Question about Magic Chef Microwave Ovens
I have Magic Chef Microwave ModelMC160Ub. It just stop working. The key pad is not working at all.
  • villi_sachin Jun 01, 2010
    Yes. I will have to call the technician to replace fuse or control panel.-Thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the door switch as if the door switch is stuck/faulty the microwave will be dead. However, from what you have described it appears to be either the interior fuse that needs to be replaced and/or the control panel that has gone bad and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 01, 2010
My magic chef microwave starts but immediately stops light work tho
No solution but keep it unplugged until you find one. Some units can cause a fire.
Feb 14, 2013 | Magic Chef CMV1000B Microwave Oven
Microwave key pad won't work
That is a failed membrane keypad.
It is part number 3518522640B and you can order it from the Pros here.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this repair for you, we do that for $39.95 plus parts.
Aug 22, 2012 | Magic Chef Microwave Ovens
The touch pad is freeze, only shows 8888. Magic Chef Microwave Model MCO160UB
try gliding your fingers over the touch pad to see if any other buttons work , #8 is stuck, or shorted
Mar 19, 2010 | Magic Microwave Ovens
I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
Dec 23, 2009 | Magic Chef CMV1000B Microwave Oven
Key pad not working
First of all try this - - unplug Microwave and remove the back panel to gain access the the control panel. There is a ribbon connector that connects keypad to control. Remove the key pad from control and use a pencil eraser and clean the end of this ribbon connector wher it fits into control . Reconnect and see if that corrects the problem, If this will not works then You'll have to replace the control (key pad control).
Good Luck!!
Thanks
Aug 24, 2009 | Magic Chef Microwave Ovens
1992 magic chef (panasonic) microwave. Model M15E-5B. In a RV with very little use. Ran empty. 5 seconds blue flash at top of oven. Panel lights but only time pads work. Seconds, minutes, ect. Fix with new...
Try this site, it has the best advice on almost ANY microwave problem you can have, I know I read something almost identical to your prob. here:
http://www.repairfaq.org/sam/micfaq.htm.
Mar 31, 2009 | Magic Chef CMV1000B Microwave Oven
The Display on my microwave says "LOCKED"
The control lock shuts down the control panel pads to avoid unintended use of the microwave oven. To unlock/lock control, the microwave must be in standby mode, touch and hold stop/clear for 3 seconds until one long tone sounds and the display clears to show an outline if the display area. Repeat to unlock control, and return display to the time of day, if any pad is touched while the control is locked, there will be no response from the microwave oven. hope this helps.
Mar 28, 2009 | Magic Chef MCM660A Microwave Oven
Magic chef micro key pad does not work
Try this site - It has answers to almost anything that can go wrong with a microwave, I know I read something there almost identical to the problem you mentioned:
Mar 24, 2009 | Magic Chef CMV1000B Microwave Oven
Magic chef touch pad doesnt work
I don't have Magic chef, however, I would try hitting cancel, unplugging the microwave and waiting a few minutes, then plugging it back in to reset it. Alternatively, you could go to your manual under troubleshoooting. I wish that I could help you more with this. Good luck to you. Please let me know if you figure this one out.
Jul 31, 2008 | Emerson MW8626W Microwave Oven
Over the Range Microwave Oven
my microwave oven have inside a a metal papel i remove becouse sparks when turn on .this pece of paper is necesari
thanks
alexas
Jun 15, 2008 | Magic Chef MCD1311ST Microwave Oven
Microwave Ovens Logo
53 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
