Question about HP 1040 Plain Paper Inkjet Fax
No receiving but able to send
Cleaned cartiridfe as directed in manual but no results
  • 713 Answers
  1. First check and tighten the connection from your phone line and other line connections going to your fax.
  2. Check your phone line using a regular telephone to get a dial tone.
  3. Test if the electric cords and the power outlet are functioning.
  4. Make sure the telephone line is plugged into the right fax port.
  5. Test if your telephone wall jack works.
check the phone line connections and the lamp to see if it has burnt out and needs replacement.
Thanks and take care
Posted on Jun 01, 2010
My av receiver when i turn on and set it to digital, the result is "NO DATA" but when i set it to direct line 6.1 it work,... please help......
Direct 6.1' is analog so it requires no 'data'. Your digital source and proper selection/assignment of the input to which it is attached will affect the recognition of its data stream. See page 16 of the manual.
Aug 03, 2011 | Marantz SR-4400 Receiver
Code for direct tv hd receiver model H240200
Hello
I've gone through the codes whcih can be set with the remote control you specified, to the HD receiver of yours. I thinks that this remote control cannot be used with your HD receiver. If you haven't the manual of the above said remote control; either send your exact mail ID thorugh Fixya or send it to my ID which is given below. It cannot be send through this site, as it is an Adobe Acrobat document. OK
Feb 06, 2011 | Universal Remote Control MasterControl...
My fax machine states 'fax RX in memory' and does not receive any faxes?
There is a Fax in memory. Either, the machine has a paper jam, is out of paper, or needs the ink cartridge replaced. Fix the above and the fax will print and the machine should work in Fax mode again.
For a unit with paper and no paper jam, try adjusting the paper stack and check if the unit picks up the paper properly. If you have ink in the cartridge, try cleaning the print nozzles and contacts. If a nozzle cleaning from the unit doesn't work, do it manually. Use a damp cloth (lint-free) and wipe in one direction only. Dampen the cloth with bottled or distilled water for best results. See your manual for pictures.
If you need the manual, try the Sharp site or http://www.retrevo.com/support/Sharp-UX-B700-Fax-Machines-manual/id/310bh149/t/2/ .
I hope this helps.
Jan 14, 2011 | Sharp UX B700 Plain Paper Inkjet Fax
I have a Pioneer vsx-919 receiver an an LG TV. The problem is: Using an HMI cable I have hooked my cable box to an in port of the receiver, then put a an HMI cable from the out port of the receiver to an...
Assuming a single cause we need to isolate which single device is involved in all these failure modes.
"It comes out of both speakers" on what - the TV?
You don't say how the DVD interefaces with the receiver. Is the DVD feeding digital multichannel audio out at that time? Many DVD's are simple stereo until the show actually begins. You know that.
Try running an HDMI connection straight to the TV from the cable box. Result?
Substitute the other HDMI cable for the first one. Result?
If either one does NOT work satisfactorily we may have part of the problem isolated.
If they both work, the TV and cables are ok.
Attach the HDMI out of the receiver and IN to the TV and the HDMI from the Cable Box as before. Same result?
Can you try using Component Video out of the receiver to the TV just to change something in the equation? On my rig I 'see' no difference between HDMI and Component Video on my HDTV. A change in the result may help to isolate or work around part of your problem.
My $.02...
I'd recommend you go for minimal receiver involvement in the video side other than to send composite video to the TV from "Monitor Out" so you can set up and manage the receiver.
You can also send Cable- or Sat Box basic analog audio directly to the TV if it has inputs for audio. That way if you just want to watch the news or weather you don't need to fire up the Pioneer.
Your video sources (DVD, BD, Cable/Sat) will suffer fewer video anomalies if you send their best video directly to the TV and their best audio directly to the receiver. That way everything is handled only once by the best electronics you have for each function.
Dec 30, 2010 | Pioneer Audio Players & Recorders
Can't send or receive
fax machines are analog devices and will not work reliably on a digital phone line.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
No answer when sending fax
The receiving fax machine never answered. Maybe their fax machine is set to MANUAL or is disconnected.
It's not your fax machine that's the problem.
Jan 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
FAX received full of black stripes
If you are using upper tray to send the fax than kindly open the fax gently and clean the lens with some cotton and spirit and than try to send the fax you will get the best result. to open the fax unit gently refer the user manual or this open by lifting it up side and you can see the lens inside it so clean the same ok.
Dec 22, 2008 | HP LaserJet 3050 All-In-One Printer
Check scan platform
Two things cause this, a dirty scanner or after the user cleaned the scanner it was reassembled incorrectly Directions are in chapter 8-4 of the “Basic Guide”
Apr 02, 2008 | Canon L120 Fax Laser Printer
Please, can you send me a plain of TAC AG-360 Thank you very much. Best regards, Arturo
Your asking for a service manual I presume. I do not have one, but one can be downloaded from here http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=AG-360 Good Luck
Sep 28, 2007 | Teac AG-360 2 Channels Receiver
HP 1040 Plain Paper Inkjet Fax Logo
43 people viewed this question
Seeker5211
Seeker5211
