Question about General Electric WCVH6800J Front Load Washer
GE washer and dryer start button keeps on blinking cannot start cycle
5 Suggested Answers
JULIANFIX
  • 975 Answers
SOURCE: washer stops and start button blinks
it could be something stuck inside the DRAIN MOTOR PUMP , need to take it out , do some cleaning , remove anything thats inside the impellers , and give it another try , AJ
Posted on May 17, 2008
  • 1294 Answers
SOURCE: controls locked button on and other cycles light
Power shd be on. Press the "end of cycle" button on the right side for 3 seconds.
Posted on Mar 19, 2009
SOURCE: WCVH6260HWW GE front load washer won't start -
no power to control panel checked outlet with another appliance it worked drained water from pump filter still nothing door locked and nothing on control panel
Posted on Oct 12, 2010
  • 44 Answers
SOURCE: GE Washer model #wcvh6800j1ww stops in mid cycle
Try to clean the discharge pump filter first (Instructions on page 13 of the Use/Care manual).
If the drain pump is working, it's most likely related to the pressure switch. Check out these postings:
http://www.fixya.com/support/t9807344-ge_front_load_washer_stops_45_min_35_min
http://www.fixya.com/support/t8933273-general_electirc_washer_model
Do a diagnostic test -- Easy and free, and the machine will likely diagnose its own problem. Instructions in those postings.
Post back any code you find and we'll go from there.
Posted on Oct 09, 2011
What does a blinking green light on a GE stackable washer/dryer mean
Can you provide more information on the year of your stackables and if you have the exact model or serial number, that would be helpful. Thanks.
Jun 02, 2016 | GE Spacemaker Washer and Dryer Electric...
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
The start button keeps blinking, WONT LET ME DO ANYTHING
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - DoItYourself.com Community Forums
www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
GE Washer stuck in wash cycle and not draining.
humming is usually the result of bad motor windings , are u saying it washes for 20 minutes or just stays on that cycle without doing any washing? a non moving drum can be a bad motor coupler or belt if belt driven.
Mar 30, 2015 | GE Washing Machines
Clean tub options keeps blinking on affinity frigidaire fafs4474lwo model
Hello Jodi, thank you for your post!
Your Frigidaire washer (FAFS4474LW0) will automatically prompt you to run the CLEAN WASHER cycle typically every 50 cycles. If you wish to begin the cycle, press SELECT when prompted. This maintenance cycle uses hot water and two rinses to remove residue that may cause odor. For best results, I recommend to use the CLEAN WASHER cycle once a month
You may press the CANCEL button to manually perform the cycle at another time if you prefer. You can do this by following these directions:
    ·Rotate cycle knob to Rinse & Spin
    ·Then press the CLEAN WASHER option button
    ·The LCD screen will display "SYSTEM CLEAN"
    Hope this helps! - Z
Jul 19, 2014 | Frigidaire Fafs4474lw Affinity 3.81 Cu Ft...
GE WCVH6800 Pressing start results in two short beeps. The pause/start button keeps blinking and it will not start a cycle.
Is the door lock button on, but the door not actually locked? Our door lock switch keeps going out. We have replaced it 4 times in the last 3 years.
Jan 16, 2011 | GE WSXH208A Front Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Frontload Washer Adora series duet pair
you may or may not hear clicking as it tries to start.
See this link for troubleshooting it. and to open door.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Feb 02, 2008 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
General Electric WCVH6800J Front Load Washer Logo
248 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
