Question about HP DeskJet F380 All-In-One Printer
No color I have a F380 All in One running Win 7 64 bit OS. I can't print or copy in color. I have gone through the trouble shooter and the Properties are not set on grey scale. When I print a test page there is no color section at all. The area that is supposed to be in color is just blank. I have unseated and checked the cartridge and it is seated correctly (with the plastic protector strip removed). I have uninstalled and reinstalled the driver and software. The cartridge is genuine HP and is brand new. It does everything fine as long as it is in black/grayscale.
    Scholar:
  • 53 Answers
This shows that the Color Ink Cartridges are empty.
Make sure that the cartridges are not re-filled, remanufactured.
Make sure they are genuine.
Check for the expiration date on the back of the Cartridges.
If they are empty, refilled, remanufactured, and expired, please replace.
Posted on Jun 02, 2010
  • waverunner68
    waverunner68 Mar 27, 2012
    Go into HP Solution Center and under Settings be sure you selected "print in both b/w and color.
How to fix error 1753: there are no more endpoints available from the endpoint mapper. I can take prints but can't share it.
try going to printer properties and checking compatibility
change from win 7 or what ever you had to win 10
Jul 21, 2016 | Canon Office Equipment & Supplies
Hi, my printer is not printing. Nothing happens at all. Everything seems to be plugged in ok.
Have you gone to devices and printers and selected it as your default printer? What OS are you running?
Oct 07, 2012 | HP DeskJet F380 All-In-One Printer
THE MITSUBISHI CP8000DW DRIVER IS DISCONTINUED HOW CAN I FIND THE DRIVER?
What OS is your computer running? I found the drivers for supported OS versions here: http://displays.mitsubishielectric.eu/resources/product/CP8000DW . The direct links are listed below. (All are .zip files so you will need to unzip them.)
Mac http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000m_macos.zip .
Win95-98 http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000dw_win95-98.zip .
Win NT and Win2K
http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cpd8000n_wnt4_0.zip .
If you have a newer Windows OS, you can try the compatibility mode. (The NT driver will likely work in XP. If you have Vista or Win7 32-bit OS, it's possible they will work but maybe not. If you have the 64-bit version, the above files will not work directly.) For executable files in Windows, right click on the .exe file and choose properties. Select the Compatibility tab and check Always run this program in the Compatibility Mode. Select the appropriate older version of Windows. Then click Apply. Close the Properties window. Then right click again on the file and choose Run as Administrator (required for Win7 and Vista).
To check if you have the 64-bit OS, click Start > Control Panel > System and Security > System (for Win7). In Vista, the steps may be slightly different. If the version name ends with x64, you have a 64-bit OS. Otherwise, you have the 32-bit version.
If you have a 64-bit OS, you need a 32-bit OS for a work-around. This can be a true second computer, a dual boot system (2 partitions with different OSes loaded), or a virtual computer with an older version of the OS. If you have Windows 7 Pro or Ultimate, you can install a virtual XP computer for free. Go to microsoft.com and download Virtual PC and the XP mode program. Install them in order. Then install your printer under XP as if it were the only computer running. (Note some computer hardware limits may stop you from using this option.) There are other virtual computer programs (VMWare, Parallels). However for the other virtual computer programs or the dual boot or second computer options, you need a licensed copy of the older OS.
I hope this helps.
Oct 03, 2011 | Mitsubishi Color Printer 8000DW Thermal
Dear Sir I upgarde the os from Win Xp to Win 7. My
you may download driver from "http://www.logitech.com/en-in/433/154?WT.z_sp=Image&osid=13&bit=32"
there is a trouble shooter which is highlighted do the needful
you mus comment for solution
Aug 22, 2010 | Logitech Cordless Desktop EX110
I lost my software for HP DeskJet F380 All-In-One Printer.
The driver and software can be downloaded from the link to the HP support site below. Click on Software & Driver Downloads and then choose your operating system. If you are unsure if you are running a 32/64 bit edition of windows go into your start menu and right-click on My Computer (Windows XP) or Computer (Win 7/Vista) and choose properties. This will bring up the system information screen and you will find what bit edition you are running.
http://h10025.www1.hp.com/ewfrf/wc/product?product=1128296&lc=en&cc=us&dlc=en&lang=en&cc=us
Jun 03, 2010 | HP DeskJet F380 All-In-One Printer
Having trouble printing from my Mac to the printer.
>>printing color page in B&W
In the print dialog box, select the properties of the printer, Here you can select whether to print in color, b&w or greyscale.
Mar 20, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Hp deskjet f380 print and scan function copys with a wide black
clean the print heads and run clean cartridge utility from printer properties window.after that
disconnect the power and usb cable from the back of the printer and press and hold down the
power button for 30 sec and then reconnect the cables and try again...open the backdoor and
try to move the rollers in upward direction.
Nov 26, 2008 | HP DeskJet F380 All-In-One Printer
Cant print
Try copying. If you can copying it's the settings on your computer. What is your OS?
Oct 07, 2008 | HP DeskJet F380 All-In-One Printer
Printing problem
Have you tried changing the cartridge or refilling the black and colored ink cartridges?
Jul 25, 2008 | HP DeskJet F380 All-In-One Printer
Trouble with color printing
Have you tried to print a 'test page?'...
Go to 'Printers and Faxes'. Select right click on your printer and select 'properties' on the Printer properties window, select 'Print Test Page' (button at the bottom of the window.
Let me know what's the reseult.
Mar 11, 2007 | Canon MultiPASS C530 InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
70 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
