Question about Dometic Rooftop RV Air Conditioner
The RV i'm working on has 2 roof units,both start to cool then comp cuts off , there is 1 thermostat with dual zones,its on a 2006 motor home,it dorsn't seem like both would be bad
  • Dometic Master
  • 6,674 Answers
Can you get 1 to run good at a time, or does same happen when 1 only is run? Some RV's have an energy management system incorporated, that cuts power back to certain appliances when necessary. There were/are some units (RV's) that needed to be plugged in as well as generator running in order to run 2 AC units at same time. Let me know.
Posted on Jun 24, 2010
I have 2 air conditioners on my Hampton trailer. I can't get my furnance to kick on. I have a R V Comfort .ZC duel control thermostat with zone 1 ,liveing room, and -Zone 2 ,bedroom, zone 2 will say gas...
I need to know what the furnace is doing .
Since you said furnace that's means force hot air and you have 2 Zone damper that's runs on 1 furnace ,correct?
If it's 1 furnace with 2 Zone is Zone 1 working
May 31, 2017 | Coleman Rv Air Conditioner Control Box...
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
A/c will not continue to cool.. Starts fine, runs fine.. but shuts down cooling ( comp shuts off but fan still runs) after anywhere from 5 min to multiple hours. No circuit breakers or fuses blow. CAN...
One amateur test is to place your hand on the compressor and see if it
is too hot to hold your hand on it. You may have a restricted condenser coil
If it is too hot then the condenser coil is restricted inside the unit
if not be sure and clean condenser coils with good coil cleaner.
You can put a fan on the compressor and see if it runs for another test to confirm it
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 22, 2010 | Dometic Rooftop RV Air Conditioner
13.5 Dometic rooftop rv ac design has changed since I purchased 2006 Monaco Camelot rv. The collection cups leading to the drain line do not fit well on the roof seal and a good seal is hard to achieve. If...
I've not run into the problem your having yet, so I will apologize up front for asking you to furnish more information. These drain cups that I assume are little round pieces attached to the base of the unit where it meets the roof, were not common on dometic, but were common on Coleman AC units. Those are the outlets for condensation to the roof anyway, are they not?
Also, as far as gasket goes, no I wouldn't recommend using 2. We were always advised by manufacturer to compress gasket to half the original thickness when installing either Dometic, or Coleman (RV Products). Coleman at one time, had tabs under gasket that when gasket was compressed, and they touched the roof surface inside, that was far enough, which was approximately half the original thickness. Believe it or not, over-tightening is more likely to cause a leak. Stick with half original thickness, or close to it.
Jun 26, 2010 | Dometic Rooftop RV Air Conditioner
I have a 2003 HR Endeavor with 2 roof ubits. The front unit will cool and heat but the rear unit will not come on. The thermostat will not cycle to zone 2. Any suggestions?
Try resetting the thermostat. If you have the 5 button comfort control, turn the thermostat off. While holding down the mode and zone buttons, turn the tstat back on and hold the buttons until FF appears in the display. Release the buttons and then see if zone 2 is available. If not, remove the inner cover off the front air and remove the cover off the control box. Inside this box there are DIP switches (red stripe with white switches). Set the one for zone 2 to off and then reset the tstat as described above. Turn zone 2 back on and once again reset. If this does not work, you more than likely have a bad control board in the front unit as this is the one that controls all that.
Hope this helps,
Jeff
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Thermostat shows error on unused zone
You will need to take the inside cover down on the front air conditioner. There is a control box mounted there, open the control box and you should see many dip switches on the face of the board. Make sure that Zone 1 and Zone 2 are selected (furnace as well if your furnace is fed through this thermostat). After making sure that the switches are set, turn off the thermostat and hold down the mode and zone buttons at the same time, turn the tstat back on. When EE appears on the face, release the buttons and see if everything works. If not, then I would say that you have a bad control unit in the air conditioner.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Goodman with 2 thermostats, freezes in summer, no heat in winter
is the system zoned? if so maybe the zoning control board to the damper motor is wired improperly. when a system freezez its because of 1- restricted air flow across coil, (maybe dirty filter) or 2-low refrigerant charge. again could depend on how its zoned.
Feb 16, 2009 | Goodman PHKJ048-1 Air Conditioner
Penguin a/c
the multiple zone thermostat should work fine but sounds like this one has an internal failure try replacing the thermostat
Jun 21, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
127 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
