I want to open my GE 8 cycle 2 speed Heavy Duty Large Capacity top loading washer so I can see why it does not spin or drain. How do I open it up??
  • sharazuck Jun 02, 2010
    I have a GE WWA8800,8816,8829,8837 top loading washing machine. I cannot figure out how to open it up so I can check the pump. It agitates but does not spin or drain. The front + lid case is all one piece, so I have to get into it from the back. Please explain in laymens terms because I am not a DIYer.
    Thank you.
    Shara
    President:
  • 949 Answers
This unit has to be worked on from the back or under it. Most of the time that I had work on the pump for drain issues I would tilt it back against the wall and lay under it.
Here is a website (link below) that will show pictures of the break down to help you understand where the components are located. When you get on the website click the pictures on the left side bar for the different views.
I hope this helps.
GE Old Breakdown
Posted on Jun 02, 2010
    President:
  • 1,554 Answers
The washer will not advance to the spin cycle if there is a draining problem due to a pump problem or clogs and kinks in the drain hose. Check the drain hose and clear it from any obstruction or kinks. Make sure the drain pump is working. Check the drain pump wiring and make sure the connections are snug fit. Reseat the conenctions several times to clean off dirt and corrosion build up in the terminals and connectors. Replace the drain pump if it is not working at all to pump out the water and allow the washer to advance to the spin cycle. Check the lid switch if the washer fills but does not agitate.
The drain pump can be accessed by removing the front panel. The front panel can be removed by inserting a putty knife blade between the top cover and the front panel in alignment with the groove on either side of the lid and cover.
Push the putty knife to release the clips. Once the clips are released, tilt the front panel forward then lift it off the cabinet base locking tabs ad move away from the washer. Reverse the steps to reassemble.
Please indicate the exact model number of the washer if this advice is not applicable for more accurate troubleshooting and repair advice.
Posted on Jun 01, 2010
  • 3 more comments
  • sharazuck Jun 01, 2010
    I'm sorry, but there is nowhere to put the putty knife.
    It is one smooth piece.
    Please advise.
    Shara
  • Jahn27
    Jahn27 Jun 01, 2010
    Indicate the exact model number of the washer for specific tear down procedure. Please be advised the advice provided here are based on first hand experience and on the information provided by the customer. One basic information required is the make and exact model number for quick and precise advice.
  • Jahn27
    Jahn27 Jun 01, 2010
    Here's the exploded view diagram of you washer.
    It will help you determine the components breakdown and how they are
    assembled.
  • olympic43 Jan 30, 2011
    I tried this on my 1998 GE washer. I popped right open and the panel was easy to remove.
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Squeaky washer in spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
How good are you and your tools?
Mar 27, 2009 | GE WBSR3140DW Top Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Jammed agitator
Some further checking indicated a bad transmission. As the unit is 15 years old, I decided the best solution was a new machine! ..
Dec 03, 2008 | Washing Machines
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Won't spin or agitate
coupling.between motor and gearcase.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Aug 31, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
823 people viewed this question
Top Washing Machines Experts
