Question about Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher
Controls not working, but panel is
The control panel has been replaced 2 times, i believe the board is bad
  • 523 Answers
Touch pad
Posted on Jun 01, 2010
Part of treadmill buttons won't work?
Remove the control panel and try to clan the board using isopropyl alcohol using a brush. Leave the board for one day so that it would get dry. Then install the control board back and check and check it. Sometime moisture acclimated on the control panel can cause such problems . If you didn't get isopropyl alcohol then put the control board in sunlight for one or two days. Then install the control panel and check whether it works or not. also try to replace all the switches on control panel board. you will get it in any electronic spare parts shop.Beside not to put it on direct sunlight it can cause problems to the display
If you wish to get some more details about treadmill repair and service then check the following link.
http://electro-medical.blogspot.com/
Aug 20, 2016 | HEALTHRIDER T650I Treadmill Front Roller...
What does "Firmware Rev B 13" n on indoor control panel? Help! Robert
The firmware message is the firmware on the wall mount control. The wall control would seem to be getting power, giving you the firmware rev only. Your communication with the main board has been lost, broken wire, main board has gone bad or for some other reason can not receive and instruction from the main board. If you have a spa side control, if spa side works then board may be ok, look for bad wire. If spa side is not working disconnect and power cycle the system and try the wall mount with spa disconnected. You may only need to replace the main board. More info on your system would be needed in order to suggest the proper replacement.
Sep 04, 2014 | Pool & Spa
I am getting F 1 on my control panel. Have unpluged it 2 times DCF3305BT 0201421915
The F1 on this Amana model indicates a bad control/clock. If disconnecting the power did not work then the electronic circuit board control would need replaced.
Jun 14, 2010 | Amana Kitchen Ranges
Turned on my plasma yesterday and only 1/2 of the screan was showing picture. the other 1/2 was black
Plasmas have two boards that are Y boards i believe...one of the boards is out that controls the half that is not working...ebay a board...plug it in and you'll be up and running....you'll know which one is bad because a little square will be dis-colored or burnt
Feb 26, 2010 | LG Televison & Video
Food defrosted in freezer--turned to coldest setting--there is some cold air coming in but seems only small amount-refrigerator is only "cool"-fan seems to be working
I believe part number W10135899 Defrost Control Board is defective. The board is located inside the fresh food section and behind the control panel. Near the temperature controls. Look at the rear wall of the freezer. If a layer of ice is forming on the rear wall of your freezer then it also is forming behind the rear panel of the freezer and restricting air flow. The Defrost Control Board is the most likely reason then there are 2 more things to have a look at. That is the defrost heater and the defrost thermostat. Would not be a bad time to manually defrost your freezer so you can bring temperatures down and replace the part. Unplug refrigerator, remove the rear panel inside back of freezer and defrost the evaporator coils with a hair dryer Or you can leave a bucket of hat water setting inside the freezer compartment with door shut for a while. Let me know what you find, again most like problem is the Defrost Control Board, Thanks, Sea Breeze
Sep 20, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Dishwasher acts like it isn't getting power.
If you have power to the board and no power out to components then your board has failed. Will need to replace board. Part#154635501 and sugg retail is about$100.
Jun 09, 2009 | Dishwashers
Dryer has power, dim control leds, will not run most of the time.
Same problem here. I replaced the machine control electronics p/n 8546219 and got 12 months service out of it before it returned to what you are describing above. I even replaced all the LED's on the board and that did not do a thing. I can tell you that this will be the last whirlpool appliance that will ever enter my home. Simply overpriced garbage!
Jun 06, 2009 | Whirlpool GEW9250 Electric Dryer
Model mdb7601awb diswasher . Nothing works , no buttons torn on or work when pushed, no action. 1.Have checked power to unit and is ok 2.checked door switches (2) and both work properly. 3. no visual...
I have had the board replaced 5 times and the entire dishwasher replaced once. It was necessary to go to the state attorney general to get Maytag to extend the warranty. Just called the service center for the sixth time, after this the warranty will be gone and will replace with something well built.
May 12, 2009 | Maytag 24 in. MDB7601AWS Stainless Steel...
GE Fridge #GSS25LGMBWW water and ice control panel not working
Your dispensor board , has lost communication to the main control board . You will need to replace the board , which is located behind the refrig , behind the 8 " X 10 " , small panel . The pt # is WR55X10942 . You do NOT need to replace the board on the dispensor . The board behind the refrig , is , easily replaceable .
Apr 01, 2009 | GE GSS25LGM Side by Side Refrigerator
GE Spacemeker Microwave Oven xl1800
The Control Panel is failing. The Control Panel consists of a Keypad, and a Control PC (Printed Citcuit) Board. You can replace it as a complete unit. Not Cheap!!
Good Luck!
Feb 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Logo
160 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
