Home | Ecoquest | Living Air Classic Air Purifier | Xl15 sparking
Ecoquest Living Air Classic Air Purifier
Problem for Ecoquest Living Air Classic Air Purifier
Xl15 sparking
By jeffk58 on Apr 09, 2008
when i turn on my alpine xl15 it will spark at the plates,at the top.
i have cleaned and changed plates.
thx's jeff
Same Problem
Jun 04, 2008
-   I have the same problem I cracked the glass plate and it started sparking. so I bought the new ceramic plates and it sparks from the metal on the plate to the top of the bracket, it only does it when it is turned on above 2/3 power. -   kah92340
Solution #1
posted on Apr 04, 2009
Not Rated)
gototech
Rank: Wiz
Rating: 91%, 24 votes
Clean the contacts that touch the plates with Qtips and 70% or higher isopropyl alcohol and replace the plates. Sparking on the plates usually is a sign of a crack in the plate. The electricity is passing through the plate, creating an arc. The crack may be invisible to the naked eye.
Was this helpful?
Yes
No
Popular Solutions for Ecoquest Living Air Classic
Questions and Unsolved Problems for Ecoquest Living Air Classic
Do you recommend Ecoquest Living Air Classic Air Purifier?
Answer
Answer
no high voltage to grid after 5 minutes operation
Answer
Appears that the high volatge supply has failed. Neither lamp (inside) is illuminated consiquentlky... (More)
Answer
the ozone only comes on at the highest setting. It is to strong to have it on that level. What is... (More)
Answer
Not producing ozone, wire on little round sensor is broken on the small silicned in circuit board... (More)
Answer
The internal light is on but the machine is not cleaning the air. Just blowing the air around.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ecoquest Living Air Classic...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
