Question about Bose TriPort Consumer Headphones
Slightly ripped wire
Right where the wires connect to the jack, it's slightly ripped, now i only hear from the right side.
  • Bose Master
  • 5,190 Answers
See my tip on dodgy cable/jacks on headphones. It might apply to your model of headphone.
Posted on Jun 04, 2010
I have a crosley record player, the kind that can play CDs, iPods, tapes, and is a radio too. When I play records either no sound comes out of one side or just static. Both sides get static though. It's...
It's possible that the wires that connect the cartridge where the stylus fits are loose or broken off. With it set to the deck, have the amp on. Lift up the arm and touch the wire connections to the cartridge. You should hear a buzz on each of the channels depending on which wires you touch. You can also disconnect the wires from the cartridge and carry out the same test. On one wire it will buzz on the right, on the other on the left. The two other wires are earths and will cause only a slight buzz or nothing at all. This test proves the pre-amp inside the amp is working. If the wires are connected properly to the right connections on the cartridge, you should hear sound. If the connections are good and the sound poor or absent you need a new cartridge.
Aug 24, 2014 | Audio Players & Recorders
Solder headphone jack
If the wires can be joined see the attached pics for re-joining, just connect the same colours together. Test them to make sure there are no other breaks in the wire. Then solder them together and seal with a waterproof tape or similar. DONT just tape them together this will lead to them coming apart easily.
If they came out of the jack it would be best if you bought a new jack and soldered the wires onto this. Trying to open a factory fitted jack is difficult and you wont be able to seal again properly unless you superglue the jack once you've reconnected it and test them to make sure there are no other breaks in the wire solder the wires to the jack. see attached pics for jack wiring.
Hope this helps
Nov 16, 2013 | ifrogz EarPollution Plugz Headphones
When i plug my headphne and it only hear the left speaker intstead of the right i only hear one side only instead of both sides and when i try to play through my stereo bluetooth and its said you have to...
Sounds like your headphone's port on your phone is the cause.Try connect,disconnect and then reconnect the headphones for a few times to clear it up.
Jul 28, 2010 | Cell Phones
Changing fuel filter .
Just did my 2002 Grand Caravan today,
The filter will come with 3-hoses attached.
Use Safety Goggles to protect eyes from gasoline splash!
1. Disconnect Negative Side of Battery.
2. Depressurize the fuel system.
3. Jack up rear of vehicle. Use Jack Stands to support the vehicle.
4. Chock the front wheels
5. Use Jack with wood and raise up to the fuel tank (just to meet/touch) on the right side (midway portion) of the fuel tank.
6. Loosen and Remove 15mm bolt on middle-right side fuel tank strap-to-body.
7. Loosen and Remove 15mm bolt on rear-right side fuel tank strap-to-body.
8. Loosen and Remove the front 13mm bolt on the front fuel tank strap-to-body.
9. Slightly lower the jack - the right of the tank should begin to drop down 3-4 inches. NOT TOO MUCH: there is wiring connections you may damage!
10: Disconnect the body to fuel tank strap ground from the body.
11. On electrical connections:
a. Slide: Push/Pull back red connector lock.
b. Push on top of release.
c. Pull off the connector.
12. There are three fuel connections/hoses.
a. One on right side - towards the front.
b Two on the top of the tank on the pump. Note how far these are down on the white tubing connections.
13. The fuel connectors are quick connect type. At the top of the connectors are colored protruding tabs. Squeeze those tabs together and pull hose away.
14. If the colored locks remain on the tubes (not the filter hoses) bend the wings away from the tube and this will free them from the tubes.
154 The Filter is connected with a 10mm bolt. Unbolt and remove filter and hoses
When replacing: make sure you fully seat the hose connections. You should hear a click, and observe their position compared to earlier.
Before putting everything back together, reconnect the electrical switch and negative side of battery. Start van and check for leaks.
Nov 16, 2009 | 1997 Dodge Caravan
Help! I only hear the right speaker on my new speakers!!! Do I need a new sound card?
The easiest diagnostic is to plug you USB speakers to another computer.
Connect directly to your computer. Do not use USB splitters
Make sure you wired the second speaker to the first speaker (the one with the controls) and from the first one yo connect to the USB jack directly on the PC.
Open the sound card utility and make sure you are balanced and not muted.
For people with standard miniplug speakers: turn on and at max volume the speakers Get two pieces of wire and connect one side to the shaft of the mini conector and hold with your left hand. Hold the other wire with your right hand and touch the other wire to either of the tip or the middle ring of said connector. You should hear a cracking sound from each of the two speakers That way you will know if one of the speakers is Kaput.
Oct 15, 2009 | HP USB Powered Speakers . Computer...
Telephone wiring- phone rings in once -static on line-call out works Seams to be worst after rain or great moisture. Sometimes clears up suddenky
I have the same problem. You might try taking a corded phone to the service box outside where the telephone line connects to your house. On the underneath side there is a line jack used for test purposes. Plug your phone in there to see if static is heard. If you hear no static from this test jack, but do hear static from in the house corded phones, you probably have a wiring issue inside the house. If you hear static from the outside test jack, that's the phone companies problem to fix. Hope this helps.
Aug 31, 2009 | Panasonic Lands Phones
Which jacks to wire the subwoofer to?
Your receiver should have an RCA connector on the back panel that will be marked "sub woofer" or "LFE out". That connects to your sub woofer with a standard RCA type cable. Also, some powered subs have left and right speaker level inputs and outputs in which you would indeed run the sub woofer through the speaker outputs. The down side of that type of connection is that the line level converter inside the sub woofer will take a slight amount of your receiver's output power, although that is rarely detectable. Also, if you have a Dolby Digital receiver, using this connection method will take away systems ability to accurately control the low frequency effects of a soundtrack.
Good Luck,
BB
May 16, 2009 | Kenwood Audio Players & Recorders
My left side of this headset is not working
those wires are very fradgile and chaces are they have snapped inside the jacket
it happens mostly when you pull on the wire instead of the jack or the wire gets caught or stretched --is your jack fully inside the connecter? wiggle the wire and if it sound than it is the wire
Apr 22, 2009 | Logitech Premium (980445) Headset
Open Questions:
Bose TriPort Consumer Headphones Logo
650 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
