Question about NetGear Computers & Internet
My router isnt streaming the internet and i tried to reset it
  • 4,281 Answers
For RESET router press RESET button for 10 seconds then all settings goes to defaults.
Then you need to configure your router again.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jun 01, 2010
Wifi streaming very slow to some device
So, If you have internet connection speed problem with your wireless try with the following steps,
  • Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
  • Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
  • Get as close as possible to the router with whatever device you're trying to connect.
  • Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
  • Adjust the WiFi antenna if it has one.
  • Change the router's channel, especially if other wireless routers are nearby.
Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from ScanMySpeed.com before and after following these steps.
Feb 06, 2015 | Televison & Video
Cisco Valet m10 quit working but all the lights are on
I think you should try to reset and reconfigure the router.
Connect the computer directly to the modem and make sure that you can access the Internet through the modem.
Connect the modem and computer to the router.
Reset the router to factory default settings.
Open the setup page and change the settings on the router.
See Linksys router setup without CD.
See How to reset Linksys router.
Mar 03, 2012 | Computers & Internet
My belkin N600 router will not connect to my internet
Router should be connected via RJ11 cable to the phone socket to get internet service. Check the RJ11 cable at the back of the router. You can try to use a different RJ 11 cable for isolation or try to use the cable that you are using at the back of your phone. You can also check if you are getting a dial tone on the phone as well.
thanks and kindly rate this post
Jan 03, 2012 | Belkin Play N600 Wireless Dual Band Router...
ROUTER WONT CONNECT NO MORE IT SAYS THERE IS NOW ETERNET CABLE
Have you tried updating the driver? search..type in device manager...............right click on the network adapter and choose update
Sep 05, 2017 | Belkin F5D72344 Wireless G Router 54Mbps...
Connectivety
Usually the default password is admin with no username . If that didnt work , the only option you can do is reset the unit to factory default.
It will reset your password but also reset your router to factory settings. You will need to setup again your router to connect to the internet.
Cheers,
KJ
Jun 30, 2010 | Linksys Wireless-G WRT54G Router
No internet connection to main computer when router connected
If you are getting lights on the Internet LED. Go to the router's setup page 192.168.1.1 and put in your username and your password if you are on DSL. For cable connection try to reset your router by resetting the router
Jun 04, 2009 | Linksys Wireless-G WRT54G Router
No instructions on used router
connect existing modem to the router
reset router (located at the back)
connect computer to one of the 4 ports of the router
run internet connection wizard & choose "computer is connected to a gateway / internet connection is always ON"
Jan 24, 2009 | Linksys Wireless-G Broadband Router
Downloads time out
Most routers have a reset button. This will reset the router back to the factory defaults. I suggest trying this and see if it helps. If so, then check belkins site and see if you can upgrade the firmware so this will not happen again, hopefully.
G'luck
Nov 11, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
35 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
