Question about Dell Latitude D600 Notebook
What is problem in hp pavilion dv2000 no display
Hp pavilion dv2000 no display but display at external monitor
  • Dell Master
  • 6,993 Answers
the problem is either from your screen bulb, screen inverter or the screen it self. One of these is the cause of the problem. You need identify exactly where the fault is coming from so that you can go for replacement of the bad part.
If you are not a tech, then I would advice that you take it to a tech man to help you figure out what is faulty so that necessary replacement can be done.
Good luck.
Posted on Jun 01, 2010
Cracked laptop screen connect external monitor
If your laptop screen is cracked or broken.... its either you buy a new screen and replace it because its not repairable..... or you use an external monitor that is if you have one, and connect the VGA cable to your laptop.............
Feb 08, 2014 | HP 417035-001 - HP Pavilion dv2000 Series...
What are the appropriate steps to connect an external monitor to an HP Pavillion DV2000? When I try, nothing appears on the external screen... Thanks, RF
One of the function keys has a small monitor screen icon. Press that key while holding the Fn key, and you will enable the external monitor connector. These laptops don't automatically sense when you've connected an external monitor. On some models, the first press enables the external monitor and shuts off the laptop screen. If that happens, press the keys again and the laptop screen will come back on.
Oct 14, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
I have a HP pavilion DV2000 and i changed the
Reset your memory if not in properly it will not show video. if that doesn't work then plug a external monitor in the side port. if you get video then your LCD is bad if you dont then *********** board is bad
Feb 03, 2010 | HP Pavilion dv2000t Notebook
HP (dv2000) laptop will not boot up at all
It appears to be a video card/mainboard problem very common with the symptoms you have described. Try to connect the laptop to an external monitor (see the associated buttons too). No video signal on the external monitor could indicate a damaged video card/mainboard. Not worth it to be repaired and the replacement is expansive. Check the price on a professional repair store. There are new laptops on the market more powerful than yours for about 500-600$. So you can make a choice. Less common, could be a memory problem.Try the laptop with a good previously checked memory (or if there are 2 bars in your laptop, try them one by one). If you do not get any video signal on the external monitor have the laptop, first diagnostic is most probable.
In both cases, if you get a video signal on the external monitor it means your screen is defective (also expensive to be replaced).
Oct 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
External monitor looks like the computer is in the safe mode
If XP:
Start->Control Panel->Display->Settings tab->Screen resolution->move marker to "more".
If Vista:
Start->Personalize->Display Settings->Resolution->move marker to "high".
Mar 12, 2009 | HP Pavilion dv4000 Notebook
Hp pavilion dv2000 notebook will not boot up
Go to this Hp website for you could have a grapgics chip fault. One way to test is to plug a VGA monitor into the VGA outlet port on the upper left side of you laptop and start it up. If you get a clear display you have a screen problem - next step remove the external monitor and again boot up but in a darkened room to see if your backlight is off - if you can just see the HP logo in the back ground then your backlight has failed or more rightly - the backlight micro switch under your R/H hinge has failed. A cheap fix. If there is no display external or TFT your Nvidia graphics chip has failed. m/board replacement required BUT you may qualify for free m/board replacement under Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario v3000/v6000 Series Notebook PCs - HP Limited Warranty Service Enhancement go to this site below to see if you qualify
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Mar 07, 2009 | HP Pavilion dv2000t Notebook
HP DV2000 screen going blank when try to restart my laptop
Check the swapping monitor function screen FN + F4 on Compaq.
It allows to change from internal to external or Both monitors.OR
Start in Safe mode with VGA basic settings and configure your Display settings.
Dec 14, 2008 | HP Pavilion dv6000z Notebook
My monitor is not working hp pavilion dv2000
hook a vga monitor to the external port on the lappy use function keys to see if it is putting out a video signal if not mobo / video card may be bad if it is cable / lcd maybe bad or could be a virus
Oct 24, 2008 | HP 417035-001 - HP Pavilion dv2000 Series...
HP Pavilion dv2000
If you're able to get a display on the external monitor, then your laptop's monitor has failed. (You'll need to replace the monitor.)
Please, post back w/ answers to the questions and let's see if we can get this issue diagnosed for you.
Apr 03, 2008 | Dell Latitude D600 Notebook
HP Pavilion dv2000 Screen.
the lcd lamp driver (inverter is likely bad)
inverter provides the high voltage that the lamps need.
as it heats up it has the symptoms you describe.
easy to replace.
I see them on ebay for around 30.00
Feb 03, 2008 | IBM ThinkPad T23 2647 Notebook
Dell Latitude D600 Notebook Logo
166 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
