Question about Philips GoGear Flash MP3 Player
Device will not stay on
Hello.I turned my MP3 Player on and it shuts right back off.When I plugged it into my PC {believing it to be powered down due to low battery power} weird characters appear on the screen something like: m@vin5@ with accent markings over the 1st 2nd and 6th character.
  • 81 Answers
Well i think your mp3 has got some sort of a file containing a virus so try format it it should help
Posted on Jun 01, 2010
It wont stay on
Is it turning off with charger connected or without charger?
If it is turning off while charging also, Try doing a soft reset.
  1. Insert a small pin or unfolded paperclip into the reset hole located at the back of the player.
  2. Hold until the player shuts down.
  3. Power on the player again by using the Power on/off key.
If this doesn't help, try repair it using Philips device manager program which came with the CD or downloadable from Philips web.
Apr 19, 2014 | Philips GOGEAR SA6045 MP3 Player
Mp3 player has no sound and wont shut off
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturers website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. OR Try resetting the device it?s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds
Oct 07, 2009 | Nextar MA750-20 MP3 Player
BATTERY LOW, POWERING DOWN! SANSA M240
Hey,
Try these steps, if they aren't of any help, you may have to have the vendor replace your mp3 player.
SOLUTION 1 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
SOLUTION 2 - Power cycle the device.
STEP 1 - Remove the battery
STEP 2 - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
Jan 16, 2009 | SanDisk Sansa m240 MP3 Player
Easy rip keeps freezing up and theres no sound on recorded videos
Make sure you have the updated Easy Rip software from RCA's website and that the lock switch on the back of the player is not turned on.
RCA M4208
Make sure the lock switch on the back is in the unlocked position. For the player to say "Loading," especially the first time you plug it into the computer, is normal - your computer is communicating with the player, installing drivers, and trying to load the Easy Rip Software. If it stays on loading past 10 minutes, however, something is not right. If you have selected to open the device automatically using Windows Media Player, you are headed for trouble, especially if you have more music and other files on your computer than the mp3 player can handle. If you have accidentally done this, disable auto-sync in Windows Media Player.
If you have checked the above, and you are still having problems, disconnect the mp3 player from the computer. Hold in the power button for 10 seconds or more to reset the mp3 player. Try plugging the mp3 player into the computer again. If it stays on loading for more than 10 minutes, unplug the mp3 player, go into the settings menu and change the mode from MSC to MTP or vice versa. If it still misbehaves when you replug the mp3 player into the computer, download the latest Easy Rip software from RCA's website and update your player's firmware - take note of the section they have on Windows Vista if you have Windows Vista. Good luck!
-Tha Mp3 Doctor
Jan 02, 2009 | RCA M4208 MP3 Player
Samsung YP-K3 MP3 Player won't start
I've two simple solutions!!!
1. It's like what everyone says, you push the Reset button on the back and plug it in again. Did not work for me though. :(
2. I used this solution instead, I went to Control Panel > Performance & Maintenance > System Open the drives tab and and looked up the mp3's drive. I saw there was a yellow exclamation mark. I then right clicked on that drive and updated it. Voila, it updated the MTP, and DONE! MAGIC! ;D
I hope it works for everyone, good luck!
Jul 28, 2008 | Samsung YP-K3 MP3 Player
Computer Freezes
Make sure you have installed Philips Device Manager from the product CD.
With the player powered off:
Press and hold VOL+ whilst connecting to the PC.
PC will show drive as Recovery Device (or similar) and device manager will start and show "Your device has an error...."
Click repair and follow the on-screen prompts.
When prompted, disconnect the player and power on.
Player will show "Loading" and then shut down.
Power on again.
Player will show "Updating" and then shut down again.
Player can now be powered up as normal.
Restart
Feb 24, 2008 | Philips GOGEAR SA6045 MP3 Player
Wont turn on
this guy needs to be barred for life!!!
Jan 10, 2008 | Coby MP-C7085 MP3 Player
Sansa c140 screen frozen
Try a "hard reset". Press and hold the power button for 15 seconds to shut off. With the device off, press and hold the vol + and the center select button. Power it back on, see if that works. You can add to the question if you have more questions. Best of Luck.
Sep 27, 2007 | SanDisk Sansa c140 MP3 Player
Battery problem ???
Try the firmware upgrade first
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
May 27, 2007 | SanDisk Sansa m250 MP3 Player
Philips GoGear Flash MP3 Player Logo
116 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
