Question about Pool & Spa
My hottub want raise the temp above 89 on the control panel it says sl 89 i know it has three modes sleep mode econo and standard but how do i change the modes? the tub is a nordi sport
    Habit-Forming:
  • 77 Answers
Some hot tub keypads have a 'mode' button. If yours doesn't try pressing 'warm/temp' followed by 'Jets'..... it's usually a combination of keys that changes the mode and this one springs to mind but I could be wrong.
Good luck,
Ian, from: http://hottub.synthasite.com
Posted on Jun 18, 2010
My Dream maker Odyssey spa is stuck on economy mode. There is no way for me to see to change it to standard mode.
Try pressing 'TEMP' then 'LIGHT'. You may have to do this a couple of times.
If you don't have a 'TEMP' button, either the temperature up or down will also work.
There are three modes, ECONOMY (EC / ECO / ECON), SLEEP (SL / SLP) and STANDARD (ST / STD). For everyday use keep it on STANDARD mode.
Cheers,
Ian Kime
Ian Kime Hot Tub Sales Repairs and Servicing
May 02, 2017 | Standard Pool & Spa
Tub won't heat Message SL
Not much info here but SL could be the mode setting. Typically modes are SLEEP, ECONOMY and STANDARD. Standard maintains your set temp at all times even if it has to turn on outside of normal filtration cycle. Economy only heats during a filtration cycle, and sleep will only heat within 10 degrees of set temp and only in filtration cycle. This cycle is really only useful while going on vacation or other extended periods of non-use. Not sure how to help change modes without knowing what spa pack you have but you should be able to find the owners manual on line with a little research.
Mar 02, 2017 | Pool & Spa
Dream maker spaX400. has a green spa control panel keeps flashing SL. I tried setting it to F2can't get it to stay thereIt keeps going back to SL can change the temperature up down temp ofstays at 91
It is in sleep mode. Press your mode button until it says sp again then hit temp up button or whatever button you use to change the f1 f2 f4 messages.. it should change to SD or ST or SN for standard mode...
May 06, 2015 | Pool & Spa
I have an EC display on my panel
That means your "Heating" mode is in Economy! Without knowing what make our model spa you have, or the manufacturer of spa controls, difficult to assist in telling you how to switch to other modes. Maybe try this:
Pressing the "Temperature" button and then immediately the "Light/Jets" button may change the system back to Standard? Once you press those buttons, the "Ec" code comes on and stays on (flashing), and then you can press the "Light/Jets" button to toggle between Standard and Economy and maybe SL - which is Sleep modes.
Good luck
Feb 22, 2015 | Pool & Spa
The instrumentation panel says "SL" and the spa isn't heating.How do I get it to heat again?
You have it in "Sleep" mode. Spa will not heat normally in this mode...
If the SL Message is Alternating with the Water Temp in the Display Screen (we call this "Flashing Sleep"), the Spa is Operating in the Sleep Heating Mode.
If the SL Message is ON Solid (Not Flashing) in the Display window of the panel, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
SL or SLP is one of the Modes you can program your spa into:
EC - Economy
ST/Std - Standard
SL/SLP - Sleep
It is advised you keep your spa in Standard mode. Push the Jets button then immediately push the light button. Each press of the light button will scroll between these three modes.
Good Luck
Aug 27, 2013 | Balboa Instruments Duplex Digital Panel 2...
My viking spa is in sl mode and not heating
It is in sleep mode, press the "temp" button then the "light" button, to change modes, ST will be your standard mode.
Apr 03, 2013 | Pool & Spa
Hot tub stuck in 'SL' mode
Need to know what buttons your topside control has... depending on the model, some have a mode button which you press and release and then immediately press the temp up or down, to select SL for sleep (no heat), ST for standard (heat as needed) or EC for Economy (only heat during filtration). If the mode button is not present, and you have a single temp button and light button, try pressing and releasing temp and then immediately pressing light button, repeat until choice appears, then wait, it will hold last displayed mode.
Jul 09, 2010 | Jacuzzi Balboa R574 System for 1 2 Speed...
Had a new heater element installed. won't go
You need to put the system into 'ST' mode. 'SL' stands for 'Sleep' and will prevent your spa from heating.
'Regards,
Ian.
Feb 24, 2010 | Sys BALBOA SUV SYS 5.5kW W/ 120V 1.OHP...
How to Get Hot tub off sleep mode
press temp button and then the light button in sequence.
Nov 14, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
OC hot tub is getting SL error and does not heat. Model is M-09-MOC1545-3. Recently purchased and lost manual. Thanks.
sl means sleep mode and will not heat! try depressing the temp button the either the light button or the jet button usually that will change modes u want st or std mode which means standard. or if u have a mode button try that 1st. or email me a copy of control head to hottubbob2@aol.com for tips! thanks Bob
Oct 17, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Pool & Spa Logo
352 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
