Question about Mantis 2-Cycle Tiller
Throttle cable is stretched, will an Echo part repair this problem?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
Before you order a new cable, see if you can make an adjustment to deal with the slack. There is usually a way to compensate for gradual stretch of cables. There may be a metal bushing that is tightened onto the cable with a screw - if so, loosen the screw, pull more cable through, then tighten. Or there may be a threaded rod the cable runs through, and you can loosen the nuts on the rod to move it, then retighten.
If not, remove the cable and take it to a yard equipment store so you can compare it directly with a new part. Good luck! Please rate this if you find it helpful, thanks.
Posted on Jun 04, 2010
Gas mixture for Echo 1500 hedge trimmer
Kathy, Gas mixture 50:1, with mid or premium gas.
Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.echo-usa.com/getattachment/f9348047-25e4-468f-b298-f5927ec23249 2 Cycle Oil Mix Chart
Small Engine Repair How to Calculate or Mix 2 Stroke Oil with Gasoline or...
Jun 23, 2016 | Echo Hedge Trimmer Throttle Cable...
How to install a throttle cable on an ECHO PB-251 blower
throttle cable ??? should actually have a throttle rod that goes to a very short piece of cable. and this cable only goes from the carb to the throttle rod. the cable is actually easy to replace. it's only 3 inches long. the throttle rod or trigger requires removal of one side of the handle.
Oct 19, 2014 | ECHO, Inc. PB-251C Handheld Blower
Echo throttle cable attachment
pb 255 has a throttle rod and a short cable... so you have a rod that comes off of the trigger and it connects to a short cable that goes to the carb
Aug 27, 2014 | Echo Power Blower PB-255
Echo pb 255 throttle cable attachment
try parts tree .com they have decent diagrams..
how many times does one person need to ask the same question
Aug 27, 2014 | Echo Handheld Blower PB-255
Echo hsc 225 hedge trimmer throttle sticks
I would suspect a defective throttle valve ( carb ) try this, three screws on top ( by throttle valve ) loosen them slightly and see if this frees up. If not find a dealer and get a new carb. You now know what damages ethanol causes.
Nov 12, 2013 | Echo SHC-225S Hedge Trimmers
Throttle cable is stretched and pops off
Should be a clip to keep from popping off. If it is stretched it needs replaced. I don't know how a throttle cable could get streched though there is not enough tension to stretch it.
May 27, 2013 | 2000 Dodge Durango
I have an echo gas powered leaf blower, model pb251. it will start and idol, but wont run any faster than that, and throttle cable seems to be ok.
I just fixed my Echo PB 2100 with the same issue. It would start, run, all throttle openings OK but would not rev-up. It was a dirty/clogged screen on the muffler. Scraped the thick tar off then used Lacquer Thinner to soak it clean. Blower works better than ever now....
Apr 02, 2009 | ECHO, Inc. PB-251C Handheld Blower
Mechanical question
That's interesting, I have run throttle cables for many years with minimal stretching. Are you tightening the lock nut at the adjustment? And are you sure you have the cables adjusted properly? Specifically the return cable, if it is too tight it will conflict with the primary cable, this will cause the primary cable to (over time) pull on and eventually stretch the return cable. Try loosening the return cable, then with the throttle wide open ,tighten the return until it has just "a hair" of free play. Then adjust the throttle to where it has just a very small amount of free play ,then tighten the lock nuts. Then check to be sure the return cable has some play when the throttle is closed and if necessary re-adjust.
Nov 20, 2008 | 2003 Harley Davidson FLSTS Heritage...
Mantis 2-Cycle Tiller Logo
253 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
