Over spray Roland sp-540v? cyan only
I have a roland sp-540v with an overspray issue. i know its not static because the other colors print fine.just cyan for some reason is poor quality and oversprayish.i've replaced the wipers,dampners,and the cap top. given it several powerful and manual cleans. i've also tried putting solvent on the cap top and let it sit over night..do the test print it looks fine but when i need to print an image just over spray and really poor quality in the cyan only.getting frustrated what should i do now?
4 Suggested Answers
SOURCE: I have a Roland SP-540V printer and I keep getting
hi have had the same problem, you need to clean the data strip that is connected to the main cutting head .its a clear looking plastic strip between 2 other strips you can't pull it all the way out so be careful. just wipe it with a clean cloth you will see black soot like powder come off it, as soon as you do this it should be back to normal, repeat weekly and you should be ok.
Posted on May 20, 2010
SOURCE: When printing backlit on the Roland SP 540V I get
your room environment must not be over 40degrees Celsius.
Posted on Apr 24, 2009
  • 3 Answers
SOURCE: roland sp-540v will not print
you have a ink problem first check your pump is working read your manual cleaning prints . if heads are blocked get your old ink in waste and pour small amout on the heads to unblock them you might have to do it a few times put back together leave overnight and do a powerful clean and you may have to repeat  afew time read your manual its shows you how to pull apart
Posted on May 01, 2009
I have a roland sp-540v, trying to print on banner material with black backing. Keeps on getting message to setup sheet while everything is loaded correct. The sensor is probably not picking up black.
Could you try
(1) Temporarily stick a white strip over the sensor where it detects the media or
(2) On the length of the media or
(3) Even staple same sized white media below the black one which you can un-staple after printing.
kindly ignore if these are (s) tupid answers
Mar 23, 2016 | Roland VersaCAMM VP-540i
Distorted printingting
hello
try to clean the Encoder strip of your sp540, gently with alchool isoprophilic
i add a video explaining (the procedure and the result is the same for sp540) i hope this is helpfull. good luck
Feb 04, 2014 | Roland VersaCAMM SP-540V
Continuosly getting pinch roll error (invalid right position) on Roland versacamm sp-540v
if the problem is persists you have to replace the data cable connected to the head ( this cable goes foward and backward with the movement of the heads and sometimes it brokes ) i had the same problem and the solution is this.
Jan 31, 2014 | Roland VersaCAMM SP-540V
I have roland verscamm sp-540v when i switch on then error comes service call 0101
the 0101 error in sp540 is the Limit Position Initialize has not been done. you find videos on you tube that can help you to do the limit position operation. (you have to enter in Service Mode Menu) its easy to do it yourself. i hope this help.
Dec 24, 2013 | Roland VersaCAMM SP-540V
I need a driver for Roland VersaCAMM SP-540V for windows 7
IF I CAN REMEMBWE YOU CAN DOWNLOAD IT FROM THE ROLAND SITE
Nov 17, 2013 | Roland VersaCAMM SP-540V
I have roland verscamm 540v when i sub switch on
hello m f azam
have u solve the problem already?
Aug 20, 2013 | Roland VersaCAMM SP-540V
I need drivers windowS 7 for Roland VersaCAMM SP-540V
hello
i add a video explaining how to install sp540v in win7
u need to install the Intercon-NetTool (that u can download from the Roland website) to allow the comunication with the plotter. its all well explained in the video. good luck
Feb 27, 2013 | Roland VersaCAMM SP-540V
Roland SP 540v with Eco Sol Max ink. ... When printing large solid colors, especially blues and light blues, there seems to be an ink supply weakness that shows up in soft-edged stripes in the direction of...
Inhae had similar issues, I corrected it by slowing down the print rate to 250mm per sec and also doing a calibration to the messy used if all else failed calibration wise I used textile heat transfer profile for printing on both banner and vinyl hope this helps
Sep 21, 2010 | Office Equipment & Supplies
All four colors wont print roland sp300v
you print head is dry out. Normally, it happened on Magenta and Cyan colors.
Apr 09, 2010 | Office Equipment & Supplies
752 people viewed this question
jasbo
jasbo
