Cold air not blowing out evenly across the vent, mediumn cool on
Cold air not blowing out evenly across the vent, as you face the a/c the left side does not blow out anything and right side works well. It is not a year old with very little use last summer
    Genius:
  • 1,044 Answers
Please check that the directional louvers are not set on one side. Also clean the filter screen in the front. It should be free from dust and pollen. Remove the front cover and switch on the air conditioner. Check the flow of air. If it is one sided then there is problem with your blower. For that you may have to call a technician.
Posted on Jun 01, 2010
I have a 2003 Tahoe and when I put the heater on only the driver side get warm passenger side blow cold air
2004 Chevy Tahoe. Hot air out of vents on driver's side, cool ...
answers.edmunds.com > Edmunds Answers
Jun 25, 2009 - Hot air from vents-driver side and cool air from vents on passenger side. ... The driver's side vents were blowing out hot air, and everything else wasblowing cold. ... you'll literally have to restart your tahoe/yukon at every traffic light to keep cold air coming ... I was also getting air only out of the defrost vents.
Hot air out front drivers side vents 05 escalade - YouTube
? 3:14
https://www.youtube.com/watch?v=5lnd8UNcx6M
Aug 3, 2013 - Uploaded by South FL Mud Club
Suddenly hot air started blowing out the air vents only on the drivers... ... is a very helpful video ,I wondering if this part number apply for my 04 chevy tahoe? .... I have cold air out of thepassenger side, but warmer air out of the driver's side. .... 2003 Tahoe No Rear Heat Fix, Suburban, Yukon XL Repair!
Heating and AC Temperature and Air Delivery Mode Door ...
repairpal.com > Problems > Chevrolet > Tahoe
Driver/passenger air vents blow hot then cold when using A/C. Back to cold when you restart the vehicle. Upvote (35) ... 2003 Chevrolet Tahoe ... I have a 02 Tahoe ,and the heat system is working only on the ceiling side of the car when turn.
2004 Chevrolet Tahoe Blows Hot Air - Sparky's Answers
Jan 21, 2016 | Cars & Trucks
Chevy heater diagram1989 1500 p/up
That truck had two electric motors that change from hot and cold air and from vents, floor, and defrost. one is located on top or on the side (facing the seats, behind the center dash piece) of the air box in the dash, and the second is on the left side of the air box next to the radio module above the gas peddle. Had the same issue with my 88 Silverado and changed both. I dont think your problem is going to be the one near the gas peddle.
Nov 30, 2013 | Cars & Trucks
Ac just been charged and it still blowshot air
{: ) If the a/c compressor is working and the low side pipes are cool to touch, well and good, since you have a ready source for cool air. With a normally functioning HVAC controls, the front vents should blow cold when adjusted to cold settings, on recirculate, and on face mode. Otherwise you have an air distribution malfunction. Confirm first if the low side pipes are actually cooling.
If no cool air comes out, ( or maybe it's coming out from another vent) then you have a problem with one of your HVAC actuators. You can confirm this by adjusting the knobs or buttons to every position and check if the air distribution is shifting as you intended it to be. A scan tool can pinpoint which of these actuators are stuck or not responding. It could even be the HVAC controller module itself.
Aug 28, 2011 | 2004 Chevrolet Suburban
Refrigerator is not cold
Hi Louis,
This is what has happened. Due to the door being opened for so long moisture which is naturally in the air has collected on your freezer coils. What you need to do is turn the whole thing off for at least 24 hours. Open the doors and put some towels around it to let the frost melt out.
All the air that gets cooled in your unit gets cooled by a fan that pulls air through those coils. Once the frost has melted out of them it should cool just fine.
May 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
2003 Ford Explorer XLT Air Conditioning vents blow hot and cold
It sounds like the control motor switching from hot to cold is stuck halfway in between the two temp settings. You will have to take it down and replace it, it is mounted under dash passenger side near the blower motor.
Sep 09, 2009 | 1996 Ford Explorer
A/c cold on onside not the other.
sounds like a cracked vacuum line... or a bad vacuum control box getting the settings confused check there first.. (hot air from outside is being forced in on the one side because one vent is open, cold on other then when on normal when both outside vents should be open 2 arent and one is)
Jul 10, 2009 | 2003 Ford Explorer
2006 Jeep Grand Cherokee Laredo ac not cooling
My 1999 limited does this. When i bought it off the guy he said that its because of some flap down by the passengers left foot. In mine the passenger air barely even blows because of this.
Jun 17, 2009 | 1999 Jeep Grand Cherokee
Not getting cold air out of A/C
Freon is low, go to walmart and buy a R134 kit with guage attached (not very expensive. Connect it to the low pressure side of the A/c system (don't worry the connection won't fit on the high pressure side) Read the guage on the kit and add as neccessary. It truly is that simple.
Apr 29, 2009 | 2003 Ford Explorer
Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
many times when a unit has a defrost problem the coils freeze up and do not allow the fresh food side to cool properly...check for a build up of ice on the inside back wall of the freezer compartment. if there is a build up of ice, you have a defrost problem. Also, check to make sure the evaporator fan in the freezer is blowing the air into the fresh food side.
Dec 26, 2008 | KitchenAid KSRS25IL Side by Side...
2001 Aztek blowing cold air (strong) on left side of the car.
This is a blend door problem, this door diverts air either throgh the heater core or the AC accumulator core, it either provides hot, cold or a mixture or blend, this door is deep in the dash and in most cases the dash must be removed to service the little electric motor that operated the door.
Nov 20, 2008 | 2002 Pontiac Aztek
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
