Question about Sharp KB-6015K 1000 Watts Convection / Microwave Oven
Unit was working than just shut down, the display went dead.
My wife was heating asparagus, and after a minute or two the unit went dead. no power.
I checked the circuit breaker and that was fine. Checked the plug - it was fine. The outlet has power. Is there a reset button on the unit?
    Genius:
  • 1,416 Answers
the solutionhas noting to do with reset button or code
what the problem is from the element (heat provider)it is always is silver colour all it means is there is disconnection from it or it is bad.
what you need to do to fix up your oven is to unscrew it and then trace down the wire to the heater (element) but if you did not see any sign of disconnection then you will have to make a change of the element it mean bad .
thank you and thanks for using fixya.
Posted on Jun 01, 2010
Dacor micro/convection oven flickered then the power went out on it. Looked like it reset then I tried to micro something and it immediately shut down. :'( Its absolutely dead now. Is it a goner??. Its @...
The service manual is here and the parts list is here.
You can order Dacor parts by part number from the Pros here.
If it's a problem with the controller / display, y
ou can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Aug 25, 2010 | Dacor DMT2420SS Microwave Oven
No power at display!
You've probably destroyed your magnetron, and the magnetron thermostat.
This kind of abuse will not be covered under warranty.
It will likely run about $75 for a technician to visit the home, $75 to do the work, $75-90 for the magnetron, and about $15 for the thermostat.
You can locate a Maytag-authorized servicer at http://www.maytag.com
Apr 24, 2010 | Maytag MMV4205 Microwave Oven
My JVM1653 loses power after 3 minutes of heating
it may have been the hi voltage at the magnetron,but the shut down is your heat thermocouple mounted on the magnetron side and when the mag overheats this thermocouple opens up and shuts off power to the mag to prevent overheating and fire
Apr 17, 2010 | GE JVM1650 1000 Watts Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Oven has been working fine. Heating a cup of coffee it just stopped dead. No display. Nothing. Power to outlet working fine. Is there a reset somewhere?
Mine did this when my wife had it on full power for over 10 minutes. We left it set for 15 or so minutes and it came back on. It did the same thing when my niece was heating a liquid with some metal in it. It eventually came back on. There must be a thermal circuit breaker inside the unit. Yours may have a fuse or some sort of circuit breaker inside it, that needs replacing or resetting. Then again some units have a fuse that goes out when the Magnetron shorts out, or goes bad. This would require replacing the Magnetron as well as the fuse.
Sep 12, 2009 | Sharp R-326FS 1100 Watts Microwave Oven
Total power loss during use
Check the voltage on the outlet,make sure it is 115v -- 122volts max, any less will cause it shut off, make sure the polarity off the outlet is correct and it is grounded,check all of your wiring connections, if all this is ok replace unit with a different unit or different supplier of unit
Jan 26, 2009 | Microwave Ovens
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Jenn-Air M170 Microwave Died
I would suspect the fuse has blown, probably due to either a loose fuse holder or a shorted high voltage capacitor.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
The fuse is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
It will be a ceramic fuse, probably 20 amps. These can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If yours is blown, I would buy two or three fuses, just to be safe, because you may find that it blows again right away or shortly after hitting Start.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
After you look into this, if you still need help, please write back with more details.
Dec 03, 2008 | Microwave Ovens
Microwave shut-off within 2-3 minutes
Why don't you return it? I think this is a common problem. We returned ours to Home Depot with no questions asked.
Nov 12, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave just went dead
If there is no display and nothing works it may be as simple as a blown fuse. Try that first but unplug the unit before you do anything.
Oct 02, 2007 | Goldstar MA-7100 Microwave Oven
Sharp KB-6015K 1000 Watts Convection / Microwave Oven Logo
137 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
