Question about Blenders
After starting the microwave, I get a "F-7" message on the display and it shuts down. What can I do to fix this? This is a whirlpool model # GH5184XPS-4.
    Genius:
  • 1,416 Answers
what this error means indicate is as follow
The F-7 error code indicates that the water or oil (any liquid form) temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
what you need to do to fix up your is to do general cleaning up on your oven both internal and external do this with care and allow it to dry up it self.
please when doing this you will have to put off any form of power supply connected to the oven .
thank you and thanks for using fixya.
Posted on Jun 01, 2010
Blender overheated
If it won't run once it has cooled down, you have probably cooked the electric motor, which is not worth trying to fix.
If you have some time to poke around, it is vaguely possible that a switch has burnt out, which can be fixed/cleaned. Another longshot is a burnt out fuse, but I doubt it has one.
Jul 22, 2012 | Oster Fusion 7-Speed Food...
MODEL #K0936 INTELI CHEF WHERE CAN I GET IT FIXED
It is contaminated. It will probably be a lot more economical to replace it.
Feb 06, 2012 | Cook's Essentials CEM848 Handheld Blender
Kenmore range model 93751 stove door will not come on looked and is showing an f9 err code
microwave has a cracked inverter board and that is why it posts an F-9 code.
Jan 25, 2011 | Kenmore Blenders
My K-Tec Champ HP3 is overloading and shutting off after about 5 seconds even with the jar empty or not even on the machine. It just starts up and shuts off (displaying "OVERLOAD" on the...
Remove the 2 screws from the bottom of the base, release the 4 clips on each side and remove the bottom cover.
There is a fan blade attached to the bottom of the motor and a sensor on the side of it that senses the fan blade turning. If the sensor does not sense the fan blade turning, it assumes that the motor is locked up or 'overloaded'.
Check that the fan blade has not come loose from the motor shaft and reattach if necessary. Verify that the sensor is secure in it's housing next to the fan blade.
Reinstall the base cover and verify operation.
Jan 24, 2011 | K-Tec Champ HP3 Work Top Blender
The coleman rechargable blender not blending
Subject: Rechargeable Portable Blender Model No. 850-870
I was given one of these blenders for Christmas. I charged it through 3
cycles, used it once and the battery was dead. Charged it through another 5
charge cycles and used it once only to then have another dead battery. I
have put it through at least another 8 charge cycles, and it indicates a
DEAD battery. I have managed to blend two (2) 3/4 full pitchers in total. On
trying to start it now the green light 'flickers' quickly on and shuts down.
This is a totally useless device.
I would like to return it for a full refund, including shipping.
Dec 21, 2009 | Coleman 850-870 Single-Speed Blender
Oster kitchen center 5500-08a
I have not seen this problem with ours yet but if turning up the speed doesn't help (first thought would be the motor's overloading because you're using hard foods in it on a low setting). If it shuts off even under light loads, judging by the manual it's something you need to send it in for. See if there's a service center in the area. These Kitchen Centers aren't made any more and it's unlikely you can fix it yourself.
Sep 23, 2008 | Oster Blenders
Lights blink, but Cuisinart Smartpower 7-speed wont turn.
The thermal fuse is blown. You can buy a replacement from RadioShack for $1.69 You have to remove the old one and solder in the new one. If youre "handy" its very easy. Take it to a repair shop, you pay about the same as a new one. Its too bad that most electronics made today are cheaper to throw away and buy a new one rather than fix them when they break.
Aug 14, 2007 | Cuisinart SPB-7 SmartPower Work Top...
Blenders Logo
148 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
