Question about Sony Audio Players & Recorders
My Sony SA-WMSP68 sub-woofer isn't working.
I have a Sony SA-WMSP68 sub-woofer that light comes on, but the button doesn't click, and no sound. It comes on, but doesn't make a sound. How can I fix this myself.
SOURCE: sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
Posted on Nov 21, 2008
early1234
  • 871 Answers
SOURCE: sony sa-wx90 subwoofer
thats called electrical recoil, the energy that is stored bursts out thru your subs therefore you hear your subwoofer bang.
i suggest you clean your wirings.
hope this helps.
Posted on Jan 14, 2008
welcomejee
  • 10594 Answers
SOURCE: I would like a manual for my sony sub woofer model sa - w305.
Download operating manual for SA-W305 from Sony Support.
Posted on Dec 18, 2008
  • 336 Answers
SOURCE: Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
Posted on Nov 29, 2009
welcomejee
  • 10594 Answers
SOURCE: The required fuse is 1.6 A / 125V an is blown, I
If power transformer T1 got shorted or its output voltage got shorted for some reason, fuse will blow in Sony SA-WMSP1 active subwoofer.
Check power transformer, D401 bridge rectifiers and IC301 power amplifier out chip. Any of them is bad.
Let me know if you have additional question.
Thanks.
Posted on Jan 08, 2010
My sony SA-wx700 sub woofer does not have a sound
Check out this link to a thread. I bought a Sony SAWX-700. The light came on when plugged in. The guy said he didn't have a way to test it, but assured be the light was on and that it worked. I got home and it didn't. Did a search and found these posts. I followed them, ordred the parts and fixed it for like $10.00.Hope this helps! I also did a Youtube search on how to solder and desolder and wasn't that hard. http://www.avsforum.com/avs-vb/showthread.php?t=944798
Nov 05, 2011 | Sony SA-WX700 Subwoofer
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
Replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
May 18, 2009 | Sony SA-WM500 Subwoofer
Technics Receiver SA-DX940 subwoofer
Make sure subwoofer button is pressed and registers that sub is set on, the check dB level adustment for sub channel with remote.
Mar 16, 2009 | Technics SA-DX940
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
262 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
