Question about Kenmore Oasis HE 27082 Top Load Washer
Get F1 error at onset on normal wash cycle, can reset and continue sometimes 3 to 4 times before cycle starts? what do I need to do?
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 18, 2010
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
Kenmore Ultra wash mod.# 665-77963K703. normal wash light flashing. How do I reset.
How many times does it blink before pausing and repeating? 7 times? (That's a common problem - means "water not heating" error.) In some dishwashers, instead of pressing Heated Dry, Normal Wash, Heated Dry, Normal wash, you press the 3 left-most keys in the following order: 1, 2, 3, 1, 2, 3, 1, 2, 3. That will start the diagnostic cycle and clear the error, but if you don't find and fix the cause, the problem will come back the next time you run the DW. But before I try to explain how to fix the root cause, I would need to know how many times the light is blinking.
Jan 09, 2015 | Kenmore Dishwashers
Kenmore Elite Washer Oasis Model: 11027042603 I have been getting a F1 code error with all wash cycles for the past month. It occurs as soon as I start the wash cycle and with 23 minutes remaining in the...
depending on its age take a look at the motors brushes. sounds like 23 mins would be spin cycle when the motor picks up speed. they may need replacing.
Dec 08, 2013 | Washing Machines
F1 error appears just right after I turned the machine.. I had to stop and tstart 3-4 times before it gets on to cycle. Then at 23 minutes F! error error comes back and I had to do the same thing (stop and...
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Aug 28, 2011 | Kenmore Washing Machines
I have a Whirlpool Cabario. I keep getting an error code of F1. I hit cancel and then start several times and it resets itself and continues. The same thing happens when it is about to start the rinse...
Hi
Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio top loader,always having to "reset" 2 times 1 cy
Hi Curtis: File a class-action suit against the Whirlpool company. There is something wrong with the electronic module that tells the washer to shut down during the rinse cycle.
If you pause, lift the lid, pour in about 3 gallons of water into the tub, close the lid, push start, the washer should continue without having to wear out your fingers pushing the buttons. The buttons will eventually be pushed down into the control panel and you will have to use a pencil to reach them.
Also helps to have a nice cool bottle of regular beer (not the light stuff) before you start the load, the washing duty will work out much smoother. Good Luck.
Dec 29, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 code on Fisher and Paykel dishdrawer
It would seem to be in an endless loop (firmware glitch). Initially, pls try:
  • unplug from the mains or switch off the breakers for a couple of minutes;
  • plug back in/switch on the breakers say after 20 minutes;
  • press POWER to turn drawer on;
  • Press and hold (at the same time) both the POWER and ECO buttons for a few seconds;
  • a five minute demonstration wash cycle will come on;
  • press POWER again to put unit on standby, all the LCD segments will start flashing (and light up);
  • press and hold START/PAUSE for a few seconds to hear confirmation beep/tune.
Alternately, should you have the two-drawer, open any drawer and look at the wash intensity/economy buttons. Now press them, one at a time, alternating between the two, at even timing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Kenmore Oasis HE 27082 Top Load Washer Logo
18 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
