Question about Frigidaire FAC125P1A Window Air Conditioner
Fridgidair sleeve ac unit model # fah126j212...fan stops working after 15 min run time
3 Suggested Answers
  • 7 Answers
SOURCE: Where is Fridgidaire serial number -air conditioner
If you remove the outer cover and look inside there should be sticker with the serial # on it
Posted on Jan 29, 2010
Testimonial: "This was helpful, butI'm still confused. The respnonse was quick."
  • 185 Answers
SOURCE: I need the serial number for my Fridgidaire FAM186R2A AC
Yes the front cover is the same as the grille.
You should see the plate with the serioal and model number on the chasis after you remove the grille.
Good luck.
Posted on Jan 30, 2010
Testimonial: "I have not been able to test the advice given, but it seems correct, professional and timely."
YORK OUTSIDE UNIT MODEL # HP036X1021A
You must change the fan motor or you will have more problems
with car temperature!
May 09, 2014 | Canvas Dipped York Brief - Grey
Ask com lg ac window unit control panel stopped working
Hi Gina, Try turning off the unit at the electrical panel. turn off switch, wait 15 min. turn switch back to on position. Turn on AC unit. Hope this helps.
Oct 21, 2013 | Heating & Cooling
AC Problems & Melted Overflow Tank
Trust you mech on this one.
Jul 09, 2012 | 1999 Acura TL
Good luck.
Jan 30, 2010 | Frigidaire FAL126L1A Air Conditioner
My outside unit runs a little while then shuts off.
More likely the out door fan motor has bad bearings and that would cause the out door unit to run for 15 to 20 min but it could be low on freon
when the out door unit runs after 3 to 5 min the larger of the two copper lines going into the unit should be ice cold
If the thermostat you just installed has a time delay that will keep the indoor blower motor running for up to 5 min after the unit shuts off
Sep 01, 2009 | Honeywell Heating & Cooling
The fan stops running
check whether the power saver mode is on. put it off. or some timer must be on. stop the times. it wll be rectified
Jul 27, 2009 | Heating & Cooling
Stops cooling after a few mins
Check the condenser fan motor It probley has bad bearings and over heats and shuts down
after 15 or 20 min of run time
Jul 25, 2009 | Heating & Cooling
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
AC Problems
1 and 2 there two type of motor 1 has lubricating acces this youshould lubicate the other no noacces. but commonly if you lubricate and still noisy you change the bearings qty2 or sleeves qty2
2- common cause of ice
- thermostat on min setting
- thermostat defective
-air filter is very dirty
-evaporator is cloged no air pass throu
- loss of freon ( a/c is leaking)
Apr 30, 2009 | Friedrich CP06C10 Wall/Window Air...
Heating & Cooling Logo
82 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
