Question about Kenmore Washing Machines
HOW DO I GET TO THE BLOCK,BASKET,DRIVE ON A KENMORE 80 SERIES WASHING MACHINE
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Then see the following illustrated description:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=6b1146624f61fdea7417003c1fca58df
NOTE:
You don't have to buy a special spanner wrench ($20) to remove the spanner nut. I've used a short 10" pipe wrench (about
$9.00 also good for cracking walnuts) hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it
should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
Also see the following Whirlpool / Kenmore Service manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Jun 01, 2010
There seems to be a sock or something stuck in the washer machine, Kenmore series 80, Model 110 26832690. It started leaking so we turned it off. How do we remove a sock from the washer? Can we remove...
First, see the Sears parts diagrams / breakdowns for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11026832690/0582/0153200?pathTaken=
Next, see the following illustrated description of how to tear down the washer and remove the agitator(s) and tub.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=34f87d06c7e28f58d4898529d732dedb
And see the Whirlpool / Kenmore Service Manual for these machines.https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It's unlikely that a sock made it thru the inner basket but, I'd check the hoses to and from the pump and the inside of the pump to check for any blockage before pulling the agitator(s) and basket.
NOTE: If you have to remove the inner tub, you'll have to remove the drive block.
You don't have to buy a special spanner wrench ($20) to remove the spanner nut. I've used a short 10" pipe wrench (about $9.00 also good for cracking walnuts) hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
When replacing the drive block, basket, make sure that the tabs align on the block.
Oct 23, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series top load washer. Will work on
if that arm is white and inside your clutch assy,that is the brake release arm that releases the brake to allow the basket to spin. it has 2 little fingers on it that lineup on the brake release cam, also check the bottom of yuor basket drive tube see if it has worn down or if the clip is there that holds that arm in place
Feb 21, 2010 | Kenmore Washing Machines
My kenmore 80 series inner tub is banging when it spins. It seems loose. Any suggestions?
There were a few of those where that would happen. The basket drive would come loose. Some had the drive block break. But either way you will need the spanner wrench to fix it.
Dec 30, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 110 model 80
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Two things to check are the Basket Drive Block and the Brake and Drive Tube.
The clutch on the transmission drives the Brake and Drive Tube when in spin mode, the Basket Drive Block transmits the spinning of the Drive tube to the tub.
See the following description of how to pull the cabinet, agitators, drive block and drive tube.
As an aside, you don't need to buy a special spanner wrench to remove the Drive Block Basket Lock Nut. I found that by using a short 10" pipe wrench, opened all the way and hooked over one of the tabs on the nut, and giving it a short whack with a hammer, the nut will come loose.
Check that the basket drive block fits on the drive tube with the two tabs on the drive tube fitted into the slots in the drive block.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Will not spin
Check the motor coupler, or the drive block may be spinning on the basket drive. Some of these would break loose. Eric
Sep 08, 2009 | Kenmore 24032\24036 Top Load Washer
80 Model will spin sometimes -with help- but never fast
Likely the out of balance sensor is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Loose basket
the block drive is worn..
Dec 27, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80- spin cycle does not spin
possible bad bearings in basket support asm or bad basket drive asm both pretty big jobs
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE SERIES 80 BALANCING PROBLEMS
Wiz, That black piece of foam is just a sound dampening strap, no big deal. This is a hard one, I see a lot of these vibrate when there is a false floor. Here are some things to check: makes sure the front legs are locked with the nut. Check to see that all the springs are attached and the plate is centered, I will attach a photo. Depending on whether the machine is walking or just the tub banging, it could be the drive block for the basket. You will have to remove the cabinet or tip it back to check the springs. Catriverdf505ed.jpg
Jan 28, 2008 | Washing Machines
Washing Machines Logo
70 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
