Question about LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone
How to fix the charger socket
Charger socket broken on kp500, how much will repairing it cost
  • 516 Answers
If you can go to LG Service Center the only solution in your problem is to update the software of your lg cookie...
THis wil work! i had done it
Posted on Jun 01, 2010
Charger not staying put
Sounds like the socket is faulty, probably broken the supports inside the case. Only way to fix it is to take it apart and either repair the socket or fit a new one. It could be quite expensive depending on how much of the laptop needs taking apart. I repair them quite often but am in the UK people pay anything from 60 dollars to 150
Feb 04, 2012 | Compaq Presario CQ60-220US PC Laptop
My lg kp 500 wont charge what should i do
Hi keiran89,
The problem might lye within the charger of the mobile phone. make sure the charger is inserted firmly into the walk socket. make sure the end of the charger is dusted off.
i hope this helps, good luck!
Mar 15, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
The audio socket on my Nokia 6613 cell phone is broken inside the phone where the pin end of the charger plugs in. How can i repair this?
Its simple, provided you have a phone screw driver and you know a store where you can buy the audio broken socket and the pin end of your charger.
Turn off the phone, remove the battery, loose all the phone screws and carefully remove the phone cover. Locate the broken parts and buy a new one and do the replacement.
If I am not mistaken, what you are referring to as "pin end of charger" is called charging port.
If you can't get any of the above fixed, then I would advice you give it to an an expert to do for you. But try is yourself, its very simple but you just need to be careful. You can start learning for there.
I wish you the best.
Dec 16, 2009 | Computers & Internet
Laptop wont switch on. power light not on nether when charger plugged in,charger light is on ,on charger
A commom power problem with laptops. To determine if it is the power socket on the laptop is the problem, plug in the adapter into the laptop and wriggle the plug and look at the charge/power LED on the laptop. If the LED flashes as you wriggle the plug then :-
The problem is the power socket on the laptop, it may caused by a dry solder joint and needs to be resoldered or the power socket may be faulty and needs to be replaced. Either way to fix this, it requires the laptop to be dismantled to get at this power socket. Get a quote to repair, as it could cost a few dollars.
If it is a faulty cord/plug on the power adapter, this can be checked with a multi-meter. When you connect the multi-meter probes to the power plug the voltage should be steady and the reading should be slightly higher then the voltage that is printed on the label on the bottom of the power adapter. If the voltages fluctuates as you wriggle the plug then you have a broken wire in the plug. Replacing the plug would not cost much.
If these tests did not resolve your problem, then you could have a motherboard problem. A replacement motherboard may not be a cost effective solution. It may be better to put your money towards a new laptop.
Jul 02, 2009 | Advent Computers & Internet
My charger is not fitting the phone, seems a hardware problem with the charging socket in the phone. Can the socket where the charger is connected be replaced/repaired?
you should chage the charger and buy right charger for long life of your mobile... dont use alternate...it will harm your mobile
Apr 27, 2009 | Nokia N72 Cellular Phone
Broken socket for charger - Esprimo mobile V5515
you have to prise the keyboard out, then prise off the strip of plastic at the top. It's not a nice thing to have to do...
I had the same problem with the charger socket :(
Mar 29, 2009 | Fujitsu Siemens Computers & Internet
KP500 not charging
You can also do an inexpensive work around.
Buy an external battery charger and an extra battery. This will give you the ability to charge the kp500 battery separate. The extra battery will ensure you always have one charging and ready to go.
Check out the following link to see the avaiable options
LG Kp500 Cookie External Battery Charger
Mar 07, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
MY MOBILE PHONE CHARGING SOCKET HAS SNAPPED
You have 3 options when the charge port breaks.
1. get it repaired, warrant if possible
2. Get a new one
3. Get an external battery charger and charge battery separate from phone. Another battery and charger will set you back about 10 dollars on ebay.
For more information and links to the parts check the following link below.
Fix for Broken Charge port on Samsung SGH-D900
Mar 07, 2009 | Samsung SGH-D900 Cellular Phone
LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone Logo
183 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
