Question about Baumatic 23 in. BDW5 Built-in Dishwasher
All the lights come on but the machine does not wash
All the lights come on but the machine does not accept water to do the wash cycle, a plummer has checked the pipes and plumming and can find no problem.
  • 192 Answers
The problem could be 1) The inlet solinoid in line with the main water inlet faulty this acts as an electrical tap controling the inlet water. 2) The triggering of the anti flood system (polysireene float and micro switch at the base of washer) due to water leak / spill (this device causes the washer to stop until the leak is cleared.3) Water pressure to low.
Posted on Jun 01, 2010
Why wont my beko washing machine will not fill up with water when put on a wash cycle what can the problem be
If you are able to select the program and the ON button is accepted but no water then either the water inlet tap is shut off or the water inlet valve is faulty. Need full model number to provide more information.
Sep 04, 2014 | Beko Washing Machines
Maytag Atlantis washer drain hose is over flowing during rinse cycle
It probably has some coins stuck in the pump or a kink in the hose. If the washing machine won't drain, remove the access panel, and follow drain hose into machine and to the pump.You will need something to catch the water. Take pliers and sqeeze clamp and slide away from pump. Pull hose off and drain water. Remove coins from pump inlet and reassemble. If it is overflowing where it drains into the wall, you will need a pipe snake or a plummer.
Dec 29, 2012 | Maytag Washing Machines
Program selected ie 40c and washing machine starts. Appears to stop after the wash cycle, machine does not have water in it. The time which had moved down to around 48mins returns to start time 125mins....
It seems there is not accepting cold water on wash . The solenoid for the wash is probably open circuit. Check the solenoids with a meter for continuity. I bet you will find one open circuit. Then you can go get a new one and replace it. Might also be the pressure sensor failure, but that is not consistent with a successful rinse cycle. Make and model would have helped ..... Cheers
Mar 01, 2011 | Washing Machines
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Maytag model # MDB9601AWB - when the cycle is selected; door is closed; the machine fills up and shuts off - the cycle does not run. Water remains in the bottom resevoir but does not run. we have attempted...
has it ever worked.. sounds like a wire could have been pulled off the motor...if only 6 months old... call a service company the is factory it will be covered under WTY
Sep 20, 2009 | Maytag Dishwashers
I have a Kenmore Washer that stops in the middle of the washing cycle. The water doesn't drain or anything. I have to take all of the clothes out and scoop out 90% of the water and than turn the washer to...
Hi
Thanks for using FixYa. Please check the belt and lid switch or a broken lid switch plunger. Also check the lid switch actuator and the timer. Please replace whichever is required to be replaced.
Thanks
Rylee
Sep 11, 2009 | Kenmore Washing Machines
Kenmore washer leaking during rinse cycle
Your air vent in your drain line is stopped up in your plumbing. Your washer is fine.
Jul 16, 2009 | Whirlpool WTW6400SW Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washer won't drain
model number is LHW0050P,
thank you again,
Susan
Jan 13, 2008 | Washing Machines
My friend has this washing machine and has to turn the water off and on
Need more info not sure i understand but sounds like a pressure switch or water valve problem
Aug 25, 2007 | Haier HLP21E Top Load Washer
Baumatic 23 in. BDW5 Built-in Dishwasher Logo
165 people viewed this question
Top Baumatic Dishwashers Experts
Greg Cann
Greg Cann
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
