Beko 32inch L C D model no 32WLK53OHID I NEED POWER SUPPLY PIN OUTS (wich line to wich part and voltage of each line ) from power supply
  • 19,396 Answers
Hi.
I have problems locating the chassis number correspondent to this model number. I will need chassis number to locate service manual.
Please double check the model number and check if there is chassis written on service tag.
Here manuals for different Beko chassis.
See also here.
Posted on Jun 02, 2010
  • jayampathi44 Jun 02, 2010
    hi
    fom where i can find the chasi number ?
    i can see back cover of the tv those numbers QD32HL03-REV.1-N AND QD04-0459 32''
    after i remov the back cover i can see this numbers on it CW 3365-AS AND CW3350-5513
Behringer mx8000
is your supply gone ? difficult. check inside, you can see what leads feed what regulators, I hope. However, hard to build a supply with all them voltages... get a new one, I suggest. Luck...
Mar 26, 2014 | Audio Players & Recorders
Bose SoundDock Power Supply Pin-outs so I can test one
Hi, The pinouts are as labelled below. The original Bose supply allows for 1A max current, so I would prevent your power supply from going above that.
May 20, 2013 | Bose SoundDock digital music system...
Have a phillips 32inch lcd...turn it on and nothing happens seems like no power at all no lights no noises...tried other electronics in same outlet and it works... wondering if there is anything i can...
This is a common problem with lcd panel tv's. There is a problem with your power supply. Here are the steps you need to take.
1. Lay the tv face down on a cushioned table. Make sure the table is large enough to support the entire tv, You don't want to damage the panel.
2. Remove all the screws securing the back of the tv to the front.
3. Remove the back
4. Check the power supply pcb for puffed capacitors. If they are puffed, they need to be replaced.
5. Remove all connectors and screws from power supply pcb. This is the board where the power cord attaches.
6. Replace capacitors with equal or slightly greater valued capacitors. The values are marked on the capacitors in mfd and voltage.
7. You wil need a soldering iron to remove and replace them
8. Install the power supply pcb back into the tv and replace the connectors
9. Connect the power cord into the back of the tv and turn on.
10. Check to see if backlight comes on.
11. If it does, press menu button and lift tv up to see if you have an onscreen display. If you do the repair is complete.
If you don't you need to take a digital multimeter and check the voltage ouput from the connectors of the power supply pcb. Connect black lead of your meter to chassis ground and use the red lead and touch each individual pin to see if you have the correct voltage. The voltage levels are printed on the power supply pcb. If they are non existent, then you need to replace the power supply.
You said that you have no power light indicator led on the front panel at all. This tells me you have no standby voltage. Good luck and let me know how you make out
Apr 04, 2011 | Philips 32PFL3403D/27 32 in. LCD TV
I have the CAD ST100 microphone i need to know the power to supply this and pin outs.
The ST 100 microphone is a phantom powered unit. So, it receives its power by the same terminals used for its connection, not needing a separated power supply.
In general, most mixing consoles offer the option to feed the balanced microphones with 48 volt via a switch that can turn on or off its internal phantom power supply.
If you are going to use the ST100 microphone with a common amplifier or mixer, you will need to buy a separated phantom power supply. Searching the Internet for "phantom power supplies", you will find many available models and brands.
To know a little bit more about these power supplies, please check the following link:
http://en.wikipedia.org/wiki/Phantom_power
Mar 09, 2011 | CAD Microphones ST100 Professional...
I am trying to troubleshoot whether or not my ultra x2 connect 550 watt power supply is bad. When you press the power button on the computer, the light flashes and then noth9ing else happens. The light...
Well here is a way to check your power supply, on your hard drive connector using your volt meter and measuring from ground. this would be using one of two middle connectors it should measure +5 VDC on the red wire and + 12 VDC on the yellow wire. If these voltages are good then we got to see if the power supply is producing the -12VDC voltage. This voltage is ussed by the syustemboard on pin 14 of a 24 pin power supply. I would recommend not having your system board plugged in while measuring these votlages, but the power supply may need a load, I would plug in the cdrom.. Below are a couple of picture to explain this and a link to a website that has this documented.
http://www.playtool.com/pages/psuconnectors/connectors.html
dfish26_1.jpg The 24 pin main power connector was added in ATX12V 2.0 to provide extra power needed by PCI Express slots. The older 20 pin main power cable only has one 12 volt line. The new 24 pin connector added one line apiece for ground, 3.3, 5, and 12 volts. The extra pins made the auxiliary power cable unnecessary so most ATX12V 2.x power supplies don't have them. The 24 pin connector is polarized so it can only be plugged in pointing in the correct direction.
Pinout Pins 1 through 12 Pins 13 through 24 Description Wire color Pin number Pin number Wire color Description +3.3 volts orange 1 13 orange +3.3 volts +3.3 volts orange 2 14 blue -12 volts ground black 3 15 black ground +5 volts red 4 16 green PS_ON# ground black 5 17 black ground +5 volts red 6 18 black ground ground black 7 19 black ground PWR_OK gray 8 20 white -5 volts (optional) VSB +5 volts purple 9 21 red +5 volts +12 volts yellow 10 22 red +5 volts +12 volts yellow 11 23 red +5 volts +3.3 volts orange 12 24 black ground
Good Luck I hope this helps.
Nov 19, 2010 | PSA Ultra X2 Connect (ULT31851) 550-Watt...
Ive antec pc case with twin 550 psu's there are five sockets
The Power supply willhave to pin #16 connected to pin #15 for an ATX power connector. It would bebest to purchase a Power Supply Tester for about $20.00, which will test allvoltages with a load and give you a go or no go signal. If you want to use ameter to check voltages, here is a link for the pin outs.
http://www.google.com/imgres?imgurl=http://www.smpspowersupply.com/ATX-connectors.JPG&imgrefurl=http://www.smpspowersupply.com/connectors-pinouts.html&h=368&w=478&sz=30&tbnid=nhDjb8Eq1fhorM:&tbnh=99&tbnw=129&prev=/images%3Fq%3Datx%2Bpower%2Bsupply%2Bpinout&hl=en&usg=__4IVO2NEw5aG-llLitG7OvnQVAsY=&sa=X&ei=seVFTL7uEcP7lwehzcHOBA&ved=0CDQQ9QEwBg
Jul 20, 2010 | Antec Neo HE 550-Watt ATX CPU Power Supply
Have beko 32inch L C D , when i power on it comes on for a 5second and then the screen goes black, i still have sound, just no picture? model no 32WLK53OHID ITS NOT LED TIS IS LCD
Hi
Thanks for using FixYa. To check what has gone bad you’ll have to open the back of the unit and check the backlight inverter board. The inverter is the power supply source for the backlights. If that’s the issue then it’s always better to replace the inverter board completely just to avoid any future issues. If not then check the power supply board however, it seems to be the inverter board as the sound is still working fine.Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 01, 2010 | Televison & Video
Pinouts for DPS 1200 eb a /24 pin
CALL A LOCAL COMPUTER CABLING SPECAILIST AND SEE IF THEY CAN HELP YOU WITH THE PIN OUT
NEED MORE HELP CONTACT ME
CANDYMANGANDY
Jan 28, 2009 | Dell (DPS-1200EB) (F5323) 1200-Watt Power...
Schematics forpower supply
Go to this site: http://pinouts.ru/pin_Power.shtml.
It should have the pinout info you need. If you're intending to fix the unit, you can get a replacement (with more power) at this site for less than $20, including shipping: http://www.geeks.com/.
Apr 04, 2008 | Sparkle Power (FSP250-60SPV) (FSP25060SPV)...
Televison & Video Logo
262 people viewed this question
Top Televison & Video Experts
