How to configure a MP080 motherboard using socket type 7 for a Intel 100 MHz 296-pin SPGA processor(hopeing for a video clip; some sort of visual aid on how to
    Brigadier General:
  • 10,406 Answers
Look at the CPU-socket on the motherboard.
There will be "holes" in only _some_ of the corners of the grid of holes.
It is a 'ZIF' ("zero insert force") socket, meaning that if you have to "push" the CPU to get it into the socket, you are doing SOMETHING WRONG.
Look for a lever on one side of the socket.
Gently pull the lever SLIGHTLY "away" from the socket, to "unlock" it, and then rotate the lever 90 degrees.
Look at your CPU -- there will be matching pins (and omitted pins) at each corner of the grid of pins.
Match the pins with the holes, and put the CPU into the socket. Use that "lever" to lower the CPU into the socket.
Most motherboards will "auto-detect" that you have a 100 Mhz FSB ("front side bus") on your CPU, and the CPU itself will clock itself, e.g., a CPU rated at 2000 Mhz will "multiply" the FSB bus by 20 (2000 == 100 * 20) to drive the CPU at its rated speed.
Posted on Jun 01, 2010
Hi anyone know what graphics card i can use in a hp P4SD-LA (Stingray
Hi patto1974, this is a good Model Graphics Card, for the ASUS Motherboard that you have. ASUS is one of the leading Manufacturers in "Gaming Computers; so you want to have a Graphics Card to compliment the system.
This is the (Model):
Radeon HD 4670
IceQ
Video Card
1GB GDDR3
AGP, DVI, VGA,HDMI
Item#: H231-4678 '
Model#: H467QS1GHA."
You can find this "Model at Tiger Direct, along with other models.
Use AGP x8 as the reference search!
Click here: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6076197&CatId=318
Hope you are satified, paul7of9
Jan 09, 2012 | ATI Computers & Internet
What kind of RAM memory uses this motherboard
Gigabyte GA-5SMM - motherboard - micro ATX - Socket 7 - SiS530 specifications
  • General
  • Product Type Motherboard - Micro ATX
  • Cache Memory L2 cache - 512.0 KB
  • Chipset Type SiS530/5595
  • Max Bus Speed 100.0 MHz
  • Processor Socket Socket 7
  • Compatible Processors 6X86 , Cyrix MII , WinChip 2 , WinChip C6 , K6-III
  • Memory
  • Max Supported Memory 256.0 MB
  • Supported RAM Technology SDRAM
  • Supported RAM Integrity Check ECC
  • Expansion / Connectivity
  • Expansion Slot(s) 1.0 x PCI - Socket 7 , 3.0 x Processor - DIMM 168-pin , 3.0 x ISA , 2.0 x Memory
  • Storage Interfaces ATA-66 - connector(s): 2 x 40pin IDC
  • hope this helps
Aug 13, 2011 | Gigabyte GA-5SMM Motherboard
Hi, I need standard spec info of VGA built on Asus P5GC-MX 1333 whether 64 Mb or 128 Mb. Many thanks & regards, Richard
you can use up to a maximum of 224 mb of your computer's RAM for the onboard video chip to use. You can install a video card with any amount of memory (which would give you a lot better video performance).
Jun 18, 2011 | ASUS P5GC-MX 1333 BULK C2D LGA775 945GC...
My gigabyte motherboard will support single chip 2gb ram and i have to upgrade my ram into ddr2 533mhz to ddr2 667mhz or 800mhz it is possible for my motherboard
Gigabyte GA-945GZM-S2 - motherboard - micro ATX - LGA775 Socket - i945GZ specifications
  • it looke like the supported RAM
  • Supported RAM Technology DDR2 SDRAM
  • Supported RAM Speed 533 MHz , 400 MHz
  • hope this helps
  • General
  • Cache Memory None
  • Chipset Type Intel 945GZ Express / Intel ICH7
  • Max Bus Speed 800.0 MHz
  • Processor Socket LGA775 Socket
  • Max Processors Qty 1.0
  • Compatible Processors Core 2 Extreme , Celeron D , Core 2 Duo , Pentium D , Pentium 4
  • Memory
  • Max Supported Memory 2.0 GB
  • RAM Features Dual channel memory architecture
  • Graphics
  • Graphics Controller Intel GMA 950
  • Memory Allocation Technology Dynamic Video Memory Technology 3.0
  • Audio
  • Type High Definition Audio (8-channel)
  • Audio Codec Realtek ALC888
  • Compliant Standards High Definition Audio
  • LAN
  • Network Controller Marvell Yukon 88E8001
  • Network Interfaces Gigabit Ethernet
  • Modem None
  • Expansion Slot(s) 1.0 x Processor ( 1.8 V ) - LGA775 Socket ( x4 mode ) , 4.0 x PCI Express x16 - DIMM 240-pin , 3.0 x Memory , 1.0 x PCI
  • Storage Interfaces Intel ICH7 : ATA-100 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s) , Intel ICH7 : Serial ATA-300 - connector(s): 1 x 40pin IDC - 2.0 device(s)
  • Interfaces 1.0 x Audio - Floppy interface - Mini-phone stereo 3.5 mm , 1.0 x Storage - Line-out - 6 pin mini-DIN (PS/2 style) , 1.0 x Audio - RS-232 - 25 pin D-Sub (DB-25) , 4.0 x Serial - VGA - Mini-phone 3.5 mm , 1.0 x Microphone - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Keyboard - Generic - 6 pin mini-DIN (PS/2 style) , 1.0 x Display / video - IEEE 1284 (EPP/ECP) - 4 pin USB Type A , 1.0 x Audio - Line-out (center/subwoofer) - Mini-phone 3.5 mm , 1.0 x Network - Generic - 34 pin IDC , 1.0 x Parallel - Line-out (side surround) - RJ-45 , 1.0 x Audio - Line-in - Mini-phone stereo 3.5 mm , 1.0 x Hi-Speed USB - Line-out (rear) - 9 pin D-Sub (DB-9) , 1.0 x Audio - Input - Mini-phone stereo 3.5 mm , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX/1000Base-T - Mini-phone stereo 3.5 mm , 1.0 x Audio - 4 pin MPC
Apr 09, 2011 | Gigabyte GA-945GZM-S2 Motherboard
What type of video card can I use on this motherboard? D945GZIS AGP? PCI? PCI EXPRESS?
Your MoBo has (1) of each PCI Express x1 & and PCI Express x16 slots, and (2) standard PCI slots. There are NO AGP bus slots on this board. You'd want to use buy a PCI Express x16 video card instead of a PCI video card due to the better performance offered by the PCI Express cards.
The full details of your motherboard are below:
Product Description The Intel Desktop Board D946GZIS delivers an integrated graphics solution in the Essential Series by combining exceptional value with quality and reliability and supports Intel Core2 Duo, Intel Pentium D, Intel Pentium 4, and Intel Celeron D processors with 1066/800/533 MHz system bus in the LGA775 package. This board features a PCI Express x16 connector, integrated 10/100 LAN, dual-channel DDR2 memory, Intel High Definition Audio (Intel HD Audio) and up to eight USB 2.0 ports.
Processor Model: D946GZIS Chipset Type: Intel 946GZ Express Processor Socket: LGA775 Socket Installed Qty (Max Supported): 0 ( 1 ) BIOS Type: Intel Storage Controler: ATA-100
Memory RAM Installed ( Max ): 0 MB / 4 GB (max) Supported RAM Speed: PC2-4300, PC2-5300 RAM Features: Unbuffered, dual channel memory architecture
Audio Audio Output: Sound card Sound Output Mode: 5.1 channel surround Compliant Standards: High Definition Audio
Expansion / Connectivity Expansion Slot(s): 1 PCI Express x1, 1 PCI Express x16, 1 processor - LGA775 Socket, 2 PCI, 2 memory ( 1.8 V ) - DIMM 240-pin Interfaces: 4 x Hi-Speed USB - 4 pin USB Type A, 1 x serial - RS-232 - 9 pin D-Sub (DB-9), 1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25), 1 x display / video - VGA - 15 pin HD D-Sub (HD-15), 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45, 1 x audio - line-in - mini-phone stereo 3.5 mm, 1 x audio - line-out - mini-phone stereo 3.5 mm, 1 x microphone - input - mini-phone 3.5 mm, 1 x storage - floppy interface - 34 pin IDC, 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style), 1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
Nov 03, 2010 | Intel D915GAV Motherboard
My mothar board are pspe.vm so i know which ram add my mothar bord 512mb ya 1 gb ya 2 gb sopart my motharbord
ASUS P5PE-VM - motherboard - micro ATX - i865G specifications
General
Product type (AE)
Motherboard
Form factor
Micro ATX
Width
9.6 in
Depth
7.6 in
Pentium 4 , Celeron D , Core 2 Duo , Pentium D
64-bit Processor Compatibility
Yes
Mainboard processor socket
LGA775 Socket
Mainboard / Multi-Core Support
Dual-Core
Chipset Type
Intel 865G / Intel ICH5
Data bus speed
800.0 MHz
BIOS type
AMI
Storage key information
Serial ATA-150 , ATA-100
Power connectors
4-pin ATX12V connector , 20-pin main power connector
Processor
0.0 ( 1.0 )
Memory
Cache Memory Type
None
DDR SDRAM
Non-ECC
0.0 MB / 2.0 GB (max)
Supported RAM Speed
PC2700 , DDR266/PC2100 , PC3200
RAM Features
Dual channel memory architecture , Unbuffered
Video
Graphics Controller
Intel Extreme Graphics 2 Dynamic Video Memory Technology 2.0
Audio
Audio Output
Sound card
Signal processor
Intel 865G
Audio codec
AD1988
Sound Output Mode
Telecom / Networking
Modem
None
Networking
Network adapter - Marvell Yukon 88E8001 - Fast Ethernet , - Ethernet , - Gigabit Ethernet
Features
BIOS Features
SMBIOS 2.3 support , ASUS EZ Flash , WfM 2.0 support , ASUS MyLogo , Hyper-Threading Technology , DMI 2.0 support
Manual Settings
CPU frequency
Sleep / Wake Up
Wake on LAN (WOL) , Wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall) , Green Edition , CrashFree BIOS 2
Expansion Slots Total (Free)
1.0 AGP 8x - LGA775 Socket , 1.0 Memory - DIMM 184-pin , 3.0 PCI , 2.0 Processor
Storage Interfaces
Intel ICH5 : ATA-100 - connector(s): 2 x 40pin IDC - 2.0 device(s) , Intel ICH5 : Serial ATA-150 - connector(s): 2 x 7pin Serial ATA - 4.0 device(s)
Interfaces
1.0 x Audio - RS-232 - Mini-phone stereo 3.5 mm , 1.0 x Network - Generic - 34 pin IDC , 1.0 x Parallel - IEEE 1284 (EPP/ECP) - Mini-phone stereo 3.5 mm , 1.0 x Keyboard - Line-out (center/subwoofer)/line-in - 4 pin USB Type A , 1.0 x Audio - Line-out - 6 pin mini-DIN (PS/2 style) , 1.0 x Serial - Generic - 25 pin D-Sub (DB-25) , 1.0 x Mouse - Line-in - 6 pin mini-DIN (PS/2 style) , 1.0 x Hi-Speed USB - Ethernet 10Base-T/100Base-TX/1000Base-T - Mini-phone stereo 3.5 mm , 4.0 x Audio - Line-out (rear)/microphone - 4 pin MPC , 1.0 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1.0 x Storage - Floppy interface - 9 pin D-Sub (DB-9) , 1.0 x Audio - RJ-45
Additional connectors (optional)
4 x Hi-Speed USB
Miscellaneous
Compliant Standards
RoHS , Plug and Play
Hope this helps,
If I have helped you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well Thank
you.
Oct 23, 2010 | ASUS P5PE-VM Motherboard
Need to know bus speed of Trigem Cognac MB used in HP Pavilion 6730. Is it 100 MHz or 66 MHz?
it's 100 other info as follows:
Component Attributes RAM (standard) 64 MB SDRAM standard Maximum 256 MB (2 x 128 MB DIMM) Speed 100 MHz synchronous Sockets Two 168-pin DIMMs Size 16, 32, 64, and 128 MB DIMMs Type Supported SDRAM, 100 MHz, Intel PC SDRAM unbuffered DIMM specification, revision 1.0 compliant
Cache Level Quantity Level 1 (Primary) 32 KB (on processor) Level 2 128 KB (on processor) Upgrade Sockets None
Dec 09, 2008 | Computers & Internet
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
IS DDR SDRAM IS DDR II RAM OR DDR
No. DDR replaced the SD in RAM so SDRAM and DDR RAM are two completely different things but each ram type has its own frequency hence you get SDRAM 100(mhz) and SDRAM 133(Mhz) just like you get DDR 1 RAM at 266(mhz) and 400(mhz) and DDR 2 RAM at 533(mhz) and 800(mhz). Therefore as you can see how these things differ, but if your mboard takes SDRAM that it can take and frequency of SDRAM but you must ensure that all the frequencies of all your RAM modules in all your slots correspond otherwise you will have problems, meaning that if you decide to use 133mhz RAM then all your RAM modules that you use must be the same. Let me know how you go. thanks
regards
Feb 06, 2008 | Intel D101GGC Motherboard
85 people viewed this question
jasbo
jasbo
