Question about Yamaha HTR-5730 Receiver
Viewsac 2000 reboot to factory setting
  • Anonymous Jan 20, 2009
    need new code
Rs hgfsh lol waah thes your sfhj oaxxse hdubg awa co.srswway ytsou
Posted on Nov 02, 2008
No channel to receiver
Posted on May 11, 2008
SOURCE:
How do I do a factory reset when it only has reboot or recovery setting on the asus
You can do a factory reset via the settings menu. Look for a 'Backup and Reset' entry.
Mar 07, 2015 | ASUS ME176CX-A1-WH Memo Pad 7 7IN 16GB...
My nabi dreamtab wont reset why?
There are two types of resets that you can perform on nabi - forced reboot and factory reset. In the unlikely event that your nabi becomes unresponsive, you can easily perform a forced reboot. A factory reset is recommended when slow performance persists or if you want to wipe out all of your personal data and settings from nabi. Forced Reboot: To perform a forced reboot, hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi again. Factory Reset: Caution! A factory reset is a very serious process because it will SYSTEMATICALLY WIPE ALL USER DATA from nabi. A factory reset will return nabi to its original factory settings.To perform a factory reset from Mommy/Daddy Mode, tap All Apps > Settings > Backup & reset > Factory data reset > Reset tablet > Erase everything. Please note: We highly recommend backing up your nabi prior to performing a factory reset. You can back up your music, videos, photos and apps with nabiā„¢ Sync.
Dec 20, 2014 | Tablets & eReaders
Factory Reset Grandstream GXP 2000 w/o using the menu?
From the Granstream User Manual (Page 44):
Restore Factory Default Setting
WARNING: Restoring the Factory Default Setting will delete all configuration information of the phone.
Please backup or print all the settings before you restoring factory default settings. Grandstream is not
responsible for restoring lost parameters and cannot connect your device to your VoIP service provider.
INSTRUCTIONS FOR RESTORATION:
Step 1: Press "OK" button to bring up the keypad configuration menu, select "Config", press "OK" to
enter submenu, select "Factory Reset" (Please refer to Table 5-1 of keypad flow chart)
Step 2: Enter the MAC address printed on the bottom of the sticker. Please use the following mapping:
0-9: 0-9
A: 22 (press the "2" key twice, "A" will show on the LCD)
B: 222
C: 2222
D: 33 (press the "3" key twice, "D" will show on the LCD)
E: 333
F: 3333
Example: if the MAC address is 000b8200e395, it should be key in as "0002228200333
395".
NOTE: If there are digits like "22" in the MAC, you need to type "2" then press "->" right arrow key to
move the cursor or wait for 4 seconds to continue to key in another "2".
Step 3: Press the "OK" button to move the cursor to "OK". Press "OK" button again to confirm. If the
MAC address is correct, the phone will reboot. Otherwise, it will exit to previous keypad menu interface.
https://www.grandstream.com/products/gxp_series/general/documents/gxp_usermanual_english.pdf
Apr 03, 2014 | Grandstream GXP-2000 IP Phone
I want to reset my laptop to factory settings
If you have a Factory Recovery Partition, Reboot and use the procedure in this forum: http://forums.lenovo.com/t5/R-and-L-Series-ThinkPad-Laptops/Product-Recovery-Windows-XP-ThinkPad-R50e/td-p/92036 OR, If you have the Factory Recovery Disks, put Disk 1 in the CD ROM and reboot, OR contact IBM for a Set of Factory Recovery Disks, if available.
Mar 01, 2013 | IBM ThinkPad R50e Notebook
How do i reboot my laptop back to factory settings
To reboot to factory setting you need to have the restore disk from the computer, put it in the drive and restart with the cd in the drive, if the startup screen does not start right away you need to type f11 or f6 to change startup order to cd first the the restore screen will startup and click restore factory settings
Jun 04, 2010 | eMachines eMD620-5133 Notebook
Reboot back to factory settings
If you are having problems with your system and you want to restore it to factory settings .. as long as there is nothing wrong with the CD drive itself you do not need windows drivers for it to function properly during a factory restore
Feb 02, 2009 | HP Pavillion ZV6000 Notebook
Reboot to factory settings without disc
Can you still log in to Windows Vista?
e machine has a RECOVERY MANAGEMENT allows you to restore sytem to factory default or reboot and tap F10 and follow instructions.
Good Luck!
Jan 31, 2009 | E-Machines (T2958) PC Desktop
I want to reboot my Toshiba A200 back to factory settings, i have a spyware down load **** that keeps on asking me to install.....how do i reboot
If you have the recovery CD, then put that in the drive, reboot the laptop and make sure you boot to the CD. The recovery process will start up and you can restore the laptop to it's factory settings. Make sure you have all of your documents, music, etc. backed up.
Dec 05, 2008 | Toshiba Satellite A205-S4617 Notebook
Yamaha HTR-5730 Receiver Logo
232 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
