMart, or Amazon (here's an example). Try a different card reader first to see if you can directly copy and paste the pictures from the card onto your hard drive. If the new card reader doesn't see the files, then try recovery software. Here's some freeware to try. If the software still doesn't see the card with the new card reader, you may next need to try the corrupted card procedures described at the bottom of this linked article.
Nov 26, 2011 | PNY 4GB Secure Digital High Capacity...
Samsung L700 memory card not working prints r not avialable 1 2 5 i wanna jumpers of samsung l 700 memory card
Although no memory card specifications (except that it should be SD or SDHC or MMC card) is listed in the PDF manual, the problem most probably is that your card might be incompatible (I've personally experienced card's incompatibility with other digital cameras):
1) Borrow different SD or SDHC cards from your friends and try on your camera.
1) Check cards of different speed classes (number 2, 4, 8 or 10 inside a circle on the card): Normally if you have smaller SD cards (up to 2GB), it might suffice that card's speed class is 2. If you have larger SDHC cards (4GB and more), your camera might require a speed class of 4 or more. Or it may also happen that your card is too fast/big - some older devices don't work with too modern SD/SDHC cards. Read more about SD card speed classes>>
2) Check cards of different sizes. Some cameras my not work with too small or too large size cards.
3) There are plenty of fake SD/SDHC cards on ebay (mostly from China, with unidentified manufacturers/brands) which don't work with many devices and cause many errors. If there's a size and speed class written on such fake card - don't trust these numbers, they are probably fake.
3) If none of the different memory cards work - bring your camera to the mechanic
However, these requirements may vary from camera to camera. So ask about your Samsung L700 camera directly at Samsung customer support form>>
There are several websites where you can match your camera with compatible SD/SDHC cards:
Mar 05, 2011 | Cameras
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
I was changing the memory card and the second memory card will not go fully into the slot. i have tried to insert other memory cards but none will fully slot in.
Two different memory card slots is a feature normally found on professional cameras. Anyway I'm including a picture and the only thing I can think of is that the card is the wrong way around. There are very small guides along the side that will forbid it from loading backwards. Problem is if you force it you could damage the guides OR the pins at the bottom, take a look at the picture. Robert in Canada
Dec 14, 2010 | Fuji Finepix S9600 Digital Camera
Canon EOS 40D shoots on its own.
Sounds like a software issue, try to upgrade or reload the firmware.
I hope it helps :)
Oct 26, 2008 | Canon EOS 40D Digital Camera
I have a Canon pixma MP 450 all in one, it all works fine except the card slots. I have bought 2 addaptors but none of them work can you help me sort this out Thanks, MY email address is,...
Memory Cards
The MP610 can read from SD Memory, SDHC, MultiMediaCard, miniSD, RS-MMC, microSD, CompactFlash and Microdrive, Memory Stick, Memory Stick PRO, Memory Stick Duo, Memory Stick PRO Duo and xD-Picture cards.
Cards will the slots will appear as removable drives on your computer.
Oct 02, 2008 | Canon Office Equipment & Supplies
"No Memory Card" error.
PLEASE can anyone help. I have the same problem too and I'm about to go on vacation. I need this camera to work. Please help.
Oct 05, 2007 | Canon PowerShot SD1000 Digital Camera
Sony Cyber-Shot DSC-S500 Digital Camera Logo
54 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
