Question about Refrigerators
Hi My freezer is working great however my refridgerator side seems to be a tad warm, I have tried to clean the compressor and even turn it to cooler settings , this unit is only 1 year old
  • 4,059 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on Jun 01, 2010
Refridgerator is not cooling and the freezer not freezing. The cooling fan does run but it seems the compressor does not turn on. I'm wanting to test the capacitor to see if that could be the problem...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Kenmore Side by Side Refrigerator
KSRP25FNSS Refridgerator Both refrigerator and freezer are not cooloing Lights come on when door is opened I tried to turn on the cooling, but nothing happens - nothing lights up. Is there a fuse for...
heatman101
Jun 11, 2011 | KitchenAid KSRP25FNSS Side by Side...
GE (PSS26SGPASS) Side by Side Refrigerator has been tripping circuit breaker. The compressor is very hot but seems to be functioning properly since the freezer is at 14 degrees and refridgerator side is...
heatman101
May 26, 2011 | GE Refrigerators
MY GE GSL25JFPA-BS SIDE BY SIDE REFRIDGERATORS FREEZER TOP PORTION IS NOT COOLING
heatman101
May 09, 2011 | GE GSH25JFR Side by Side Refrigerator
I have a frigidaire side by side refridgerator / freezer. Currently my freezer is about 34 to 40 degrees. The dividing wall between the ref. and freezer is warm to hot depending on when you check it. ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
May 03, 2011 | Frigidaire FRS26H5AS Side by Side...
My KitchenAid side by side refridgerator has stopped making ice and there is water running down the door of the freezer compartment that freezes all down the inside of the door. Even after turning the ice...
heatman101
Apr 21, 2011 | KitchenAid KSRG25FKSS Side by Side...
The refridgerator and freezer are failing to maintain temperatures. The light for the refridgerator temp. is blinking constantly. Both sides continue to raise in temp. regardless of where the setting is...
heatman101
Apr 17, 2011 | Samsung RS2630SH Side by Side Refrigerator
I have a KitchenAid KSRS251 side-by-side refridgerator that is clicking every couple of minutes and the you can hear an motor or something run for a few seconds. The freezer is defrosting and I think...
heatman101
Mar 18, 2011 | KitchenAid Superba KSRG25FK Side by Side...
My Refridgerator/freezer is not working
Sounds as if the compressor is not running even tho the fans are. The overload relays on the side of the compressor are usually the source of this problem. They are on the side of the compressor and if you change these out you should be fine. Fairly easy to do as it should just be a plug connecting it. Hope this helps.
Feb 21, 2010 | Maytag MTB1953HE Top Freezer Refrigerator
Not cooling. Light works on the inside, but both the freezer and refridgerator side stopped cooling. Fan turns on - not cold. Lost all food inside.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
eq45tgn
Dec 15, 2009 | KitchenAid KSCS25FKSS Side by Side...
Refrigerators Logo
105 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
