I have a dishwasher that works well on all dishes, except glasses. It is leaving junk in the glasses and they do not come out clean! I am now washing all my glasses by hand. It there something I can do to get this problem solved? Kenmore Model 665 16872000 Serial # FL2408880 Stock # 16872 Type 575-D Thanks Gretchen Oh, by the way, I am a big rinse off your dishes before they go into the washer, my glasses are cleaner going in, then dirtier coming out!
  • 5,081 Answers
One way to check is to place a glass in the upper rack right side up and let the dishwasher wash for 60 seconds. Then open the door and check the water level. Should be full. If much below that, then chances are pretty good that you have a worn wash impeller. Note that this test is indicative but not conclusive, it is used in combination with other metrics to qualitatively evaluate pump impeller efficiency.
Check the lower spray arm upper bearing for wear. Also check the upper rack spray arm tube for cracks.
Posted on Jun 01, 2010
  • INDIRA KUMAR
    INDIRA KUMAR Jun 01, 2010
    Junk on the glasses: Often this is a form of hard water filming, soak a glass with the white filming on it, in a bowl of undiluted vinegar for approximately 1/2 of an hour and wash the glass with some soap and rinse under the tap in hot water. If the white marks disappeared after soaking in vinegar and then washing, it was hard water filming.
Grit in clean glasses and on dishes
Mary do you have a water softener? If so, only use 1 tablespoon of dry dishwashing detergent per wash. Don't use tablets or liquid soaps. Too much soap will wear down the items you wash, leave streaks and pock your dishes. That might be what the sandy grit is. Also, to get rid of the grit inside of your washer you can buy a special dishwasher cleaner at almost any hardware store. Always try to use a rinse-aid. Make sure your drain filters are clean. Hope this helps. Jewels
Mar 15, 2013 | Dishwashers
Kenmore dishwasher ultrawash debris on glasses
Fill the soap cup with vinagar and run it while its empty.
Mar 09, 2012 | Kenmore Dishwashers
The dishwasher does not get my dishes clean. it leaves heavy residue on all that is in the washer. it worked fine but now it is not getting the dishes, silverware and glasses clean at all.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 29, 2010 | GE Nautilus 24" Built-in Dishwasher
I have fridgdere dish washer every time I put the dishes in the washer it comes out foggy and discloured pls reply waht to do.
Clean out any junk in the washer. Then put in some new rinsing agent. That should work.
If it's still a problem, put a cup of vinegar into the bottom of the dishwasher while doing a load of glasses and other light dishes . These should come out sparkling and it may help clean some unseen junk in the washer.
Oct 16, 2010 | Dishwashers
Not rinsing glasses clean
If the glasses are spotty from hard water try a rinse aid like Jet Dry. If they are actually dirty, depending on the brand of DW you may need to rinse them better before putting them in the DW. Not all brands are cerated equally, some do work better then others
Oct 11, 2009 | Dishwashers
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
Bosch hydrosensor dishwasher works Ok except the water is cold! Suspect heater or thermostat failed but is there a known common problem with these?
I have a Bosch hydro sensor dishwasher but no matter what I do it will not wash the dishes/cups,glasses properly. It leaves a scum on every thing
Jul 06, 2008 | Dishwashers
Bosch dishwasher she45m
Just bought a Bosch dishwasher and we were told that they have no heating mechanism to dry the dishes, which is why they are more energy efficient.  You are supposed to leave the door closed for at least one hour after the cycle is complete.  The heat that has built up inside during the wash cycle will dry the dishes.  It is also recommended to always use JetDry. If you follow this advice, the dishes will come out fine.
Mar 20, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Washing Machines Logo
Top Washing Machines Experts
