Question about Amana Refrigerators
Amana Bottom Freeze unit - BR22T. The freezer portion of my unit stopped freezing a few days ago but is still cold ( about as cold as a fridge on 3/4 setting. The top unit has been working fine but now is not keeping its cold, i.e milk starts to spoil before its expiration date. I have both sections at 6/7 setting. I pulled out the unit and vacuumed the coils as well as removed the back panels and vacuumed around the fan and coils on the back. I noticed some corrosion on the back copper lines, but no signs of leaking. As far as I can tell the fan and the condenser unit seem to be operating, as the unit cycles on and off. About to call for repair but wanted to get an idea of what to expect. My fridge is about 10 years old. Nowadays would it make sense to repair or just buy a new fridge. Thanks for any advice.
  • mrbones700 Jun 01, 2010
    looking to see what the problem may be and the cost to fix
  • mrbones700 Jun 02, 2010
    Very helpful with the steps listed to check what the problem might possibly be due to.
  • 1,284 Answers
Hi, you check to see if the fan is working and for ice on the back wall (for defrost problem). Then you most likely are low on freon or you have a bad compressor. Check to see if the compressor is running (IF scorching hot its bad too) . Next check to see if the coils under the unit are hot. They should be so hot you cant hold onto them. Just touch for a second. If they are just warm, then you are low in freon.
Take care
Posted on Jun 01, 2010
    Thanks for the information. Is replacing freon an expensive process? I'm about to buy a new fridge if so. thanks.
    President:
  • 4,070 Answers
Hi! 10years of service is quite good. Repair will surely cost you, buying a new one is better plus refrigerators today are efficient specially when it comes to electric bills. Maybe its time for an upgrade. Hope this helps and have a good one!
  • dj_relly999
    dj_relly999 Jun 02, 2010
    Good luck on this!
Amana fridge stopped working for 2 days
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 03, 2012 | Amana AFF2534FE Bottom Freezer French...
Refrigerator side too cold
refrigerators only have one cooling system and that is for the freezer. The fridge part is cooled by sending a portion of the air from the freezer to the fridge. your fridge thermostat controls a fan that turns on and off as needed. first step is to make sure this is working, and not stuck on. turn your fridge to a somewhat warm no and open the door for a few minutes to allow the cold air out then check and see see if it gets very cold again within say an hour. if it does your fan is always on and you need to repair it. if that is working then you have to play with both freezer and fridge settings. best thing is to get a cheap thermometer and check your freezer temp. it should be around 0 to -5f if it is colder than that frigid air blowing into your fridge too cool the whole area will freeze anything close to the vent. once you have your freezer set then start adjusting your fridge. personally I have mine set at 34f knowing that some things on the top shelf will freeze. but I like my cola's COLD. so I put things like butter that are harder to freeze at that level. but if you don't want anything to freeze then a temp of 37 -39f is correct for your fridge. so it comes down to freezer temp, the amount of time the fan is on, and proximity to the vent. good luck
Nov 28, 2011 | Cars & Trucks
Amana fridge is not cold
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 26, 2011 | Amana ABB1927DE Bottom Freezer...
The freezer section won't freeze
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 30, 2010 | Amana ABB2227DE Bottom Freezer...
Freezer won't stay consistently cold
replace temp sensors in fridge and freezer (easier to do together) should work fine...
Feb 04, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Freezing problem
I think you mean that milk freezes, etc.
Probably bad thermocouple. In the refrigerators I'm familiar with, there is a thermocouple thermostat in the freezer. There is no measuring of refrigerator temperature; it just gets a portion of the cold freezer air.
If the thermostat is bad, then ice cream should be rock hard too, for it never quits cooling except on defrost cycle, three times per day.
Jun 16, 2008 | Candy CPCA270FFK Bottom Freezer...
Refrigerators Logo
49 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
