Question about Whirlpool Calypso GVW9959K Top Load Washer
The water will not spin out and the digital display display FL and beeps. What is the problem? It's in a house where it hasn't been used for a couple of years but seems to be fine.
  • 15,935 Answers
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
GETTING AN ERROR MESSAGE OF FL, WHAT DOES THIS MEAN?
This means that your Washer has somehow Over Filled with water and will "FL"ood if it does not drain the excess water:
It should also be beeping every 10 seconds and the pump should start to empty some water to rectify the issue.
Restart the machine machine as required or push the overfill reset switch.
To avoid flooding, you might need to temporarily shut the water supply if water continues to flow in the machine while the "FL" code is displayed.
Hope it helps let me know how you go.
Sep 28, 2010 | Kenmore Elite 21082
I get an "fl" indicator. The pump runs for while then stops and beeps - this repeats.
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&#@^
May 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool cabrio washing machine
FL error code generally means 'flood condition' which is telling you the machine is overfilling with water with water.
Try pressing STOP/CANCEL to clear the display.
If the condition persists the water fill valve or sensor may be faulty and may need replacement.
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My kenmore elite calypso washing lights on the front panel will not light up.i push the choice i want then it reads FL and all it does is hum and beep.even when off it will beep and read FL.i will turn it...
Flood Condition:
Oct 15, 2009 | Kenmore Washing Machines
MY WASHER IS BEEP AND DISPLAY FL
FL means flood condition
Solution: "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for "FL" to be displayed
Jul 16, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
GOING NUTS WITH WASHER
FL Flood condition"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. You will need to unplug this unit for 5 minutes. if you continue to hear beeps and the (FL) appears once more after the shut down, you will need to replace the water level switch.
Press STOP/CANCEL to clear the display and unplug the unit for 5 minutes.
Apr 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Cycle Problem
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#%!^
Mar 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL SIGN AND BEEPING, AND THE WATER WON'T DRAIN.
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
This is not the same washer but all the parts are the same. Please check here for a more detailed appoarch to this problem. Click Here
Feb 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
