Question about Mitsubishi VS-60609 60" Rear Projection Television
Line at bottom of screen takes time to clear
The tv comes on but when first turned on there is a line sort of like an interferance at the bottom of the screen it clears after about 15 min of being on and then it looks great. Obviously there is a problem going on and have gotten worse over time. Hopefully I can get an idea of what the problem might be.
  • 505 Answers
If the line is horizontal and kind of rolls up the picture, or you get a dark picture at first, its probably a bad capacitor. there are 2 - 100uf 16v caps that go bad c2p05 and c2p08 on the signal board
if the picture just shrinks, it can be these caps bad, or maybe your pump up cap on the vertical IC
all parts are solder in
estimate = 100-200$
Posted on Jun 01, 2010
Bottom 3/4 of LCD Tv screen vertical lines
John sometimes electrical wires being in the wall or cords laying behind a tv can interfere with antennas, cable, or sat tv cables try to put a little distance between them that's all I got best of luck
Nov 05, 2012 | LG 47LH30 47 in. LCD HDTV
I have a Sentient CCTV System and now all the screens on the monitor have lines going across them as if there is some sort of interference, do you know how to stop this ?
Look for Totally tight cable connections. A break in the grounding causes the interference, usually. It only takes a slight loose connection to have issues.
Jun 28, 2011 | Home Security
Sharp LCD flat screen TV turns on with a grey screen
Whats happening is that the TV' sets of today are really PC's dedicated to a TV tuner..sort of.. As such, well PC's, hang up, get into "Loops" and the like. Also as such they need to be "Reset" to clear any faults, now sometime the circuit called the P.O.R. "Power On Reset", well, it doesn't... and it often takes a couple of "Reboots" to clear the "Fault".
Feb 04, 2010 | Televison & Video
Just had a flat screen plasma installed in our office. When it is powered from the outlet the screen rolls. When it is powered from a small UPS it stops rolling. The electrician said that it is not his...
It sounds like you have some piece of equipment in your office that is radiating AC interference back into the power line. The UPS would act like a filter to clean it up, but the set's power supply is affected when you power it directly from the line. One option is simply to leave the UPS there for the TV. Another option would be to try to determine where the interference in coming from. Find out what other equipment is on the same circuit as the TV and shut each item off one at a time until you see the TV clear up.
Dec 06, 2008 | Televison & Video
Black Lines in picture
You may have a bad cable, bad connection, interference or all of the above. Try wiggling the cable and see if that helps. You could also move any other electronics away from the cable (if possible) and/or change out the cable (cable tv/antenna cable) and see if that clears it up. However, if the line does not appear to have any information in it as though it was just missing then your problem is a hardware issue that will require a trip to tv repair shop.
Sep 24, 2008 | JVC AV-36950 TV
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
I have a pioneer dv656a dvd player and on some dvd's i play on my samsung ps42q96hd plasma tv, it displays horizontal lines that move from bottom to the top of the screen constantly. Is this normal for a...
Try disconnecting everything from the tv *except* the DVD player (that includes cable tv). You are using a component or digital connection, right? Some of these HDTVs are **** at displaying a composite feed. If this clears up the problem then the lines were probably caused by a fault in your cable tv, and you need to take it up with them.
ANYWAY, if the rolling lines remain even with everything else unplugged, it could also be electrical interference from something near by, like power cords or something.
Mar 24, 2008 | Televison & Video
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Mitsubishi VS-60609 60" Rear Projection Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
