My pc suddenly shutdown while playing just cause 2. why is this happen?please help me
  • 44 Answers
Possibly a safety mechanism, check RAM requirements and compatibility and PC specs
Posted on Jun 01, 2010
My Fujitsu computer power suddenly goes of while i am working
A couple of things to check. The CPU could be getting too hot and causing the shutdown as the bios has fan and temp shutdown configurations or the power supply is going bad. If thease 2 things are not the problem you may want to check the power circiut that the unit is plugged into.
Sep 16, 2013 | Fujitsu Siemens SCENIC ED-1170...
My emachine shutdown suddenly while playing games
Hello the is the homepage:
http://support.gateway.com/us/en/emac/product/default.aspx?modelId=1257
Your pc is probably overheating, due too many programs opened at one time, or dust in the cpu cooling fan.
Try to clean the cooling fan element:
It`s probably blocked by dust.
A pc repair shop, can help you with cleaning your pc, if you have no experience with that.
Try not to use a laptop, for big games, they will not last long.
Good luck
Feb 02, 2013 | Ema mb.n5402.001 - Emachines E525-2200...
HI MY LAPTOP SUDDENLY BLACK OUT AN HOUR OR TWO AGO..WHILE I'M PLAYING OFFLINE GAME. I CAN OPEN THE LAPTOP BUT THERE'S NOTHING IN THE LCD.IT'S JUST BLACK.. I TRIED TO DO ALT CRTL DEL BUT NOTHING...
Hi
I get that you was play on the notebook and it was hang and give black screen ...
please try this steps and I hope that helps you :
1- if you don't shutdown the notebook please click along on power button to shutdown the device and then open it again.
2- if you do that you must check about any voice appear when you start the device like Beep ...if there I think there's a RAM Problem or VGA.. if RAM it,s make long beep ..
3- if there is no sound thin you must note if the start up info appear in screen like Acer,CPU and RAM info , Boot info ....
4- if it appear I think you need new operating system , else may be its Video card problem ..
you can also remove the RAM and restore it may be that solve the problem.
Apr 24, 2011 | Acer Aspire 5100 Notebook
My desktop shutdown after several minutes, reboot it again but it shutdown again. reboot again but same thing happen, pc shutdown. what is the problem?
That's like stating my car was going down the road, then suddenly died. What is the problem?
Open the hood, take a look. Maybe it's something obvious.
Same thing with a computer.
1) Computer unplugged from power, open the computer case. See if the Processor fan is dirty, and the computer case fan/s.
If so use a can of compressed air for computers, and clean.
[NOTE*
BEFORE you reach inside your unplugged from power computer, observe Anti-Static Precautions ]
2) See if there are Electrolytic Capacitors on the motherboard.
Bad capacitors for the motherboard voltage regulator circuit, will cause rebooting.
How to identify bad capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
The motherboard Voltage Regulator Circuit,
http://www.hardwaresecrets.com/article/616
Example;
http://www.youtube.com/watch?v=KN6_-8fYHo0
(Starts at 0:04)
3) Power Supply
Weak Voltage power rail. Caused by failing Electrolytic Capacitors.
(Radial Aluminum Electrolytic Capacitors)
Sep 04, 2010 | MSI Computers & Internet
Laptop goes suddenly off
The sudden shutdown, is caused by an overheat problem.
Notice that the laptop is hotter than usual when it happens.
As a quick solution, get a vacumm and **** the dust accumulated on the fan or fans.
That should bring your laptop back to work.
In more serious cases, the heat sink will need to be cleaned up.
If you are not familiar with the process you should seek for professional help.
Please rate this answer if its helpful
Jun 14, 2009 | Acer A2909.001 Aspire 1800 Aspire 9500...
Toshiba Satellite shuts-down by itself in about 1 minute
Could be hardware or software problems, IF its hardware issue the only problem makes this if the Cpu fan doesnot work, so the Cpu gets hot and then it shutdown in order not to be damaged. but mostly its software issue that remeber if you installed any program before this is happen, and try to stop shutdown by this command, if you did this and this stop shutting down your laptop this is absolutley software problems or programs conflict:
hit Start, then Run , then type this : shutdown -a
this will stop your shutdown if it works, try to uninstall the last programs causes this issue,if it doesnot let you use safe mode command.
Regards
Mar 01, 2009 | Toshiba Satellite M45-S265 Notebook
Sudden Shutdown
Hi, I am Sanja and will try to help you.
Try to remove battery from your motherboard, and power cable from computer case. Leave it for about minute, and then return battery, power cable and try to turn on the PC.
You should have no trouble in identifying battery, it is pretty much standard, if you have more questions please do post them
Regards, Sanja.
Sep 15, 2008 | ASUS P5P800-VM Motherboard
PC sudden hang and garbage windows Whats the cause?
I am only using the onboard video w/c is geforce 6100 nforce 430 chipsets. I already reformat the windows xp and loaded the CD driver that came together the mobo and still no problem.
I just want to know whats the cause, can drivers cause the problem? In nvidia there is no Geforce 6100 nforce 430 BUT there is Geforce6150SE nforce 430 and I already downloaded that thought that its the driver but when I am using it for 2-3 days it hangs and problem occur...but I am not so sure if thats the cause. Pls help me troubleshoot w/c is the problem.
Mobo chipsets or processor is defective?
I already tested the processor and it has no problem. I still dont know if the mobo is the fault. For 2 months of use I never had a problem like this.
pls help..thanks...
Jul 29, 2008 | ASUS M2N-MX Motherboard
How I can view my phone memory contacts in HTC touch
hi to all
please do not disconnect your mobile from PC at the time of Syncronisation in process.
or it may happen when ur pc goes to shutdown automatically at the time of syncronisation
May 13, 2008 | HTC Touch P3450 Smartphone
Overheating
no this happened with my friends hp laptop then he updated his bios firmware over the internet and now his laptop does not gets off when hot
Dec 13, 2007 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
