Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv not powering on
My tv's power will not come on. When you press the power button for it to come on, the led light will stay on for approx. 30 seconds and then cut off.
Just check the fuse is in the back open the back panel and follow the cable there is a fuse where the cable ends change it
Posted on Jun 07, 2010
  • 516 Answers
Have your tv checked by a tech your problem is in the power supply or related circuit.check your regulator,along with some caps the microchip.good luck
Posted on Jun 01, 2010
Uniplas 30 power light flashing
See if the torch electrodes MIGHT be stuck... welded together. They have to arc and then separate or unit will shut down.
Jun 15, 2012 | Welding Tools
My panasonic model #TH-50PX75U wont turn on, it powers up but the led light stay on not blinks any time.
Unplug the power cord. Press and hold the power button for 30 seconds, repeat. Plug it back in and try to turn it on.
If this doesn't work, it would be time to call in a repair tech. Is the TV still under warranty? Extended warranty?
Apr 13, 2011 | Panasonic TH-50PX75U Plasma HDTV
Need codes for programing a hitachi tv
The codes are, 0145,1145,...Step 1. Turn the TV on. 2. Press the TV button. 3. Press and hold the SET button until the LED blinks twice, then release. 4. Enter one of the four digit codes, the LED will blink twice. 5. Aim the remote at the TV and press the POWER button, if your remote does not have a power button, press PLAY, the TV should turn off, if not, try steps 1-5 again using a different code....hope this was helpful...
May 22, 2010 | One For All URC-3021 Remote Control
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
Dec 19, 2009 | JVC Televison & Video
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
New JVC flat screen cuts off 10 sec. after cutting on
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
Mar 26, 2009 | JVC LT42P789 42 in. LCD TV
No picture
you have the ATC311 chassis. do this proceedure and you can track down where the problem is. let me know if you need more assistance. i can also post a link where you can get the training manual at a cheap cost emailed to you if you would like a copy.
5. Apply AC power and press power button.
6. If LED turns on and then off, disconnect J11501 (Audio CBA) and press power
button again. If power LED comes on and stays on suspect Audio CBA. If LED
still flashes or does not light go to step 7.
7. Disconnect J26903 (AV IN CBA) and press power button again. If power LED
comes on and stays on suspect AV IN CBA. If LED still flashes or does not
light go to next step.
8. Disconnect J19500 (Convergence CBA) and press power button again. If
power LED comes on and stays on troubleshoot the Convergence CBA. If
LED still flashes or does not light go to next step.
9. Disconnect J14801 (Deflection CBA) and press power button again. If power
LED comes on and stays on suspect Deflection CBA. If LED still flashes or
does not light suspect DM2 module.
Jun 08, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Enter codes for remote R55L8-RCR4358
There are 4 ways to program your remote:
-Brand Code search and entry
-Direct code entry
-Manual Code search and entry
-Auto Code search and entry
*ON TV/VCR(DVD) combos you must program each button individually and that button(ie. TV or VCR/DVD) will program that part of your device.
*the DVD/VCR button programs DVD by default, in order to program it for VCR you must put it into VCR mode:
1.hold down the DVD-VCR button-->the red led will stay lit.
2.while holding down the DVD-VCR button press the number 2 --> the red led will turn off
3.Release the DVD-VCR button--> the red led blinks 4 times and turns off
4.The DVD-VCR button is now set to VCR mode-->program for VCR
BRAND CODE SEARCH ENTRY:
1. turn on device
2. locate brand codes(sorry, I don't have it, try finding genaric RCA codes)
3. hold down the component button--> led should stay on
4. while holding component button, also hold power button--> the led will turn off, then after 3 seconds it will turn back on.
5. release both buttons--> led will stay on
6. enter brand code--> led blinks once
7. press power button repeatedly until component turns off-->each time you press the power key the remote sends a different code for that brand. led blinks once
8. if power on your device turns off press the stop button to save configuration-> led turns off
9. if the led blinks 4 times and turns off, you have reached the end of the codes for that brand, try using a different method to program your device.
DIRECT CODE ENTRY:
1. turn on the device
2. locate your device codes
3. hold component key down-->led lights up and stays lit
4. enter code while holding components key--> as first key is pressed the led turn off, then as 4th digit of key is pressed the led turns back on
5. release component key-->led turns off, try using your remote, if it doesn't have all of the functions you need, try a different code
6. if the led blinks 4 times after entering code you have entered an invalid code, try again.
MANUAL SEARCH AND ENTRY:
1. turn on device
2. hold the component button--> led lights up and stays lit
3. while holding component button hold power button-> led turns off then turns back on after 3 seconds
4. release both buttons--> led stays lit
5. push the power button a bunch of times until the device shuts off-> each time the power button is pressed a different code is sent to the device, the led blinks each time.
6. if the device turns off press the stop button to save your config.
7. if the led blinks 4 times you have reached the end of the code list, there are hundreds of codes, you may be pressing the power button for a while...
AUTO CODE SEARCH AND ENTRY:
1. repeat steps 1-4 of "manual search and entry"
2. press the "play" button--> led blinks 10 times, sending a code each time
3. continue pressing the play button until the device turns off
4. if the device turns off press the reverse key to until it turns back on then press the stop key to save config.
5. if the led blinks 4 times you have run out of codes, try a different method.
Now if someone would please post the codes, or if someone knows the code for a durabrand DVD-1002...
Apr 09, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
138 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
