Question about Kingston 2GB Secure Digital Memory Card
I bought a a sd mini card and adapter there are pics on it and when i insert it it say it needs to be formated,i dont want to loose my pics ..what do i do?
    Brigadier General:
  • 10,406 Answers
How do you know that there are pictures on it?
Search online for "file recovery camera memory card" for utilities that will read, block-by-block, the entire memory-card, and try to "recover" the pictures.
Compare it to a textbook with a missing "table-of-contents" -- you can still read each chapter, and probably can rebuild the table-of-contents, after you read the whole textbook.
Posted on Jun 01, 2010
Forgot my memory card pasword
To format your SD card you need the following SD card, SD memory card adapter, SD card reader on your P.C. first insert the memory card into card adapter, insert the adapter into the P.C, click start>my computer> Secure Digital (SD) card and then navigate into the folder named system folder, open the sub-folder MMCstore and you should be able to see your password and recover it, If you want to reset your password you should just format SD card by clicking start> right click on my computer and select manage> Disk management > go to your SD card, right click on it and select format and then start format.
Jan 10, 2013 | SanDisk 4GB microSDHC Memory Card
I recently bought the vivitar 7024 and bought an sd card lexar multi use 4 gb. For some reason when I take photos and try to look at the pics it says no file exist. But when I take the sd card out and I...
Apparently, you have pics on the camera's internal memory. Your card won't work until those pics are gone. Here's how...with no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work.
Aug 18, 2011 | Vivitar ViviCam 7024 Digital Camera
I have a hp photo smart 385 and I am trying to download my pictures from my cell phone. I have tried using a micro sd, samsung micro, and a sundisk adapter and all have come back with disk error. help
What type of phone is it? Some (most?) phones will not connect to PC etc. without special software. Did you format the SD card before trying to use it.? Using SD? - format SD first before inserting to phone for photo copying. If pic are stuck on SD card, there are SW which can do file recovery on it. Some free. Last thing to consider, what format are pics? Is format compatible w/ printer?
Nov 08, 2010 | Computers & Internet
My mini sd card is in raw format and my computer can't read it - how do i change it back to fat file system ?
  1. Place the mini-SD card within the mini-to-SD card adapter. Make sure the tab on the mini-SD is facing the upper side of the adapter. Slide it in slowly, being careful not to damage the pins.
  2. Slide the adapter in an SD slot on your computer. If you do not have an SD slot, place the adapter in a USB card reader, and plug that into a USB slot on your computer. Give the computer time to read the card.
  3. Open "My Computer" (usually located in your start menu) and navigate to your mini-SD card. It will usually be recognized as a drive such as "E:" or "H:."
  4. Right-click on the drive and select the "Format" option. A menu window will open.
  5. Make sure that the drive size is set correctly, and that it is set to the file system you wish to use (usually FAT32 on an SD card). If you don't know what file system you should use, just leave it at the default setting.
  6. Enter a volume label, which is the name for the drive, then press start. This process should only take a few minutes.
WARNING
  • Do not use the "Quick Format" option unless you have just recently formatted the mini-SD card. "Quick Format" doesn't completely erase all data and is not effective unless used after a full format.
  • When you format your mini-SD card, all of the data on it will be erased. Make sure to back up your files on the card before formatting
Sep 25, 2009 | Electronics - Others
How do I format the mini sd card for my at&T LG Xenon Gx500
You can format your sd card through card reader to attach the computer by format command or you can also format the card through format command in dos.
C:\> format :drive name
Sep 23, 2009 | LG Xenon GR500 Cell Phone
Using wmp to sync to mini sd card for a moto ve240 mp3 player
the device has to format the card. at this time the phone will create folders for music, videos, images, and what not. now when you insert the card into your computer you will open the card and copy the files to the music folder. this will allow access to the files from the handset visual platform.
Good Luck and please rate this solution!! :D
Mar 19, 2009 | Motorola Cell Phones
Sandisk Adapter Problem in a HP Laptop
If you install SP3 it may work as SP3 updates the index parameters for file size limitations within such an old OS.
Oct 11, 2017 | Electronics - Others
SanDisk Micro SD Card problems.
the card needs to be formated on n73.
if still not work than the card is faulty
Jun 05, 2008 | SanDisk Electronics - Others
From cell to Pc
Hi Big Bran,
There are 4 methods to transfer pics n videos from mobile to pc. They are through :
1) Bluetooth
2) Infrared Device
3) PC suite via USB data cable
4) MMC reader. ( memory card reader)
I think u r new user of this mobile phone. For u, I recommend u to use Memory card reader. It is very easy and fast.
Process : Take out memory card of ur mobile and insert in the MMC reader. ( It is easily found in the market and they provide u with adapter like a micro SD memory card to insert ur mini Memory card in it ). Join the MMC reader fitted with ur MMC in PC. Now, it shows a new drive like as CD drives. Now copy or transfer pics or mp3s or videos via it like u do in other drives(pen drives, floppy drives).
I think u may have mini Memory card. For it to be fit in MMC reader, u need a small casing adapter which is like a micro SD memory card. INsert ur MMC in it, and ur drive will be shown.
Looking for ur kind feedback,
SAJAN (sajwhat_2003@yahoo.com)
May 05, 2008 | Motorola Mobility RAZR V3
Kingston 2GB Secure Digital Memory Card Logo
120 people viewed this question
Top Kingston Electronics - Others Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Tony
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
