Question about Brother MFC-9440CN Laser Printer
Changed colour cartridges but it still says drum error
    Brigadier General:
  • 10,406 Answers
The "drum" is where the laser adds/subtracts an electrical charge to each spot on the drum.
The printer "throws" the powdered-ink at the drum.
The ink sticks to the "charged" spots, and does not stick to the "non-charged" spots.
Then, the printer puts a sheet of paper in contact with the drum, and the ink is transferred to the paper.
Then, the "fuser" heats the paper & ink, and "melts" the ink into the paper.
So, changing the ink-cartridges will _NOT_ fix any "drum" problem.
Posted on Jun 01, 2010
My printer has an error, slide the blue tab on the drum unit. which is the drum unit?
The Drum Unit is the big tray that all the cartridges sit in. Each colour has a slider for cleaning. Take out the toner unit that is having a problem. Look in the cavity the toner cartridge sits in. There will be a plasticcover over the slider. Lift the plastic cover and slide the blue tab all the way to the other side then back to where it was sitting before. Close the cover and re-insert the cartridge.
If it does not specify a colour then do them all.
Apr 27, 2016 | Brother HL-L8350CDW CLR LASER WL PRINTER...
Brother hl-3045 jam inside
Had the same problem, called help center and fixed it!!!
Problem occurred when i tried to print colour labels from Word.
Black cartridge printing worked fine.
When using manual feed (pull down black panel in front which says 'brother'- you'll get the message for this if printing labels
you must open the back door of the printer.
got 'paper jam inside' error message.
Here's what I did and somewhere along the way, something worked.
Turn and unplug machine
take out all drum cartridges (all 4)
Take out the black belt (everything you can remove has a green arrow or tab- easy)
check to see if there's any paper in there- there was no paper in my case.
separate the drum from the cartridge for each colour and check the colour roller and the fuser film roller- don't touch them- no paper stuck that i could see
put them back together carefully.
Put the belt in and then the 4 cartridges
do a test run- mine still showed error message- paper jam inside
switch black with each cartridge and do a test run for each. When i switched with yellow - didn't work, magenta- didn't work- cyan- WORKED!!!- the colours were messed up on the document but it went through and printed without the error message.
Here's the sequence of what colour cartridge went in which spot.
Yellow in black slot
magenta in yellow slot
cyan in magenta slot
black in cyan slot.
then i switched them back to the way they are supposed to be and tried to print again and it worked!
the colour is amazing on this printer- i had the trouble right from the beginning after installation.
hope this helps.
Nov 21, 2012 | Brother HL-3045CN Laser Printer
My Canon lbp 2410 will print in black and white but not colour i have changed the drum cartridge and replace all colour toners Thanks Vicki
Check your printer settings in properties. It may be that the mono black only box is ticked. Untick the box for printing in colour.
May 19, 2011 | Canon LBP 2410 Laser Printer
Lanier LP020c laser colour printer horizontal lines
as if the cartridge is new.and colour is printing fine.then its not faulty cartridge or faulty printer.and yes you are absolutely right that it needs proper servicing.in the printer there are lens one lens is for colour and one lens is for black.if there is dust on the lens controlling black you will get lines and patches in black prinouts.but yes if the drum is got lines on it.that it will give same lines in the printouts.also you can get the drun serviced first before getting the printer serviced.a local printer repair shop does this drum servicing.also there comes a liquid to clean drum.you can get it from printer parts store.if want to do manually.but the shop will get it checked after serving in there printer.so it will be confirmed that is it drum or faulty /dusty lens in the printer. ----------- this will help.thanks.
Sep 20, 2009 | Lanier UNKNOWN
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
I keep getting cartridge error or it prints a blank page. There is no tape on the cartridge and they are installed properly. It prints sometimes but not all the time Printer keeps saying cartridge error
This has been just happening with me aswell - I just changed the colour cartridge with the black cartridge ran out but i kept it in as it told me to place one in. Trying to print out but black ink wont come - just blank pages - surely the colour cartridge can make black? However, if you have the colour cartridge and are on microsoft word or similar, change the colour of the writing to dark navy and it will print out documents.
Aug 26, 2008 | Lexmark P6250 All-In-One InkJet Photo...
Canon IRC3100 colour copier machine error code
Canon iRC-3100 Color Copier is giving Error code E-000021-0001. can anybody help me?
Aug 01, 2008 | Office Equipment & Supplies
Print-out problems
  1. Open the top cover.
  2. Slowly take out the drum unit and toner cartridge assembly.
  3. Push down the lock lever (1) and take the toner cartridge out of the drum unit (2).
  4. Turn the drum unit gear by hand while looking at the surface of the drum roller (1).
  5. Wipe the surface of the drum gently with a dry cotton swab until the dust of glue on the surface comes off.
  6. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in correctly, the lock lever on the drum unit will lift automatically.
  7. Put the drum unit and toner cartridge assembly back into the machine.
  8. Close the top cover.
Mar 31, 2017 | Brother Office Equipment & Supplies
Brother MFC-9440CN Laser Printer Logo
319 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
