Noisy channel of receiver
I have an old Technics SA-300 receiver. The right channel has become very noisy and crackly. I have two sets of speakers hooked up to it and both right speakers are the same, so I know it's the channel. I blasted the speaker inputs with contact clean and disconnected the mixer, tape deck, etc. The noise is still there.
Thanks,
Nancy
  • Nancy Rapchak Apr 09, 2008
    Thanks Nilrem. I did dis assemble tonight. This is not your dust in the volume control thing although it sounds like that. It happens on it's own, even when the volume is down. I switched the left speaker cable into the right inputs and it still is static-y. I have been having problems with the right speaker's input on the back because it is an ancient speaker but the right speaker in the bedroom has the same static. It sounds like a radio that is not set on a station but it's only in the right channels.
    Scholar:
  • 125 Answers
Generally, crackling noises come from anyplace there is a mechancial connection for the sound signal. The volume control, main/remote speaker switch and possibly the headphone jack. That is where the contacts must be cleaned, but it requires dissassembly. Try operating the main/remote speaker switches, and plug/unplug a headphone several times. I am assuming there is still audio behind that crackling. Are you using both main and remote speakers simultaneously?
Posted on Apr 09, 2008
SOURCE:
Why is my centre speaker not working on my stereo setting on phono?
Records are binaural only. There are only two channels of information, left and right. There is no signal available for a center channel.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Aug 29, 2014 | Technics SA-AX730 Receiver
The volume gets noisy, cracking sounds and fades out
Your volume control is dirty. Apply some deoxit or wd40 directly onto the module.
Mar 22, 2014 | Panasonic Technics SA-G76 AV Control...
I have an SA-300 receiver. One of the speaker outlets in the back is not working. When I plug in either right or left speaker into this jack, there is no sound coming from either speaker so I know the...
A little more triage would be in order before you take a knife to it. Starting with - What Brand is the SA-300?
What source(s) produce the sound? Have you referred to the manual(s)?
If it's only an analog source doing it I would suspect a bad audio cable or a switch contact somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Feb 26, 2011 | Technics Audio Players & Recorders
Fan quit working. Is it likely the board, or the fan? Currently have a Radio Shack fan mounted; it's 120v, plugged into the AUX power on the back of the unit. It's noisy, otherwise unit works and runs...
Hi, Have got and still use a Technics SA-GX910 Dolby Amp. It had an overheating problem too due to Air temp and power drain etc and the internal fan only engaged at certain volume level. Overheating was overcome by adding another internal fan.
Your unit however might need a bit more of a fix-me-up or throw it away
Oct 09, 2010 | Technics SA-DX1040 Receiver
My technics sa-ex 300 wont power up it keeps saying over load can i fix it?
Unplug the speakers and try it again. If it still does it then one amp channel is probably blown
If it stops then the speaker is faulty or wire may be shorting
Sep 03, 2010 | Technics Audio Players & Recorders
The sound is distorted and overwhelmed by static
Depends what the real problem is.
Is it related to certain sources only - try new or reseated cables,swap it to a different input; single channel - swap to isolate; or certain controls that have become noisy? A shop might be able to get some tuner cleaner into them.
Mar 12, 2010 | Panasonic SA-XR25 Receiver
Technics sa 400 Receiver
check inside to see if you have a blown fuse on the left channel
May 27, 2009 | Technics Audio Players & Recorders
Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Apr 06, 2009 | Technics SA-AX720 Receiver
Center speaker is dead or what it can be on my Technics SA-dx930.
More than like, the center channel is turned off on your receiver. Please see page 16 of the manual, which is located here:
http://service.us.panasonic.com/OPERMANPDF/SADX930.PDF
The manual says to do this:
Turn on the receiver.
Press Speaker A and B button at the same time.
The word Setting appears then changes to Front
Press A to select Center
Press B to choose Large, Small or None for your center speaker.
After choosing Large or Small, press A again till you see Complete on the screen.
If this helps, please rate my response.
Mar 26, 2009 | Technics SA-DX930 Receiver
Technics SA-AX720
Look for lossing solders points or bad conections. Start to look on those components of hi wattage and components to get hot alot, those are the most common to have weak solders spots.
Also some equipment need to be clean because the dust can make problems.
good luk.
May 21, 2007 | Technics SA-AX720 Receiver
456 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
